E90/E91/E92/E93 (2006 - 2013)
Old 12-21-2011, 03:05 PM
terri_atl terri_atl is offline
Mein Auto: 2011 328i Convertible
hello x26: the SA still hasn't call back yet I am wondering what took so long? I doubt I am getting my car back tonite and that gets me really anxious
Old 12-21-2011, 03:35 PM
x26's Avatar
x26 x26 is offline
*** Team America ***
Mein Auto: 335i
Tell that DeadBeat Dealer to Fix your F##@&&%ing Car!!!
Don't let them Dupe You!!
What's the Name of the Dealer so we can all send them a "Bag of Coal" for Christmas!!
Old 12-21-2011, 04:13 PM
Global Imports. Please don't send them any "coal" before they fix my car. I wonder if they are trying to stall this matter until I will "surrender" & say I will pay for the battery. I won't be able to sleep well tonite, wondering what they doing to my car.
Old 12-21-2011, 04:18 PM
sunny5280 sunny5280 is offline
Mein Auto: 2007 X5 4.8i
Hi yikes, Sunny, Ctuna and all..
I have dropped my car this morning for another round of checkup.. The SA just called and said the #1 cause is Terminal 15 was on (according to the diagnostic test). He said basically that is like leaving the keyfob in the car. I told him that's totally an error then cos I live on the 9th floor, the car parked on the 5th. I locked my car every time I parked and of cos the keyfob goes with me home on the 9th. He said he understood what I was saying, but if they submit the test to BMW, BMW will not pay for the new battery. I said that was the same diagnosis the last time, Terminal 15 was on. But that time no one wanted to explain about #1 Cause, ie terminal 15 was on but all blamed it on my "unfavorable driving pattern". So I told him I should not be paying the battery cos now he was telling me the cause of this irrational battery pattern was due to "Terminal 15"? He said he would talk to his Manager. That was more than an hour ago when he called, he hasn't call back. So I am wondering even if the battery is replaced, the problem, ie the faulty Terminal 15 , still needs to be fixed. Seems like their solution is just to replace battery.
He said it was "like leaving the keyfob in the car". Does this mean he performed the test with the keyfob outside of the car and obtained this result? From what I've been able to research Terminal 15 on is essentially "Leaving the key on". Is it his conclusion you've been leaving the key on?
This may be of some help:
http://www.justanswer.com/bmw/1fqya-...atic-mode.html
Most importantly a way to diagnosis is to see if the calibration sequence is repeated once the key is "removed" from the car and the alloted time passed (15 seconds). I would recommend you put the key in, turn the car on, and see if the headlight calibration sequence occurs. Then remove the key, wait 15 (or 30) seconds, then turn the car back on. If the car performs the calibration sequence again then the car recognized the key was removed. If not then that would indicate a problem. At least that's the way I'm reading it. And, of course, this may not be a definitive test.
While I'm no expert it stands to reason if the keyfob is not in the car and the diagnosis comes back with an error indicating a condition as if the keyfob is in the car then there is a problem with the car that needs to be fixed. And until it is fixed a replacement battery will be subject to the same issue and end up in the same condition as your current battery.
Does you car have Comfort Access?
As for the unfavorable driving conditions I assumed you explained to him you have been taking the car out for long drives on the weekends?
Old 12-21-2011, 04:39 PM
Sunny!!!! Yes I told him the car has been out many days a week on the highways at least 30mins. Thanks to someone in this forum, I actually learned how to test the voltage on the car battery when car is idle or when it is moving using whatever is on the car. I even logged down that info for the past 5 days. I have also given a list of dates which have the "Increased Battery Discharge" warning. Btw, after having the car out 5 out of 7 days last week, 2 days ago I have the "Battery Charged Level Low" popped up.
The SA did say it is like having "the key inside the car" which you know how can it be possible when I live in a highrise condo where I park on the 5th floor and live on the 9th floor. The parking deck is 3rd-7th. There is no way anyone can say my keyfob is in the car or near the car. After I explained to him, he said he understood what I was saying but if they are to submit the report to BMW, BMW is not going to pay for the battery. I am not sure why he just said battery, I hope he meant they will also fix the problem and get that battery replaced. But that doesn't mean I have to pay for the battery when actually this whole episode stemming from November could be all caused by "terminal 15". I don't know exactly how they run the test, he just said they run diagnostics and no matter how they test, the cause was "terminal 15 was on".
