Old 12-06-2011, 04:41 PM
kwang0429 kwang0429 is offline
Mein Auto: 2006 750i
Question CD changer flap won't come down and CD changer wouldn't eject
So I have been having this issue of my CD changer not coming out, 2 days ago, it somehow finally popped out and I changed out some CDs and put it back in, now the CD changer flap won't go down and when I try to hit Eject again, the magazine is no longer popping out again..... but it still works.
anyone has any idea how to fix this?
Thanks.
Old 12-06-2011, 05:14 PM
Mr_Burger's Avatar
Mr_Burger Mr_Burger is offline
2007 760Li User
Mein Auto: 2007 760Li
If it still drives the mech when you press eject, chances are it's got stuck through lack of use..
I had a similar issue with my rear DVD changer not ejecting, if my memory serves me well I think one of trays failed to unload (meaning it won't eject).
I just kept tapping/knocking it while it was attempting to unload the cartridge and after a min or so it came out..
Upon loading my DVDs back into the drive, I made sure to select each one a few times to get the gear lubrication back into circulation again..
If your trays load/unload fine (you're able to play all 6 CDs) then either the cartridge mech has failed (or is stuck), the flap position sensor has failed (or is stuck) or some glitch exists between the controller and the CDC..
On the E65, the CDC eject button isn't directly linked to the CDC (unlike the DVDC) as it needs to open a flap (and confirm its position) before ejecting the cartridge..
If it can't do that, it tends to avoid ejecting the cartridge..
I would kill the power from the car for a few mins (resetting all systems) and see if it closes after re-applying the battery lead.
My 760Li - Fully Loaded
Old 12-06-2011, 05:20 PM
Thanks for the detail explanation, much appreciated!
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
To remove the cartridge (don't thank me):
Originally Posted by MakaveliFaison View Post
try this.
get a butter knife. Put the flat edge at the bottom of the changer all the way to the right hand side and slide it in. There is a metal tab that it will hit and put your cd back in the cartridge. Then keep the butter knife in there and slide it all the way towArds the left and it will hit the lock mechanism and spit it out. Good luck.
the reason why your changer wont eject is because your door is out of sync with the gears that open the flap. when the door reaches the top of the cd changer there is a tab on the right side of the at the top door that is suppose to push in 2 buttons that are on the motor bracket at the same time. if the tab has a missing tooth or somehow just got out of sync it wont hit both and just one. if only one is pushed in it will not spit out the cartridge.
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
Old 12-06-2011, 05:36 PM
I wonder if I can find a replacement for just the door than? I believed you are correct...
Old 05-07-2016, 06:37 AM
bluzplayer bluzplayer is offline
Mein Auto: 2007 BMW 760Li
No love yet...
My O8 760Li has the number 2 CD protruding via a small black plastic stick. I assume I will NEVER get the changer out until I can get CD #2 to not be in "playing" mode. The #2 CD is still stuck, and I can't get it to do anything. I put a new #6 fuse in, nothing.
Do I need to do this while the car is fully lit up, ready to drive, or do I need to do something else?
My iDrive shows the CDC and the CD grayed out. I've tried all the methods here on Bimmerfest, but none of them work. TurnerTX has one of the best methods, but I have removed the small screws to get to the "sliding" part, but there is nothing that will move behind/below that plastic part where the tiny screws and the wire card.
I went to lunch and when I came back, the door had closed, but that was the last time it did so. Now it's basically dead. Having given it power, what else could I be missing?
Am I destined to let the Dealer fix this?
Ed
America is a divided country. Liberals and progressives vs conservatives. One side is about fairness, the other side is about fairness. The difference is the definition of fairness.
