Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 11-28-2011, 12:04 PM
m4dzl m4dzl is offline
Mein Auto: 2011 335d M pkg; 2004 X5
Wheel Spacers for 2011 335d with M pkg 18 inch M rims
I've got the M pkg with M 18's but I want to push them out a bit to fill out the wheel well. What size spacers could I use where I won't have to change wheel lugs?
Old 11-28-2011, 04:57 PM
julesandtrish julesandtrish is offline
Mein Auto: 2010 335d
I don't know that you be able to fit anything above 3-5mm without needed longer bolts. If you do you run the risk of something catostropic happening.
Old 11-28-2011, 05:07 PM
I guess I should point out that when I had my stock 335d 18 inch sport package wheels on the car I put hr spacers on my car with the longer bolts and I had no rubbing issues. 10 in the front and 20 in the rear. I did have to have my rear fenders rolled though. IIRC your M sport wheels have the same dimensions as mine did so you should be good.
Old 11-29-2011, 09:42 AM
Axel61's Avatar
Axel61 Axel61 is online now
Mein Auto: 335d
I believe that Terry from JB wrote me an email stating that 12mm up front and 15mm rear for car w/o staggred wheels if not mistaken, please seek advice from tire companies if possible
Old 11-29-2011, 04:45 PM
cssnms cssnms is offline
Mein Auto: '11 335d
3mm coud probably loe done safely. 5mm not. what's the big deal with longer lugs?
Old 11-29-2011, 05:54 PM
EYE4SPEED's Avatar
EYE4SPEED EYE4SPEED is offline
Mein Auto: 335d M-Sport LCI
The hub centric spacers that I have run on other cars have some minor vibration at higher hwy speeds. Why not buy some replicas with a more aggressive offset?
FS: 19" HRE 840R's/Tires/TPMS http://www.bimmerfest.com/forums/sho...94#post7186394
HTML code is Off
