Old 11-23-2011, 08:54 AM
rac400 rac400 is offline
Mein Auto: 745
Alternator bracket oil leak
Has any been able to replace the gasket behind the alternator bracket by simply removing alternator. Also bolts that hold braket on may be loose, so does anyone on here know if bolts are accessable by just removing alternator. ? Thanks in advance.
Added some pics
ID:	302251   Click image for larger version
Old 11-23-2011, 09:19 AM
Bendare2 Bendare2 is offline
Mein Auto: '02 745LI
Getting to that gasket is a pain in the arse.
Old 11-23-2011, 05:46 PM
HerbP HerbP is offline
Most likely if your gasket is leaking, it is not a loose bolt. One of the bolts is behind the motor mount bracket. The bracket along with the alternator, power steering pump, & fender well must be removed. You are looking at around an 8 hour job. The good news is that the gasket only cost 1.50.
Old 11-23-2011, 06:49 PM
apaul99 apaul99 is offline
Mein Auto: 2003 745 li
I just ran into the same problem I found this video on You tube. I just got the parts in and im going to change the gasket next week.
Old 11-24-2011, 12:28 AM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
Just finished doing that as part of a crossover pipe replacement (weep hole problem). Fun stuff...it's cramped in there, but at least you have the air-cooled alternator.
You have to remove the alternator, unbolt / move the power steering pump (to get it out of the way and take weight off the bracket), lift the engine and unbolt the driver's side motor mount. Then, you will be able to remove the alternator mounting bracket.
Sent from my ADR6425LVW using Bimmer
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
Old 11-24-2011, 08:21 AM
Mein Auto: 745
Found my leak. Upper timing cover is leaking. Does anyone know if I need to remove valve cover first to replace this seal
Old 11-24-2011, 05:05 PM
Yes!
Old 11-27-2011, 02:56 PM
Mein Auto: 745
what about having to remove alternator bracket. I can not get cover off, it seems there is one more bolt behind alternator bracket
Old 11-27-2011, 04:10 PM
attempted to load a picture but it would not go..
Old 11-27-2011, 05:18 PM
Here is the TIS. You should not have to remove the alternator bracket.
http://tis.spaghetticoder.org/s/view.pl?1/07/45/57
