Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Audio & Electronics Forum
Hi-Fi upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Old 11-17-2011, 09:20 AM
aa240sx's Avatar
aa240sx aa240sx is offline
Mein Auto: 2003 BMW 525I
First Gen Dice Ipod Integration Kit work with 6th Gen Multi-Touch Ipod Nano?
Quick question to put out there.
Believe it or not I still use my first gen Ipod Nano with my Dice unit in my E39 BMW and it works great with my OEM headunit, full compatibility.
However, as many of you may have heard, Apple is now recalling the first gen Nano's and replacing them with 6th gen Nanos with Multi-touch.
So, of course I'll all in, but I never use my Nano outside of car. I just plug it into the Dice unit and forget about it.
Have been doing a little research and it turns out the latest Nano still uses the 30 pin connector that is found on nearly all Ipods, Iphones, even Ipads. So... great right?
Does this also mean that it will work with a first gen Dice device like the one I have for my car, though? It's called the Dice Ipod Integration Kit and it uses a less attractive square black box form factor.
Not sure what the window is for the recall, but if my Dice device won't work with the latest Ipod Nano Multi-touch, then I'll continue to take my chances with the first gen Nano.
- 2003 525I Sedan - Manual Tranny, M-tech Bumpers Front/Rear, shadowline, M5 Mirrors, 19" Miro 279's, NNR Coilovers, Front lip, 50% tint, Dinan ECU Stage II, Dinan CAI, Dinan Free Flow Exhaust, DICE Ipod, Connects2/Parrot Bluetooth, SSK Kit, AC Schnitzer Shift Knob, CDV Delete,
- 2008 R350 Mercedes Wagon
Old 11-19-2011, 12:54 AM
aa240sx's Avatar
Ok, maybe no one uses the first gen Dice IPod Integration kit?
So, I took matters into my own hands and was able to borrow a 6th gen nano from a buddy to try it out. Turns out it does work but a few key features may keep me from making the move. These are namely,
6th Nano will not charge from the dice cable
I can no longer control the nano directly when plugged into the dice unit.
So, my question now is does anyone know what iPods are compatible with the first gen Dice units?
Old 11-29-2011, 03:44 PM
supra88 supra88 is offline
Mein Auto: 740il supra turbo
that is correct the new nano charging part works on 5 volts usb not firewire i believe dice electronics made a new cable they are $30.00 or $30.00
