Old 11-05-2014, 09:59 PM
hilaljohn hilaljohn is offline
Mein Auto: bmw 330xi
Steering wheel sensor code issue.
Hi all I have a 2006 BMW 330xi and i am getting Steering wheel sensor message on the dash board.
Old 11-06-2014, 05:55 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
There's no specific error on the dash that shows a bad steering angle sensor. When the SAS fails, you get dsc, abs, and brake lights.
If you have a steering error on the dash, it's most likely the elv lock error.
You can try moving the steering wheel while you switch ignition. This may releive tension on the lock and allow it to disengage.
If your battery is low, try changing it, having it registered, and see if the lock disengages.
Otherwise, the steering column must be repalced. It's about $1200 for a new column, plus a few hours labor to code and install.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 11-08-2014, 07:24 PM
willkenni05 willkenni05 is offline
Mein Auto: 06' BMW 330xi
Or if you're mechanically inclined, you can remove the steering column and relive the lock... It'll save you $1200, but from experience, not for the faint of heart and it takes some patience.
Old 11-08-2014, 07:44 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
THIS may help
Permanent fix noted HERE
Old 11-08-2014, 08:38 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
either replace column at $1200-$1400 and in 3 years time it will play up again... This pre-LCI lock design is a complete joke
or have an emulator installed
https://www.avtotools.com/index.php?productID=437
simple device but works wonder
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 11-08-2014, 10:26 PM
Sorry guys had a issue with my PC at home and was not able to write.
It actually shows few lights lit up.... Brake,and few other ones. Some one said to me that it is faulty Steering angle sensor. Car is driving fine and not causing any issue in driving. But i want to make sure what the cause is. Like i said it shows three messages on display,
Brake (in red color) and also shows 4X4 ABS on display. I can check tomorrow and write here what all it says.
Thank you.
Old 11-08-2014, 10:34 PM
Thank you for reply. like i said it is not locked and car is driving fine. Just shows message on display. Brake light and few other msgs, but i will check tomorrow and let you know.
Old 11-08-2014, 10:35 PM
SilverX3's Avatar
Check battery whilst you re at it
Poor voltage may cause warning lights to go off
Job - Captain
MY11.5 X1 Xdrive25i
Old 11-08-2014, 10:36 PM
Is the symbol red or yellow?
Old 11-08-2014, 10:45 PM
Sorry this is what displays on the monitor Brake light in Red DTS and ABS some one of the guys said it is going to be a steering angle sensor, car drive fine and causing no issue.
Old 11-08-2014, 10:46 PM
BRAKE letters are in red and abs dts in yellow
Old 11-08-2014, 10:47 PM
Car is driving fine.
Old 11-08-2014, 10:53 PM
I will check battery tomorrow.
Old 11-08-2014, 10:55 PM
Thank you for the reply. yeah i can do it as long as i get idea what i need to shoot for.
Steering is not locked.
Old 11-08-2014, 11:38 PM
Reregistered User
Not fer nuthin' and too easy, but have you checked THIS?
Old 11-08-2014, 11:54 PM
I tried that but no luck, will try tomorrow again.
Old 11-09-2014, 08:11 AM
The new part # removes the elv lock.
CAS module is updated to remove the elv check
Old 11-09-2014, 08:13 AM
The optical disc or the eye is dirty or the unit is bad.
You can remove the SAS and clean it. See if it works again. Otherwise, you need a new SAS.
Old 11-09-2014, 09:24 AM
ctuna ctuna is online now
Mein Auto: 325xi wagon
There are DIY procedures for both angle and elv
There are DIY procedures for both angle and elv problems at the following link.
http://www.e90post.com/forums/forumdisplay.php?f=16
If its the steering angle sensor there is a DIY on how to replace or clean it.
If its the ELV there is a DIY on that to.
Best to check the battery first.
Old 11-09-2014, 03:06 PM
Banned
Mein Auto: 2007-335 HTC
When mine had those lit up it was the abs module too
Old 11-09-2014, 05:05 PM
Did u replace the ABS module or what did u do.
Old 11-09-2014, 05:07 PM
Should i go and run scan at autozone or advance parts and see what comes up.
Old 11-09-2014, 07:40 PM
Try to find a BMW Scanner
Generic Scanner can't get all the BMW Codes.
BMWhat
BMWlogger
coding setup
are the best and cheapest route.
Old 11-10-2014, 07:18 AM
That won't reveal anything.
They can only pull faults from the DME.
You need faults pulled from the DSC module.
You need a BMW specific scanner
