e39 rough idle on cold start - Bimmerfest - BMW Forums
Old 11-22-2011, 09:43 AM
EURO540M EURO540M is offline
Mein Auto: 03 BMW 540i ///M
I recently started experiencing rough idle on cold start. Once the engine warms up it goes away. What can cause that?
Old 11-22-2011, 10:27 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Vanos, idler pulley, oil separator.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 11-22-2011, 10:28 AM
mpower997's Avatar
mpower997 mpower997 is offline
Mein Auto: '90 325i
I just recently had the same problem, turns out I had a vacuum leak at the intake manifold/throttlebody
Old 11-22-2011, 10:39 AM
POof540i's Avatar
POof540i POof540i is offline
^^^Worst Username Ever!
Mein Auto: '01 540iA
Very likely a vacuum leak somewhere. Either the CCV, throttle body or intake manifold gaskets.
"The more you know, the more you don't know," Dave Chappelle
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content"-Durant
WTT: Black Comfort Seats for Black Sport Seats. PM for info.
Old 11-22-2011, 11:07 AM
Josh P.'s Avatar
Bimmerholic
Why would it occur only at idle if it was a vacuum leak? Not disagreeing, just wondering.
Old 11-22-2011, 03:57 PM
POof540i's Avatar
Unless I'm misinterpreting his post, I believe he's saying the car has a rough idle on cold starts. Once the car warms, the rough idle disappears. Me thinks the gaskets expand when they warm up, sealing the vacuum leak, thus normalizing the idle.
Old 11-22-2011, 04:52 PM
Trebbia's Avatar
Trebbia Trebbia is offline
Mein Auto: BMW E39 I6
In addition to the seals changing shape suggestion, the OP may not realize the SAP system operates only when cold.
So maybe the SAP system is haywire?
What other systems operate only when cold?
Old 11-22-2011, 09:47 PM
sbersenev sbersenev is offline
Mein Auto: BMW 528i
I got similar. On cold start. The engine shakes a bit and rpms move up and down between 1000 and 2000. every 3 or 4 days. I need to restart the car because it shuts down on cold in the morning sometimed. What doed this mean? is this something to worry about?. if yes, how do i fix it?
Sent from my SGH-T959V using Bimmer
Old 11-22-2011, 09:49 PM
Mein Auto: BMW 528i
I think its the cadilic converter thats building up emissions. Its very expensive to do.
Old 11-22-2011, 10:06 PM
POof540i's Avatar
Is your car throwing codes?
Old 11-25-2011, 07:33 PM
Mein Auto: BMW 528i
cadilic converter for 2000 528i
Yes, I think its the cadilic converter. Anybody know how much it costs?
Old 11-25-2011, 08:00 PM
Mein Auto: BMW 528i
cadilic converter
No Codes
Old 11-25-2011, 08:54 PM
jorjio_k jorjio_k is offline
Mein Auto: BMW 528 99
No Codes
I am experiencing the same problems and no faults what so ever,i guess it is time to replace the oil separator coz i hear a slight whistling sound on cold starts when i accelerate,the problem is the separator or a vaccum leak.
Broken Angel
Old 11-26-2011, 06:37 PM
safety glasses safety glasses is offline
Mein Auto: 2000 528
sbersenev what year is your car?
if it is a 99-2000 then it's most likely your Vanos Seals. Those cars' m52TU engines will stall in the cold at idle and run real rough until they warm up.
A new CCV (sometimes called an oil separator) will make it run a bit smoother but it will still run rough and sometimes stall at idle when the temps are at or under freezing.
I did the CCV last fall and the Vanos this spring and the car is running silky smooth in the cold now, that is how I know this
Sorry OP this may not be helpful to your 540.
Old 11-26-2011, 07:42 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
This doesn't sound like catalytic converter issues to me. First of all, you say it produced no codes. a failed converter should certainly produce a code. Second, clogged converters affect high speed power, not idle speed--at least, not that I've read about.
BMW--giving new meaning to the phrase "disposable income."
Old 01-27-2015, 07:43 PM
Bimmerman4ever Bimmerman4ever is offline
Mein Auto: 97 740iL
Old post but...
Do these cars run fine without cats?
Where I live there is no smog cert requirement since population vs square mile ratio is low
Old 07-21-2016, 01:45 PM
Spitfire Pete Spitfire Pete is offline
Mein Auto: 2000 528i Wagon
2000 528 runs rough when cold
My 2000 528 runs rough one cold and sometimes continues to run rough for a while even when warmed up. I have replaced the CCV without improvement. From all the discussions I've read sounds like the vanos seals. The check engine light is on not sure what the code is right now. Like to hear anyone's thoughts on this issue.
Old 07-21-2016, 01:57 PM
MKJS MKJS is offline
Mein Auto: '99 540iA
Easiest thing to do, aside from starting to swap out a lot of parts is get the codes read and get the fuel trim numbers. Could be a vacuum leak, could be a lot of things. "You can't tell the players without a program."
Jim
Old 07-21-2016, 02:01 PM
Thanks Jim. Will get the codes read next week and go from there...
Old 07-21-2016, 02:10 PM
In the mean time, how's the plugs?
You might start careful exam of the vacuum lines looking for cracks etc.
Jim