Guess I am not getting my car back since it is already after 7pm. I miss my car. I have gotten a loaner, it's just different and really uncomfortable.
Oh, and my car does have comfort access.
Old 12-21-2011, 05:02 PM
I take your not getting the car back as a good thing...at least for the moment. I suspect the service department is attempting to look further into the problem.
With that said if the #1 diagnosis is "Terminal 15 On" and the key is not in the car then there is a problem with the car and it needs to be fixed. Unless it's his position you are leaving the key in the car.
Old 12-21-2011, 05:12 PM
sunny: I hope you are right about that part, ie they are looking into the problem. I don't think any logical person will believe I will leave my key in my car when it is a non private garage. I don't think he believes the key was really in the car from the last conversation, ie why he said if they submit the report, BMW is not going to pay for the battery. He sounded like he was in a difficult position. But it is not fair to make me pay when clearly there is a problem and it's just one of those faults ie not in any typical situation.
Old 12-21-2011, 05:29 PM
I don't think he's in a difficult position. It's his job to properly diagnosis and fix the problem. If the car doesn't shut down because it cannot detect the key has been removed from the vehicle despite the fact it has then it's broken. Given the information we have it's the only rational explanation.
Old 12-21-2011, 05:56 PM
Sunny: I have a feeling he was supposed to ask me to pay for the battery. I have heard dealer has to fork out the battery if it is not covered by BMW. I am sure Global Imports or any dealer will try not to pay if possible. So perhaps usually when "terminal 15 was on", this fault may just applied to people who have their own garage., just thankfully at this time, I have none.
I have read from the warranty booklet on the Battery Care, it states "if car is driven short distances of less than 10 miles over a prolonged period of time, without an occasional drive at highway speeds, the engine's charging system will not maintain the battery." Clearly, I have been taking care of the battery and I have not abused the battery based on BMW's standard. So my warranty of the battery should not be voided. Btw, I have also read up, it does not state anywhere in the Service & Warranty Information that battery is not covered under the warranty. Regardless, even though say someone has own private garage and my same issue happens to them, BMW should still cover it unless the owner repeatedly does the placing keyfob in the car after getting battery replaced before.
Totally agree something is broken
Old 12-21-2011, 06:56 PM
If the #1 cause of the battery discharge is the "Terminal 15 On" issue then you, nor the dealer, should have to cover the cost of a new battery. The "Terminal 15 On" issue likely resulted in damage to the battery and therefore should be covered as part of the repair.
Old 12-21-2011, 08:04 PM
Not sure, the SA did say if they submit the report, BMW is not going to pay for the battery
Old 12-22-2011, 11:19 AM
Ok this is sounding crazy! My SA finally called, he said he has spoken to his Manager and the most they can do is not charge any labor cost. Battery? $258!! I said I have looked up the warranty booklet that came with the car, battery is under warranty. Told him I got the car for less than a year and something is broken. He said unfortunately for that particular fault, BMW will not cover the battery. Told the SA it is not fair cos the reason of this whole episode is "key in the car or leaving the radio on every time" which is what this "Terminal 15 was on". The SA said he agreed with me (ie not fair for me cos there is no way I would have do that in a condo bldg), I have also asked battery aside if they are going to fix the problem since the car is not sleeping. He said no cos they don't find any problem. This is really confusing me. Anyway, I said Global Imports should do a courtesy swap, he said he would talk to the manager again.
2011 328i Convertible | Black Sapphire Metallic | Black Dakota Leather | Bamboo Anthracite Wood Trim| Sports | Premium | Comfort Access | Heated Seats | Navigation | Harmon Kardon | iPod/USB
Old 12-22-2011, 12:18 PM
Deleted.
Another update: The SA called this morning, said the battery replacement is what they will recommend me. There is still abit life in the battery. Same position $258 for battery, no labor cost
Told him I will drive over and talk to the manager.
Old 12-23-2011, 04:53 PM
XXX555 XXX555 is offline
Mein Auto: 2012 M3 cab
high battery discharge here today with low battery, twice in over two years....
Old 12-23-2011, 06:19 PM
hi xxx555, my case it is 3 times within 9 months, or is it 4 times? Got it brand new in March. So this whole $0 maintenance & 4 years warranty is just marketing gimmick cos clearly battery is covered warranty, but oh wait cos of one or more particular reason, BMW won't pay for it
So given no choice, I have actually agreed to replace the battery
What about you? have you sent your car in and what reason or diagnostic the service center told you?
