E36 (1991 - 1999)
Old 12-10-2011, 07:53 AM
diqiu diqiu is offline
Mein Auto: 96 BMW 318I, 95 MB C220
96 318i DME relay location?
I have a 96 318i, it had been running perfect all the time, but last Monday it quit starting. I turned the key to the end, all the indicate lights are on like normal, but nothing happened, no crank, nothing...... I checked the starter, it has no problem, all the fuse are good, battery is fully charged. Now I suspect it could be the ECU system problem. First I'm going to check the DME relay, I did some serch, but still not sure where it located. Could anybody tell me where is the DME relay located on a 96 318i? Any idea is appreciated.
Old 12-10-2011, 12:53 PM
mckenada mckenada is offline
BMW for life
Mein Auto: 1993 325-I v6 4dr
under the fuse pane in the engine bay you should see all your fuses and such. next to that cluster of fuses is a black box with a cap pull that off and there should be 3 relays. Im not sure which one is the dme relay but for mine it was the middle one that was white.
Old 11-14-2013, 02:09 PM
billycura billycura is offline
Mein Auto: bmw 318i 1995
diqiu did you find your problem ??,, I'm having the same problem
