E36 (1991 - 1999)
Old 11-18-2012, 10:40 AM
harobe harobe is offline
Mein Auto: 1995 325i
Advice needed on 95 325i
I have an oil leak getting worse. Its the oil filter housing - quote was $625 for part and labor. I pulled off the air filter stuff so I can see and the oil filter housing is leaking around a plug on the rear of the housing. Can o-rings be bought for this? If so, where?
Or do I have to buy the whole thing as the mechanic said replace it at $325 for the part.
When I do it, is there anything else I should replace when I remove the oil filter housing besides the gasket next to the block?
I check and top off the oil regularly but it has been leaking a long time, do you think it damaged anything else around there that I should replace while at it?
I also have a clicking noise that just started sounds like its around the alternator.
Advice on these things?
Old 11-18-2012, 08:03 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is online now
Somebody stop me....
Mein Auto: EW/// 86
Unless the housing is cracked you don't need a new one. I'm sure the gasket just fail and it can be replaced. Google Oil FIlter Housing DIY and I'm sure there is something out there.
Nothing else to really do along with that job. Fix the leak and that's it. Please don't pay $625.
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 11-19-2012, 07:22 AM
Thanks TRaV MaNN,
I can see the oil coming from around a back plug it the housing toward the firewall.
I am going to tackle it but dont know where to get the Orings behind the plug.
Can you steer me to where to purchase them?
Old 11-19-2012, 07:25 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Any decent auto parts store will have an O ring assortment. Take your old ones out and match them up.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
