Knocking noise in steering wheel when turning right or left. - Bimmerfest - BMW Forums
Old 11-27-2011, 10:40 AM
albutterz albutterz is offline
Mein Auto: 2007 525i
Hi Everyone, I am a first time thread poster on bimmerfest.com and I was wondering if someone could help me pin point my similar problem.
I too, hear that knocking noise whenever I turn my steering wheel to the left or right when I am in a stationary postion or driving very slow, or hitting a small bump. I took my car to a non-certified BMW tech and he felt the problem was with the tie rods. So I replaced with the inner tie rods with new ones (purchased from BMW) and the sterring wheel is still making the noise. I am not sure that I want to spend anymore money trying to fix this noise problem. What happens if I were to leave it the way it is and just deal with the noise? Is this something that NEEDS to get fixed?
This is my second 5 series. I first had the 2005 525i which was not great on the steering.. this 2007 is a lot better and I consider it my baby.. can someone please advise on what I should do.
Thank you in advance!!!!!!
Old 11-27-2011, 11:44 AM
Gerry550 Gerry550 is offline
Mein Auto: 2006 550I M Sport
I am having the same problem! Mine is going to the agents on Tuesday to be looked at. If they find the problem I will post the fix.
Old 11-27-2011, 02:22 PM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Originally Posted by albutterz View Post
I took my car to a non-certified BMW tech and he felt the problem was with the tie rods. So I replaced with the inner tie rods with new ones (purchased from BMW) and the sterring wheel is still making the noise...
If I were you, I would've replaced BOTH inner and outer tie-rod-ends. I've always had the outer tie-rod-ends go bad first...
If tie-rod-ends are not causing the noise, control arm bushings could be the culprit.
Old 11-27-2011, 02:27 PM
EmM HoLLa EmM HoLLa is offline
Mein Auto: BMW
I had this issue... The tech took apart my brake system and tightened a lubricated everything.. He also tightened up my ball joints. I will ask him tomorrow exactly what it was...
Old 11-27-2011, 03:28 PM
pcy pcy is offline
There is nothing to 'tighten-up' the ball joints. If the ball-joint was installed properly, there is no adjustment/tightening-up needed until the replacement of ball joint.
Old 11-27-2011, 05:53 PM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is offline
U of Dawgs
Mein Auto: 08 535iA Spt/11 X5 35i
No cost fix that you can attempt before going further is to tighten your lower control arm and tension strut nut to 165NM or 122ft/lbs.
File Type: pdf Front Lower Control Arm and Tension Strut Nuts.pdf (132.7 KB, 2304 views)
Nube1Kenobi
2011 X5 35i Sport Activity|Plat Gray/Beige/Dk Poplar|Conv Pkg|Cold WX Pkg|Tech Pkg|Prem Sound|Comfort Seats|Hitch|
2008 535i Mon Blue/Dakota Blk/Dk Poplar|Sports Pkg|Prem Pkg|Cold WX Pkg|Nav|RTTI|PDC|L7|HD|I-Pod/USB|PWR Rr shade|Sports Auto - paddles|Active Stg|Comfort Access|F/D R/seats|Rr DMS Airbags|Adaptive Xenons
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
Old 11-27-2011, 06:27 PM
tried that already.. i hope this doesn't turn out to be a costly fix.. let's see what the other guy syas after he goes to the mechanic on tuesday.
Old 12-02-2011, 02:57 AM
hi, was someone supposed to go to the mechanic this week?
Old 12-02-2011, 06:26 AM
Keith2000328i Keith2000328i is offline
Mein Auto: 2015 BMW 528i
You might be thinking of me, but my car had a howling noise at slow speed when simultaneously braking and turning the steering wheel sharply. It started happening in July after the dealership replaced my front rotors and pads. They ended up re-lubricating everything and replacing my front brake pads again. It seems to have fixed it.
This person's issue sounds like something different to me.
Old 12-02-2011, 07:15 AM
Skim Milk's Avatar
Skim Milk Skim Milk is offline
Mein Auto: 2004 530i
I think he was looking for this guy:
2004 E60 with M54B30 - Manual Trans - Winter Package - 19" Style 101 BBS Wheels
Old 12-02-2011, 09:05 AM
Glockz Glockz is offline
Mein Auto: 08 535i
I had a similar "knock" but it was mostly when pulling in a driveway so uneven surface. I tightened up the torx bolts for the strut tower brace and that resolved the issue. Just something you might want to check before investing in tie rods.
Old 03-14-2012, 07:37 PM
Got it fixed.
So I found out what needed to be replaced in order to get rid of that knocking noise - it was the steering shaft assembly. The car is all fixed and is driving very smoothly.. I feel much better now.
One mechanic told me that it was the rack and pinion and he was completely wrong.
Total cost including original bmw part # 32306780892 plus labor and tax in nyc was $548.21. It could have been a lot worst.
Old 03-14-2012, 11:43 PM
As Glockz said, all that was needed too fix my knock was to retighten the bolts on the strut brace and shock assembly...... as simple as that...
Old 03-15-2012, 12:54 PM
aiwapro aiwapro is offline
Mein Auto: 2013 X5 35d
So is this the towers that you see with the hood up? I know those are the strut housing, but is this where you did your tightening? To what torque value?
Old 03-15-2012, 04:33 PM
sockmonkey sockmonkey is offline
Tail out!
Mein Auto: BMW
Goot-n-tight. Standard German spec.
Old 03-15-2012, 07:47 PM
U of Dawgs
I think he was talking about the center or cross strut brace. If you are using the new bolts P/N 51 71 7 063 831, the torque value is 27nM or 20 ft/lbs. I believe the old bolts called for 21nM or 15 ft/lbs... going on dim memory here.
Nube1Kenobi
Old 08-15-2015, 07:19 PM
be-em-dabolyu be-em-dabolyu is offline
Mein Auto: car
i think your shock absorber
Old 08-15-2015, 07:24 PM
Mein Auto: car
i diagnozed the e90 bmw yesterday. when i turning the steering to the right the shock absorber create the knocking noise because it connect to the subframe
