Old 11-17-2011, 07:53 PM
jackson2275 jackson2275 is offline
Mein Auto: 2006/07 BMW X3
Key Repair
Have a 2007 X3si. Warranty expired an 7/28 and I just noticed the my 2nd key is bad. Dealer says the battery cannot be replaced because it is a sealed key and I would have to buy a new one. Anyone have success replacing the battery in their key?
Old 11-17-2011, 10:54 PM
shendrick shendrick is offline
Mein Auto: 08 M3, 05 e46 zhp, 07 X3
Have not run into this so far with our 07. However, you would think that everything about the key that was important (chip and physical laser-cut key) could be moved to a new shell/battery making the cost pretty much insignificant. However, not sure that would be the BMW way.
Old 11-18-2011, 06:21 AM
John320 John320 is offline
Mein Auto: 2017 X1
Jackson, look back a page to "Remote Unlock Problem" thread - there is a YouTube link I posted on that. Might be a pain but can be done.
Old 11-18-2011, 08:11 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
There was a thread here a few years back on replacing the battery in the X3 key. It involved a radio shack battery a bit of soldering and you were good to go. The cost was something like $2.00 as I recall. The OP indicated the hardest thing was opening the key case. Someone else might remember the thread or you could try to search for it. Good luck!
Old 11-23-2011, 06:58 PM
Thanks for your replies. At some point ill see if I can repair it myself and let you know if I'm successful.
Old 11-23-2011, 08:21 PM
Mein Auto: 2004 X3 2.5i
My memory of the DIY .....
as the case can only be opened by cutting into it,
as opposed to finding a naturally occurring plastic seam that can be pried apart,
I imagine the caveats are that you might slice into the inside components by accident,
and even if it works, after gluing it back together it will never look or feel quite right.
Worth a try though.
Old 12-01-2011, 05:20 PM
HilaryEP HilaryEP is offline
Mein Auto: 2006 X3
I was at the BMW dealer a few weekends ago buying some parts and discussed the issues that I'm having with my key. I have two keys, one which I never use. I've noticed with my main key, that is has been acting non-responsive. I'll double click to open all doors, but all doors wont open. I'll have to lock, then double click again. Annoying. I was told by the Dealer that the sealed keys are "the worst BMW design ever" and that I would not be able to replace the battery once it died. In fact, I would have to buy a new key (est. $180). I am now using the other key and it's working great. He told me to switch out my keys often, as the battery gets charged in the ignition.
Old 12-01-2011, 07:52 PM
Thanks HilaryEP. They key that died was my spare. It's good to know that the battery is charged when in the ignition. I'll have to start rotating the keys out on the wife's car.
The dealer quoted me the same price for a new key. Works fine for a spare. Just can't push the buttons so I can deal with it.
Thanks again for the info.
Old 12-02-2011, 10:15 AM
madurodave's Avatar
madurodave madurodave is online now
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
Try and charge it in the ignition. Maybe you will luck out!
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 12-02-2011, 10:23 AM
That's exactly what I was thinking after the last post. I'll give it a try and post if its successful.
Old 12-27-2011, 10:26 PM
X546IS_GUY X546IS_GUY is offline
Mein Auto: 2002 X5 4.6IS
I own the Gambit key programmer that has a CHARGE BATTERY function. It is a USB driven device that works on Windows XP. You can purchase and try it.
Old 04-23-2012, 06:52 AM
dogpile dogpile is offline
Mein Auto: 2008 E83
X546IS_GUY
pm sent, question about programmer!
thanks!
Old 04-30-2012, 12:07 PM
Captain Roundel's Avatar
Captain Roundel Captain Roundel is offline
Underachiever
Mein Auto: 328,Z3, X3
Our second key was dead 1 day after purchase. The dealer tech charged and reprogrammed it in the ignition. It only took 2 minutes.
Old 02-24-2013, 03:40 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This, from the E39 bestlinks, can also help others, so I post it here for reference:
- How to replace the old-style BMW square key battery (1) (2) & how to replace the rubber key pads in the square keys (1) (2) & what the red LED indicates on the old square key (1) & what can go wrong with a key and where to send it for repair (1) (2) (3) (4) & what battery to use in the new style 2000+ BMW E39, E46, E53, E85, etc. diamond key (1) (2) (3) (4) (5) (6) (7) & youtube videos of diamond key repairs (1) (2) (3) & a square key to diamond key retrofit and transponder swap (1) (2) (3) (4) & diamond key to square key retrofit questions (1) & how to recharge your key out of your BMW and how long that key will last in the drawer before it needs that off-the-car recharging (1) & the details on swapping the BMW diamond key transponder (1) & the proper diamond key initializing or programming sequence (1) (2) (3) (4) (5) (6) & what to do if your only key is locked inside your bimmer (1) & a description of the various types of BMW Remote, Illuminated, Spare/Wallet, & Valet/Service keys (1) (2) & a list of diamond key EWS, FZV, & DWA functions (1) (2) & all about the 10-key limit to programming your own keys at home (1) & a description of the ignition key ISN (individual serial number) ten-second rule (1) & what to do if you lost your only diamond key (1) or what to do if your BMW key was stolen (1)
Old 02-24-2013, 04:44 PM
urquattro83 urquattro83 is offline
quattro
Mein Auto: 2007 X3 3.0si
Is there any chance you could offer the part or model number for your Gambit charger, X5 guy? Thanks for your thoughts!
Life's great in beautiful Skagit Valley
Old 02-24-2013, 04:50 PM
quattro
Sorry, just posting to subscribe to thread...
Old 02-24-2013, 05:05 PM
Here's the link. Worked well for me. Hope this helps.....
http://obd2tech.com/177-car-key-prog...t-300plus.html
Old 02-25-2013, 10:39 AM
legalfee's Avatar
legalfee legalfee is offline
Mein Auto: 2004 X3 2.5i 5AT
Here's a link to the Youtube video:
Old 02-25-2013, 01:41 PM
Cutting Key Open
I don't advise you to cut your key open. Its all up to you.
Old 02-25-2013, 07:41 PM
MC-X3 MC-X3 is offline
The Pumpkin King
Mein Auto: 2006 X3, 2009 E89
If the battery is already dead, you aren't really risking anything other then the price of the battery you are putting in it.
Old 02-25-2013, 08:49 PM
My last post.... Again, if intended to be serviceable, would be serviceable.... Its not about screwing the end user or the risk (other than cutting yourself). Overall, with all the time u wasted with installation time, battery purchase, research, etc... and hopefully it's the battery..... you are further ahead by just buying the key from the dealer.... If you have lots of time on your hands or have something to prove to yourself go for it! If you think its a dead battery, charge it with the vehicle or $100 gambit, or buy a key for $175... Don't forget to program your door locks and trunk to the new key, you can do that yourself without scantool, but need all keys present.
Just remember its just a key..... On to the next repair....
Old 02-26-2013, 08:30 AM
bluebee's Avatar
Here is some more information for you X3 folks:
