E90/E91/E92/E93 (2006 - 2013)
View Poll Results: Does your 2011 328xi have the same problem?
Yes 12 63.16%
No 7 36.84%
Voters: 19. You may not vote on this poll
Old 11-21-2011, 08:54 PM
baoma baoma is offline
Mein Auto: 2006 325i
Whining sound from new BMW
I just got my new 328xi and noticed a whining sound coming from the dash when car is started from cold, accelerates, or runs downhill. This has nothing to do with AC (it is there when AC is off). I did not hear this from my old 2006 325i. I talked to the salesman and was told that is normal. I tested another 328xi at the dealer, it also has the whining noise. It is really annoying and can be noticed even when the radio or music is playing at medium volume. I know there are several posts in this forum reporting similar issue. This is going to drive me crazy if not fixed. Does anyone have the same problem and have it fixed under warranty?
Thanks.
2011 328xi sedan/AT/Black/Premium/Navigation/Convenience
2006 325i/Black/Premium package/Navigation system (totaled)
Old 11-21-2011, 10:00 PM
adityab adityab is offline
Mein Auto: 2009 BMW 328i Sedan
Might be the infamous transmission whine - mine does the same, and it's considered normal. Sounds a bit wheezy, for lack of a better term. I just keep convincing myself it's part of the BMW-ness of the car.
Old 11-21-2011, 10:18 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
The transmission whines when the car isn't moving? Ugh, that sucks. Is it a torque converter thing? Because I've never noticed it on any of the MT cars.
Old 11-21-2011, 10:31 PM
I didn't realize your car whines at standstill. Mine only does so when moving, but it might be an unfair comparison given that it's an 09 with RWD. Might be worth getting a second opinion from another dealership.
Old 11-21-2011, 11:13 PM
Alien2012 Alien2012 is offline
Mein Auto: 545i
Thats a bad steering pump i had the same problem replace and baumm sound is no more
Old 11-22-2011, 05:51 AM
DSXMachina's Avatar
Automaticallyparsinglinks
That's the most common cause of what the OP is hearing.
OP, try turning your steering wheel hard left and hard right. Does the sound vary? It's the pump.
If the sound stays the same then we don't have any idea what the heck we are talking about.
Old 11-22-2011, 08:45 AM
AllBlackBimmer AllBlackBimmer is offline
Mein Auto: 08 328i, Prem, Sport, MT
What does this sound like? I realize it is hard to describe sounds...
but notice a "whinning" sound from my car too, but i thought it was either the summer tires or sometihng or that nature but coul dnot reproduce the sound - it makes the sound almost randomly ... it won't happen at low low speeds (less than 20 mph) but when I get going a little I notice it...
its a really faint sound, almost as though someone was holding a credit card against a tire ...
does this sound familiar to anyone? ...is this my trans or steering pump? ... or something completely different?
EDIT: I have a '08 328, RWD, Manual transmission.
2008 CPO 328i Jet Black, Premium, Sport, Manual, Xenon.
Old 11-22-2011, 08:56 AM
Thank you all for your reply.
DSXMachina, you are absolutely right -- When the car is parked and the wheel is turned hard left or right, the noise become louder.
As Alien2012 has said, I am going to have the steering pump replaced.
Old 11-22-2011, 09:26 AM
dirtybird_434 dirtybird_434 is offline
Mein Auto: 2006 330xi
Does it sound like this?
http://www.e90post.com/forums/showthread.php?t=599939
Old 11-22-2011, 09:34 AM
DSXMachina's Avatar
Whoa, you like throwing money away? It might just be that your pump has gotten some air in it. That's the number one cause of whining. Remove the reservoir cap and ensure it is full (be absolutely sure to use the right fluid!). Leave the cap on but loose.
Turn the wheel left and right 10 times slowly. Each time make sure that you have turned the wheel to the limit and hold it there for a second. Check the fluid level. Still good? You're done. If it dropped too low you'll have to top it off and start over. When done be sure to tighten the cap.
If it's your lucky day you've got a quiet system and you owe me one.
Old 11-22-2011, 09:52 AM
Originally Posted by dirtybird_434 View Post
It is not the same noise as in the link. The noise can be best heard in the dash not under the hood. It is like wind blowing through a narrow pipe.
Old 11-22-2011, 09:53 AM
Thank you. I will definitely try that. If it works, I will treat you for dinner
Old 11-23-2011, 07:33 AM
Hi DSXMachina, I tried your method. It seemed to have not solved the problem. You said the reservior should be full, how full is it?
Old 11-23-2011, 10:13 AM
DSXMachina's Avatar
There will be either a mark on the outside of the reservoir which indicates "full", or a dipstick under the cap which is marked like an oil dipstick.
Old 11-23-2011, 11:40 AM
Yes, I see the dipstick on the lid.
I guess I will have to have the pump replaced to solve the problem.
Old 12-20-2011, 05:03 PM
I took my car to a dealership and showed the service person the video. He watched it and said it is horrible. Then another guy from the shop test drove my car and also noticed the noise. In the end of day, dealer called me saying the noise is normal.
This the video I shot some time ago and now the noise is going louder
Old 12-20-2011, 07:43 PM
jertronic jertronic is online now
jertronic
Mein Auto: 2008 328 xi sedan
I will be checking upon this thread regularly for updates. My 08 328xi sounds IDENTICAL. The whining is obnoxious. The transmission fluid has been changed and the PS fluid topped off with the appropriate fluid (CHF 11S)
The whine has not subsided with my vehicle. The noise level began progressing at the age of 5K or so. I now have 60K and have lived with the noise.
2008 328xi E90|N51|monaco blue|premium|sports|cold weather|logic 7|ipod|BMW Assist|xenon|sunshade|HD radio
Old 12-20-2011, 08:52 PM
dtc100 dtc100 is offline
Mein Auto: 2011 328i
Is it just me the video has no sound?
Never mind, PC issue.
What sound? Is it the high pitched scratching sound like runing a sand paper? If so no, I don't have it.
Old 12-20-2011, 09:35 PM
Yes, the high pitch sound which most obvious between 8 -16" in the video.
Old 12-20-2011, 10:49 PM
I hear it now, I do have similar whine, but not as pronounced as yours. I actually like it, but I understand we have different tolerance levels.
Old 12-21-2011, 06:03 AM
pamejame pamejame is offline
Mein Auto: 325I 2006 Sport Package
Just bought a used 80k miles, 2006 325i, sports sedan. low profile tires..drove it to San Antonio from Austin yesterday.. It sounds like a windup toy. The whinning, freaked me out. Driving straight, and coming to a stop. just keeps on whinning at a lower idle?? "Goldie", still has extended BMW warranty for another 20K miles left. I think this whine is annoying and worries me. What the he.. is that really,, bad lube..throwout bearings on an automatic trans ??? Any other issues with the sport 325i sport.. Please advise, PS,, anyone have some ideas as to how I could take advantage of the 20K warranty remaining.. things I should complain about now.. someone mentioned "steering pump" problems.. maybe I could need One?
Thanks to all, Pamejame
Old 12-21-2011, 06:19 AM
hpowders hpowders is offline
Bruins Beat Blackhawks!
Mein Auto: E90, Porsche 911, VW GTI
I've had 4 BMW's. Never had the whining sound. BMW continues to make its cars more complex. Perhaps the whining sound is the result of one of these unwanted, unnecessary technological improvements.
Oh well. At least you will get a free pen.
There is no more beautiful car on Bimmerfest than my gorgeous Forest Green Porsche 911 coupe!
Obama is an incompetent liar!
Porsche: Accept no substitute, unless you're poor!
The E90 sedan is the last in the line of great 4 door 3 Series BMW's. Too bad.
"The VW GTI remains and will likely continue to be one of the finest compact sports cars in the world." Christian Seabaugh, Motortrend, March 27, 2012.
06/02/2005-03/02/2013: 7 3/4 Great years on Bimmerfest!!!
Old 12-21-2011, 06:45 AM
Thanks, going to get it checked out..
Old 12-21-2011, 12:56 PM
zeeway zeeway is offline
Mein Auto: 2011 328 ix
I have a 2011 328xi (but with auto)...I can hear a whining sound when I first start off in the morning, but then it slowly goes away. I figured it was the oil in the hydraulic coupling used in the X drive. I did watch and listen to your video...never did hear excessive whining.
Angie
2011 328 ix Coupe \ Sports \ Premium \ Winter \ Space Gray Metallic \ Black Leather
Old 12-21-2011, 03:49 PM
Exclamation Whining 2006 325i
Thanks for the replies..Tomorrow BMW San Antonio ..check up.. The original whine started after 65 miles on highway at 65 to 80 mp speeds...once I slowed on access road and with the stopping and going, it was really noticeable and annoying...
Today..just did a little normal town driving lower speeds.. no noise!
I'll give a report after my apt at BMW tomorrow.. I hope they fix what they find..and not try to BS me..pj
