Instrument cluster LCD repair. - Bimmerfest - BMW Forums
Old 12-04-2011, 08:51 PM
dpostelnicu dpostelnicu is offline
Mein Auto: 2000 540i
How luckly is it for the LCD to go out? I bought the LCD ribon repair kit. Spend all day sunday thaking the cluster apart and clenaing it, installing the new cable 3 times, trying to get it to display. With the new cable the best I was able to do is first 3 digits on the left, rest re just one solid color. It looks like the LCD is history to me. Has anyone else experienced dead LCD on the instrument cluster?
Old 12-05-2011, 07:08 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
- What are 'all' options when your instrument cluster or MID pixels slowly die due to a press-fit pink electrical-connection tape lifting off its contacts over time (1) & how to remove the E39 instrument cluster (1) (2) & a summary of the BMW NA cluster-repair goodwill policy (1) & how to fix the MID pixels yourself (1) (2) (3) (4) (5) (6) & how to remove the MID (1) (2) (3) (4) (5) (6) (7) and how to test the MID (1).
Old 12-05-2011, 08:12 AM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
If your pixels are out and you want to pay a bit of cash, I'd reccomend http://vdorepair.com/
They are well known here about cluster PIXEL fixes, and in my case guage position fixing.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 12-05-2011, 09:37 AM
I belive the LCD is OUT and not just the Pixels. I replaced the cable that is suposed to repair the pixels and same old after about 4-6hr work. The LCD displays couple of things on the left side and the right side of the LCD is all one dim solid light. Any idea where I can purchase an LCD or LCD and cable besides EBAY (they are going for $125-180).
Old 12-05-2011, 11:57 AM
Brett San Diego Brett San Diego is offline
Mein Auto: 1998 540i
I did the same thing with similar crappy results. New ribbon cable installed, display was worse. Not that it will be of any help, but here's my fail thread...
http://www.bimmerfest.com/forums/sho...rument+cluster
I bought the ribbon cable from:
http://bimmer.netne.net/pixels.html
I consider myself fairly adept at these kinds of things especially with what I thought were reasonable instructions to follow. (although I still botched the return springs on a couple of the instrument motors.) Anyway, it was a miserable failure. I ended up buying a brand new cluster from the dealer.
I don't know if the ribbon cable from that web site is complete crap or if I did something wrong with respect to cleaning the contacts on the glass surface on the LCD side... I just don't know what went wrong. And, that still bugs me.
I think I describe it in my thread above, but when I removed the original ribbon cable from the glass LCD, it appeared that some contacts from the ribbon pulled off cleanly, whereas others left residue on the glass surface. I completely cleaned the glass surface with solvents and Q-tips until there was no visible residue. There didn't seem to be anything on the glass, but if you looked at the glare from a certain angle, you could see the "ghost" of the contacts (or where the old ribbon cable was). To this day, I don't know if I did the right thing, or if I cleaned away the contacts from the glass, and that is why the repair failed... Or, if it was a crap ribbon that was the problem.
I have yet to see any completely detailed DIY complete ribbon cable replacement that clearly shows how to handle the contact surface on the glass LCD side. I haven't been looking for anything more recent since I'm beyond it now, but that part worried me and may have been my undoing...
Where did you get your ribbon cable?
Brett
Old 12-05-2011, 01:11 PM
I bought mine from German Auto http://www.ebay.com/itm/190591748466...84.m1497.l2649
Old 12-05-2011, 01:20 PM
http://bimmer.netne.net/ribbonrepair/ If you look at the end pics you can notice the terminals on the LCD. I was not able to see these. I had to look hard on certain angle I can see a shadow of a trace. I bet when we removed the cable the glue took the terminals with it! Dang on it!
Old 12-05-2011, 01:39 PM
That's a picture I haven't seen. If what's in that pic are contacts deposited on the glass that should stay there, then, yes, I most definitely wiped them out of existence with my cleaning job. Sounds like you did the same thing. The glass contact area ended up looking clear, but at a certain angle, like you say, you can see the "contacts." Or, maybe I should say you can see where the contacts used to be. But, I saw the same thing that you say. The original ribbon cable pulled many of the contacts off the LCD glass completely when the cable was removed. That's why I went ahead and removed all the rest of the visible "residue" because I thought it was all supposed to come off. I didn't imagine that the deposited contacts would pull off with the cable. There needs to be more detail given on how to remove the original ribbon. Perhaps one should soak the original ribbon/glass interface with solvent to begin to dissolve any adhesive (if there is some) before pulling the ribbon off.
Sorry, man. I think you're in the same boat I was. Looks like you may still get some help from BMW, if you just put it back together and make the calls and write the letters as described in a post a few days ago. I wasn't fully aware of this and just went and paid out the nose for a new cluster.
Brett
Old 12-05-2011, 07:02 PM
Here is a pic of my LCD after "cleaning" the contact surface. Not that great a picture, but I think one can see that it just looks like glass with two different alternating shades here the contacts are or were. I have no idea if this is what you want to see or not, but it doesn't really "feel" right to me.
Brett
