Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 12-06-2011, 06:06 PM
alkemyst alkemyst is offline
Mein Auto: 1998 240SX SE
19x8.5 / 19x9.5" CSL wheels, best tire sizes?
I am going to be taking the plunge and buying some real CSL wheels to replace my ZCP's...
I wish they made something lighter in the lineup with the concave look...I like the RE-Mg's on paper, but not the LM look they have.
What tire sizes are the 'best' to run? Not necessarily the biggest I can fit on the wheel.
Anything offer a rim protector? My current ZCP's are badly curbed and don't want to risk that.
Old 12-08-2011, 12:57 AM
E60* E60* is offline
M powered
Mein Auto: E46 M3
I think the recommended setup here would be 235 in the front and 255 or 265 in the rear. It could be pushed to a 245 / 275 combo but then the turning angle and rub issues start to creep up. For the tyre wall size i would potentially go for 30 all round. I've got conti sport contact tyres which are slightly wider than the actual alloy and offer curbing protection.
1997 E36 3.23i
2001 E46 3.20ci SE
2006 E92 3.25i SE
2005 E60 5.30i SE
2004 E46 M3 - Current
Old 12-08-2011, 03:08 AM
I have the ContiSportContact M3's on my wheels now and the previous owner was able to curb them all .
Are the non-M3 different?
Old 12-08-2011, 03:47 AM
M powered
Mein Auto: E46 M3
Ah, it depends on the alloy size. Are you doing 8.5j in the front and 9.5j in the back. When i get the chance i'll upload a picture of my set up. the tyres over hang the alloy thus making it nearly impossible to kerb.
1997 E36 3.23i
2001 E46 3.20ci SE
2006 E92 3.25i SE
2005 E60 5.30i SE
Old 12-08-2011, 03:58 AM
It's whatever the factory real CSL wheels came in
Old 12-08-2011, 06:25 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Personally, I try to minimize the stagger.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-08-2011, 06:52 AM
The 8.5/9.5" setup is more square than the stock 8/9.5" setup
Old 12-08-2011, 08:54 PM
Pendulum's Avatar
Pendulum Pendulum is offline
Mein Auto: '05 AW/IR M3, '07 Rabbit
Originally Posted by alkemyst View Post
The 8.5/9" setup is more square than the stock 8/9" setup
The CSL wheels are actually 8.5/9.5", so it's pretty much the same and really depends on the tires you get. The only stock setup that is 8/9" is the 18s, both the 19s and ZCP run 8/9.5".
Old 12-09-2011, 03:42 AM
The CSL and ZCP cars use the same rears. Yeah should have had 9.5" above...they are a more 'square' look than the ZCP setup being wider and closer to the edge of the fender.
This topic is more about what tire size is best on them though...
Old 12-09-2011, 05:31 AM
Pinecone's Avatar
M Mad
Wheel width is only a starting point. Tire width is what really controls stagger.
Going with a 245/265 setup is more square than the 245/275 setup mentioned.
Personally, I run a 265 all round setup on my car.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-09-2011, 07:00 PM
what's your car? and what wheels?
Old 12-10-2011, 03:24 AM
Pinecone's Avatar
M Mad
E46 M3. But I run a set of stock wheels, except that all 4 are rear wheels.
You have to increase negative camber to make this work, but just swapping the front hats will give you enough.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-10-2011, 05:25 AM
That would put the front wheel 1.5" further out just negative camber can fix that?
Old 12-11-2011, 03:47 AM
Pinecone's Avatar
M Mad
Yeap.
It looks like it will touch, but it doesn't. I ran single adjustable Konis with the 4x rears and 265s for several years. Then put a TC Kline suspension on the car.
Very common setup for E46 M3s. Roy Hopkins ran the setup on an E46 M3 in the One Lap of America. In fact my two extra fronts came from him. As did a set of 4x 265 tires.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-11-2011, 11:04 AM
pics?
Old 01-01-2012, 01:15 PM
mark_12345 mark_12345 is offline
Mein Auto: E46-E92 M3s,997TT,997C4S
Michelin Pilot Sport 2 (all season) are the best around tires... I've tried Conti, Pirelli, etc
The Sport 2 is awesome in wet and dry. The ride is smooth and quite.
