Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 11-26-2011, 01:58 PM
Joecarmona//M3 Joecarmona//M3 is offline
Mein Auto: 1995 BMW M3
Chip recommendations?
Any input on installing a performance chip in my stock 95 E36 M3? Is this a do it urself mod, will it make a productive difference in performance, any special brand/site anyone has used that can be recommended ?
Old 11-27-2011, 04:49 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
In general the Conforti chips seem to be best. A chip on a 95 does do nice things, but even better with some other mods. And the chip has to match the mods.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 11-27-2011, 05:48 AM
rrsperry's Avatar
rrsperry rrsperry is offline
Really Senior Moments
Mein Auto: ///M3 sc
Save your pennies. Get the 3.5" HFM, intake, and chip at the same time.
I bought the Conforti intake, HFM and chip from Turner Motorsports (Conforti chip). Ended up with 230 rwhp, 228 tq on a DynaPac. Cost me about $1100...
Anyway, it was faster, the rev limit was raised, top speed removed. But it wasn't OMG faster... It was just better.
Then you add the supercharger or turbo, NOW it's OMG faster....lol
No matter where you go, there you are.
Old 11-29-2011, 07:01 AM
AlpineWhiteM3 AlpineWhiteM3 is offline
Mein Auto: 1995 M3
I installed just the comforti stage 1 chip, it made a little difference, the rev limiter is higher, also the 155 top end speed limiter is also removed... It took about an hour to put the chip in. The hardest part was slipping the internal boards of the ecu...u need a few thin flat head screw drivers.
Old 11-29-2011, 08:18 AM
rrsperry's Avatar
Mein Auto: ///M3 sc
1.) the top speed was limited to 137 mph. The car will do somewhere in the 150's depending on gearing and tire size, with the limiter removed.
For a 95 the really big gains are when you install the 3.5" HFM and remove the exhaust bottle neck before the cats. Either use the OBD2 mid section, or a track pipe, or headers and matching midpipe. (but the track pipe isn't legal and the car won't pass emissions.) Add cams, injectors and a tune you can rock about 240-250 rwhp... All that for about $4K. Or you can install a stage 1 supercharger and make 290's for the same $. Just saying...
Old 12-04-2011, 09:32 PM
Mein Auto: 1995 M3
I had my car at 145 MPH before I put the chip in and 150 after I popped in the chip... go figure. BTW, Its a Euro M3.
Old 12-05-2011, 05:05 AM
rrsperry's Avatar
Mein Auto: ///M3 sc
Again... If you weren't using GPS, but going by the speedo, you are mistaken. BMW vehicle speed as measured by the OBC, and ECU is very accurate where the speedo isn't. The faster you go the more optimistic the speedo is. To verify this, reset the OBC speed function or use GPS, and compare it to the speedo.
At 100+ I've seen some cars differ by 10 mph.
Old 12-22-2011, 09:11 PM
JOHNHOF JOHNHOF is offline
Mein Auto: 95 M3
Conforti and Dinan both good choices
I have had a Conforti chip and at that time I had only a scorpion cat. Back on the car. Now I have a Dinan chip in this car. Both chips work without any problems. The first thing you need is to think about how you will use the car the most and work from there. I drive my M3 primarily at high performance driver schools with about 200 miles a year being driven on public streets. The Dinan setup I have works well for both applications. But since I drive the car more on the track the suspension and brakes setup I decided on does not work very good on the street. As others have said here you need to do more than just replace or flash the chip to get any real gains so you need to decide what you want from the car and work from there.
I bought the following Dinan items together eight years ago and installed them at the same time
and this setup has worked very well for how I use my 95 M3:
Stage II chip
MAF
Big bore throttle body
High pressure fuel regulator
Exhaust
Good luck and I hope you enjoy your M3
John
