Different tires on different wheels - Bimmerfest - BMW Forums
Old 12-02-2011, 06:41 PM
maybebmw maybebmw is offline
Mein Auto: Audi A4
I may have to post this in the tire section, but I'll try here first, being most are 1-series owners...
Driving a 128i with sport package. As most of you know, it has 225 rears and 205 fronts. The stock Goodyear NCT's (which I hate) are worn to the ware bars on the rear, but have at least 3/4 of their life left on the fronts. Since I loathe the Goodyears, I want them off the car, and so the rears will be replaced by something else, probably Conti Extreme DW non-rft. I know it is 'frowned upon' to have different tires front and rear, but how bad will it be to have one brand on rear and a different brand on front? Would it be better to swap out all 4, which I don't really mind, but the cheap man in me thinks it's a waste of a good tread? If I could rotate front to rear, that wouldn't be much of an issue, but alas...
Take your time replying, I'm swapping to winters tomorrow so I won't need to have these tires until April or so.
Thanks to all who will answer.
Tony
Old 12-03-2011, 07:40 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
I had the same problem last year after about 24,000 miles, and since a pair of rear NCT5s would have cost $700, I opted to throw away the good fronts and mount 4 DWS tires for $600 (with a CCA discount).
The idea of combining RFTs and non RFTs - or even tires of two different makes/models - was quickly discarded as I want to be able to depend on the emergency & wet road handling of my 128i. I have not regretted that decision.
Tom
Old 12-03-2011, 09:25 AM
sd330Ci's Avatar
sd330Ci sd330Ci is offline
Mein Auto: BMW 1M, MINI Countryman S
Having 2 different tires front & back will result in very unpredictable handling as diff tires have diff grip (especially new vs old)
Some time back I had to drive summer tires front / winter back (bent 2 winter rims in huge pothole)
That was not fun at all - car goes from huge understeer to oversteer in a sec.