I have the following setup and no problems...
255-35-19 front and 275-30-19 rear
Old 01-01-2012, 01:22 PM
The all season is the Pilot Sport A/S. It's a great tire if an all season is all you need.
My new problem is I still want CSL wheels but had to buy Pilot Super Sports in the stock sizes of 225/40R19 and 255/35R19. I don't know how the front tire will be on a 8.5" wheel.
Anyone have experience?
Old 01-03-2012, 02:12 PM
xavier1000 xavier1000 is offline
Account Under Review
Mein Auto: M3 E92
I don't remember anymore, sold mine a while ago.. Just wanted to tell you the CSL's are the best choice! If you want to see how they look on a white M3 E46 check the banner on our homepage!
Looks much like Pendulums Alpinweiss M3!
Old 01-03-2012, 02:51 PM
The banner image was a little small Looks good though. I have a TiAG.
Old 01-12-2012, 09:03 PM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92
I would recommend that you check out the Sportline CS.16 CSL Style Wheels if you're looking for something that is light weight and strong. The Sportline CS16 wheels are rotary forged (aka flow form) and do utilize the same manufacturing process of other light weight wheels such as the BBS CH/CH-R and ADVAN RS. Sportline CS16 wheels are also powder coated as a standard as well for a more durable finish!
They're available in the following setups:
18x8.5 ET35 - 19.8 lbs
18x9.5 ET43 - 19.6 lbs
18x9.5 ET22 - 21.0 lbs
19x8.5 ET35 - 20.80 lbs
19x9.5 ET45 - 22.40 lbs
19x9.5 ET22 - 23.40 lbs
Here are a couple installed pictures on our customers E46 M3 Vert for you guys to check out as well!
We Specialize In: BMW Parts | BMW Tuning | VMR Wheels | Cobb AccessPORT N54 | Avant Garde Wheels | BMW Headlights
Alan Wei
| Alan@ModBargains.com | (714) 582-3330 ext. 8006
Hours: Monday - Friday 8:00am-7:00pm / Saturday 8:00am - 5:00pm (PST)
Old 01-13-2012, 06:58 AM
lucasd2002 lucasd2002 is offline
Rover
Mein Auto: looking for Porsche/BMW
This is probably a dumb question, but is there any problem with putting OEM CSL wheels on a non-CSL e46 M3? There is no need for spacers, is there?
Old 01-13-2012, 08:05 AM
Mein Auto: E92
You wont need spacers and they should fit just fine.
Alan Wei
Old 01-13-2012, 07:01 PM
These wheels don't look like they have any certifications....also is the finish looks a little different than the ZCP/CSL wheels. Price is right and the weight is nice...I just worry about non-certified wheels on a daily driver I put 1000 miles a week on at times (average about 2000/month).
Anyway, my tire sizes were determined for me when I suffered a blow out shortly after making this post. They couldn't get a Conti overnight, ended up with 225/40R19 and 255/35R19 Michelin Super Sports. They had 235/35R19s, but no 265/30's. They had 275/30's as well. I had to make up my mind in 10 mins to get the order in so my tires were there in the morning.
I really like the tires. I just worry if the 225 will be a little off on a 8.5" front. In 6-12 months when I need new tires, I will upgrade the sizing if needed.
Old 01-15-2012, 01:22 AM
Pendulum's Avatar
You should be fine with 225 on the 8.5" wheel. According to Tire Rack, these tires in that size can be used on wheels from 7.5-9". http://www.tirerack.com/tires/tires....ty=2&tab=Sizes
Click on the "Specs" tab and you should see "Rim Width Range" in the 7th column from the right.
Here is another link on the subject from over on M3f. http://www.m3forum.net/m3forum/showp...16&postcount=3
Old 01-16-2012, 11:43 AM
Mein Auto: E92
Sportline is the only company (that I am aware of) who makes a CSL style wheel that is actually certified by JWL/VIA with certification numbers. The Sportline CS16 wheels are rotary forged and are definitely light weight and strong (more than good enough for everyday street driving). The Sportline wheels are powder coated silver which is more durable than most other wheels which are painted.
Alan Wei