Old 12-23-2011, 06:26 PM
Latest update: Spoke to Service Director and prepared to call it a lemon. Even show him my key ring with elevator key fob, car fob and condo door key. There is no way anyone can accuse me of leaving my car fob in the car, leaving the car unlocked or leaving the radio to drain the car. I am no homeless and don't live inside my car.
But there is just no way to get a courtesy swap or make them honor the warranty for battery. Agreed to pay $258 for the battery but I want the BMW engineer who comes into that service center twice a month to check on this car and I want to meet him. He is scheduled to come in the first week of January 2012. No one in the service center can explain to me why the power is on when clearly I turn off everything n lock my car every time.
Old 12-23-2011, 07:59 PM
Lufthansa Lufthansa is offline
Mein Auto: 2010 E92; '07Lexus GS350
As an aside, I have the BMW alarm system, and it appears that when I lock my car by any means, the alarm is activated, thereby obviously putting a drain on the battery. Is there a way of locking my car and NOT activating the alarm (such as when I park it in my driveway after washing it)? I have Comfort Access, if that means anything.
Thanks for any enlightenment.
Old 12-23-2011, 08:47 PM
Hi Lufthansa, oh my.. thank goodness I don't have the BMW alarm system even though I have the "indicator" thing under the mirror (Don't ask me why). If I have, they going to say "aha, look! you have the alarm draining the battery"
But logically that's the whole purpose of having an alarm, you lock the door, alarm is activated. I have comfort access too. I am bad in analyzing this whole battery draining thing. Hopefully someone has some enlightenment for you I am eager to learn something too.
Old 12-24-2011, 09:02 PM
Bimmer4life Bimmer4life is offline
Mein Auto: 2011 335i
Issue Seems Common Among Owners
My car is a 2011 about 1 yr old now, a few weeks ago I got the Increased Battery Discharge message on my navi. I have comfort access w/ alarm. I have not left the key fob inside, nor the lights or the ignition on. The message went away once I drove it the next day on the highway for 30 mins. A few weeks later I got the same message again, I know for sure I am not leaving anything on. I wonder if the alarm is draining the battery.
I called my SA and he said the increased battery discharge he has heard other owners having the same issue. I've also had issues with my alarm disarming when I lightly touch my door handle, key fob in my pocket, alarm is going off, I'm looking stupid and I have to reach in my pocket to disarm the alarm and then I am getting random messages appear that a door is open when I am driving and I know for certain there is no door open on my car. So something is going on electrically with my car so I have an appoint next week.
I also have slight turbo lag in D mode from 0-20 mph that is noticable. So we will see what they say.
Old 12-24-2011, 10:19 PM
It doesn't help when I run my car a few times a week with 30mins each trip. In the end I have a "Battery Charged Level Low". At least your SA acknowledged about the issue. Mine and my service center initially want to pin on my low miles in the car. Now they just say ignition off, power on.
I will update here in case anyone is interested in knowing. I find it awful when they simply assume "Terminal 15 was on" is based on owner's leaving keyfob in car or leaving the radio on night after night. I don't live inside the car but 4 concrete floors above where the car parked and actually the other side 4 floors up.
Merry X'mas to you and everyone here
Old 12-25-2011, 08:54 AM
Terri.
I'll be very interested in knowing how your situation turns out. Thank you for your posts so far.
Old 12-25-2011, 10:14 AM
Terri.
Hi hi Will definitely post something back when I meet with the BMW engineer in January
Old 12-29-2011, 03:32 PM
dkotanto dkotanto is offline
Mein Auto: 2006 BMW 530i sport
You should have called BMW NA and complained. The battery, if that is what they recommended to be replaced in their final diagnosis, is covered under the warranty and should be replaced for free. Period.
2007 530 xi
2004 X3 3.0i
2006 530i
Old 12-29-2011, 04:19 PM
I would not agree to pay for a new battery. There is a problem with the car that damaged it. The short driving distances aren't the problem. Insist they fix the underlying problem.
Old 12-29-2011, 04:27 PM
All my X5's have had the factory alarm. I've never had an increased battery discharge problem with any of them despite short driving distances.
