Old 12-06-2011, 08:57 PM
Petlover Petlover is offline
Petlover
Mein Auto: BMW 530i
Oil Service Reset 2003 530i
My car is down to 2 lights ( Yellow/Green) on the Interval, but " Oil Service" does not show up yet.
Shall I wait until the " Oil Service " show up then reset the Interval.
Because I try to reset it, but it is not flashing, it says " Reset, SIA 908 1 "
after 2-3 seconds, it says " End ", but still has only 2 lights ( Yellow/Green ).
Please advice
Pet
Old 12-06-2011, 11:20 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
I'm not positive, but I think you may need to trigger the oil service to reset it. The message you're getting seems to point in that direction.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 12-07-2011, 08:33 AM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
it WORKS
did it many times
http://www.bimmerfest.com/forums/sho...d.php?t=398341
Old 12-08-2011, 04:24 AM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Did you try to redo it again as outlined in my PM? I couldn't tell from your description as to if you were actually following the instructions correctly.
But as to "should you reset the SI display now"...that's a personal choice. SIA III calculates the next OIL SERVICE or INSPECTION based on fuel consumption alone. And due to multiple engines...this factor varies as to how much needs to be consumed...but as you can see in the info below...each green LED is equal to 20% of the total amount. From this, we can estimate that the interval will be equal to a certain mileage based on AVG MPH...so if you like to change your oil based on a specific mileage...you can still use the lights to judge as to how far along you are in the "range" of miles (as well as fuel consumption) you are.
Resetting the display prematurely...doesn't change the fuel consumption calculation (see the 3rd bullet in the tech info below). So let's say you consumed 60% of the fuel consumption value...and then you reset the SI display. When you've consumed the next 40% of the fuel value...your SI display is going to quickly go from 5 illuminated green LEDs...to the yellow LED being illuminated as well as the yellow LED and if later, the red LED.
Personally, I don't reset the SI display until the OIL SERV or INSPECTION light illuminates because that is the time when a SI reset also resets the calculation to begin again.
INSTRUMENT CLUSTER RESET PROCEDURE:
Here's a quick synopsis & video of how to reset the SI display using the instrument cluster procedure which requires a 10/2000-up build date...or basically the E39s that do NOT have the 20 pin DLC in the engine bay:
From what I gather by what you wrote...I think you skipped one of the "press & hold" button instructions.
  • press & hold trip odometer, then turn ign to position 1...continue to press & hold trip odometer until you see "RESET" appear (and the mileage since the last reset...that's what the "9081" in the "Reset, SIA 908 1 " means)
  • release the trip odometer button, then press & hold it again and "reset" should begin to flash after approx 5 seconds (this may be the step you're skipping over)
  • press & release the button (again) and the SI display should reset if minimum value for resetting has occured (or turn the ignition to another position to cancel and NOT reset)
And here is an explanation of SIA III and how the service interval is calculated:
Q {BMW CCA Member #191509}
(SOLD)
