E36 (1991 - 1999)
Old 12-04-2011, 01:20 PM
Caranell Caranell is offline
Mein Auto: 328i
No heat after installing new thermostat
Hi
I installed a new thermostat in my 1997 328i today as I was only getting heat when the car was going at higher speeds and I thought my thermostat was stuck. So I installed the new one (and it isn't backwards) and now I have no heat at all. I opened the radiator screw and added coolant a few times and it is at a constant level now. the hoses going to the thermostat housing are fairly warm after driving but the hoses going into the dash at the back of the engine are not very warm. Any suggestions? please help!
Old 12-04-2011, 01:26 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Does the engine get to operating temp?
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 12-04-2011, 01:30 PM
Mein Auto: 328i
yes it did. and it is not overheating or anything.
Old 12-04-2011, 02:28 PM
A white m3 A white m3 is offline
Mein Auto: 98 ///M3
still has air in the system. Bleed it
TRM
Old 12-04-2011, 02:47 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
This.
that happened to me when i changed my t-stat last month
just keep bleeding and make sure the heat is on full blast and is switched to hot on ALL dials
-Dino
Old 12-04-2011, 03:02 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Originally Posted by Dino1394 View Post
This.
And raise the front 8-10".
Sent from my ALCATEL_one_touch_908S using Bimmer
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 12-04-2011, 03:48 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yep, you still have air trapped in there.
1998 BMW 328is
1966 Pontiac GTO
Old 12-10-2011, 05:52 PM
himelsphere himelsphere is offline
Mein Auto: 1994 325 i convertable
when u installed thermo did you make shure hole was on top and did you make shure thermo stat cover lil hole was not plugged? bleed air
Old 12-10-2011, 06:13 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
Here's a video on how to bleed your coolant system.
Note: he didn't raise the front at all.
Sent from my SCH-I500 using Bimmer
Old 12-10-2011, 06:36 PM
IgotBMW's Avatar
BE IRIE
heater, thermostat
