Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 11-21-2011, 06:09 PM
zach0726 zach0726 is offline
Mein Auto: 2010 335d, April build
Instrumentation issue or engine issue?
Put 1600 miles on the d this weekend. Averaged 35mpg, 75mph. Mostly flat driving, some small hills, across TX/LA/MS/AL, ambient temps 50-75 def F.
Here's the rub: On 3 separate occasions indicated MPG (instantaneous) dropped 15-20MPG for about 25 minutes, each time. Engine was warmed up, car was running at highway speed, no other apparent issues - usual great acceleration, no vibration, no noise, etc. Issue occurred on 3 separate tanks of diesel bought from "reputable" locations.
Towards the end of each of these episodes you could see the MPG needle fluttering from 20 to 35 MPG as the episode began to subside. This transition would last for about 2 minutes, then indicated MPG was back to normal.
Anybody else experience this or have a guess as to what's going on? Thanks
27k miles.
Old 11-21-2011, 06:51 PM
Pasa-d Pasa-d is offline
Mein Auto: 335d
DPF burnoff?
'11 335d M-sport/Le Mans/Oyster/Glacier/Titanium angel eyes
Lifetime avg fuel economy: @27,000 miles, 35 mph, 28.0 mpg
Pollution is bad, but carbon isn't pollution!
Old 11-21-2011, 08:02 PM
DnA Diesel DnA Diesel is offline
Mein Auto: E90 335d, Mk4 Jetta TDI
Originally Posted by Pasa-d View Post
DPF burnoff?
This.
2009 335d Sport - Space Grey, Gloss Black on Black Leather (pics)
Old 11-22-2011, 03:27 AM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
I've never noticed something like this, especially when running at a steady load. I suspect some sort of instrument issue or interference, emi (electro magnetic interfernece) perhaps.
Old 11-22-2011, 09:55 AM
Ah....DPF burnoff. That's was a new one to me Now I can go back to enjoying the car and not worrying about a gremlin. After reading more about DPF burn-offs thats pretty much exactly what's going on. Thanks guys.
It sounds like the engine timing is altered to produce hotter-than-normal exhaust gasses during the burn-off which leads to reduced mpg....that right?
Does 3 burn-offs during 1600 miles of highway driving seem excessive? Normal drving routine is routes <10 miles highway at a time.
Old 11-22-2011, 11:01 AM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
Me too. That is a huge drop in mpg.
--Aaron
Old 11-22-2011, 12:37 PM
Stugots's Avatar
Stugots Stugots is offline
Speed Demon
Mein Auto: '10 335d E90
My question is how it is that you're viewing the instant MPG, unless you're talking about the bar that's underneath the tach. Did you get your car coded to add this (I plan to do exactly that, along with the digital speedo, along with some other goodies)?
Old 11-22-2011, 04:57 PM
julesandtrish julesandtrish is online now
Digital speedo? Come on Stugots....we need more details on this. Pretty please?
Old 11-23-2011, 05:37 AM
No fancy instrumentation/coding (yet). I sure would like to see some more engine data - temps, DPF burnoffs, and a lot more. I was using the bar under the tach (but clearly the same data was being fed to the avg mpg calc as it was decreasing rather quickly).
Since I was cruising on flat interstate around 75mph, before the events mpg was low 40s. During the events mid-20s. After the events mpg was somewaht better, getting close to 50 which I think is why the trip average still managed to be around 35mpg.
The wierdest part was the mpg needle fluttering a little bit (between 25/40) before returning to normal.
Old 11-23-2011, 08:02 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
I suppose a DPF cycle could cause some unusual shifting in intrumentation.
I've just never noticed it after 30k miles and 2 years of driving this car.
Old 11-23-2011, 08:41 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '00 540iT
I'm going to go out on a limb and guess extra fuel is injected after the main compression cycle, not burning in the cylinder but instead gets pushed to the DPF where it burns to do the cleaning. This extra fuel decreases MPG, but does not impact the operation of the engine itself. That's my story and I'm sticking to it untill someone comes up with a better one.
Old 11-23-2011, 09:17 AM
SteveGu SteveGu is offline
Mein Auto: 335d, vermillion/gray
specifically:
"Soot particles have a relatively high ignition temperature. So, the
exhaust temperature must be raised in order to initiate a regeneration
phase. The exhaust temperature is raised by "post injection"
events. The DDE system triggers the injectors after initial
combustion has taken place.
This raises the exhaust temperature,
which in turn burns off the accumulated soot particles.
The DDE will initiate regeneration every 300 to 500 miles depending
on several factors. Mostly, the regeneration is transparent to
the driver. There may be a light loss of power for a short period
while the soot is burned off."
from BMW "Introduction to Diesel Technology" pdf
Old 11-23-2011, 10:47 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Thanks Steve,
I realized it was heating, just not how that was done. So they are essentially pushing unburned fuel through the exhaust into the DPF to "burn".
Fully explains the momentary drop in MPG.
Old 11-25-2011, 11:50 AM
pql pql is offline
Mein Auto: X5 diesel
does anyone know if this fuel is injected into the cylinder or further downstream?
Old 11-25-2011, 02:23 PM
I am not reading anything that suggests that there are 'injectors' except in the cylinders.
Old 11-25-2011, 02:44 PM
pql pql is offline
thanks, I gather that in some engines the fuel is injected downstream of the cylinders for the DPF regen cycle
Old 11-25-2011, 03:17 PM
It does inject more fuel and some people claim to see a drop in mpg when it happens. No one ever has claimed though to see any where near 15-20 mpg drop. Suppose it is all in how they are monitoring things.
--Aaron
Old 11-25-2011, 04:20 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
Here is an interesting take on this subject:
I drove from Hagerstown, MD to Phoenixville, PA over the holiday. The trip is approximately 160 miles, mostly flat, I-81 and PA Turnpike. On the trip to PA, I averaged 72.1 mph and got 39.2 mpg. On the return trip, exactly same route, I averaged 71.6 mph and got 36.7 mpg. The only thing I can figure is there was a DPF cycle on the return trip.
Colonel (Ret) US Army / Hagerstown, MD
2010 Z4 s30i Alpine White/Beige
PP/SP/CWP/6MT/CA/NAV/ipod/USB
ED 1-29-10/Redelivery 3-8-10 (weekend car)
2013 Audi A6 Quattro (daily driver)
2011 335d (Ret)
2009 335i vert (Ret)
2007 335i vert (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 11-25-2011, 06:07 PM
I can think of many times I have shut my car down and discovered it was doing a regen. My mpg for those tanks though were no different than the ones around them. Perhaps it just is a difference in overall car use.
--Aaron
Old 11-29-2011, 10:23 AM
Stugots's Avatar
Speed Demon
You can code our cars (not just the d) to have features some of the other cars have standard (like the M), in addition to adding other features. Digital speedo is one, instant MPG on your OBD (where your trip odo and your average mpg are) is another, and a host of other things.
335d, mileage, mpg
HTML code is Off
