Old 12-14-2011, 04:43 PM
AceFX AceFX is offline
Banned
Mein Auto: BMW 760Li BMW X5 4.8iS
Hey M4XBMW7, yes that is the unit.
If you look in your left rear quarter, do you have the connection plug there, just above the NAV unit?
Old 12-15-2011, 04:48 PM
Banned
Video on the move -VIDEO.
For the front seat passenger to enjoy!!! NOT the driver.....
Old 12-19-2011, 07:48 PM
DarkLord DarkLord is offline
Mein Auto: 2005 E65 750i Sport
orderd ;-)
now need to find the correct DVD stacker i only have TV
Old 12-19-2011, 10:37 PM
al7oot al7oot is offline
BiMMER4EVER
Mein Auto: 750Li F02
Does the 2008 has the same cables and plugs ?
Old 12-20-2011, 01:02 AM
Banned
The DVD changer is a retrofit kit available for all 7's so there must be some sort of connection point.
Old 01-01-2012, 09:24 PM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
Originally Posted by AceFX View Post
OK guys you have given me a bone to chew on............it's must be a programming thing.
My menu in the front says, FM, AM, CD, CDC, AUX, TONE, VIDEO.
Now if I want to watch Video, I select VIDEO and then that shows me TV, DVD, Picture and Settings options.
If you are missing these in the front, and you have the Genuine BMW Rear Entertainment system, then either 1. It was a retrofit and it hasn't been coded to your car or 2. but I will see what I can find out.
I have never seen the TV and DVD functions NOT available in the front of a 7. Every 7 I have looked at has the TV and DVD option in the front MMI menu.
Are there any other 7 owners there state side that have the TV and DVD available on the front MMI? Please chip in to this post
I've been researching this issue for quite a while now. For all US E65/E66, the VIDEO source should be disabled on the front MMI menu. It's either a programming thing or the video cable is not even connected to the front display. At this point, I'm not sure which is the reason. I have the MMI trace files from NCS Expert. I'm willing to compare with other non-US source to confirm whether it's a programming thing or not.
For US F01/F02, this is not the case. Just the video-in-motion feature is disabled on the front display by default. You can enable it back easily without a third party component.
Old 01-01-2012, 09:29 PM
Hi All
mine used to say FM, AM, CD, CDC, TONE, TV,DVD with the dvd being translucent as i dont have a dvd player in mine.
After one of the updates last year ( software) i have FM, AM, CD, CDC, TONE, TV only now
Old 01-02-2012, 07:40 AM
lawandorder39 lawandorder39 is offline
Mein Auto: 540i 760li M109 Rm1500
cost
How much does item cost and can a dvd player concect to it?
Old 01-02-2012, 07:13 PM
rippjd rippjd is online now
Mein Auto: '05 745i / '10 X5 35d
Correct. One of the parameters in North America spec MMI / Control Display modules removes the Video menu (2002 - 2005) or TV / DVD (2006 - 2008) from the list of Entertainment sources.
The MMI/CD has to be recoded to enable the menu option(s). Only after this is available does it make sense to buy the Video In Motion module.
Here are some screen shots from a car that did not have rear entertainment, but had the TV/Video module retrofited and MMI/CD recoded: http://www.bimmerfest.com/forums/sho...d.php?t=563704
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 01-04-2012, 04:36 AM
Banned
OK Guys.....I have successfully worked it all out!!!!!
If you have rear TV or DVD I can tell you how to make it appear in the front.
It is a simple code change of the front MMI.
I used Dashsoft 2.10 which I purchased off eBay and I have posted in this forum about how it works and how to use it.
Now with this tool, all you have to do is go to command line 3002 and change pos1: 55 to 5F (gives DVD on front MMI) and change pos5: 49 to 4B (gives TV on front MMI)
If you get stuck......let me know.
I have successfully got control of everything on the MMI now. I can show or remove AUX, TV, CDC, DVD, Bluetooth, CBS, OIL Level, Front Seat Heating......anything on the MMI
Old 01-04-2012, 04:37 AM
Banned
I'll do a video tomorrow and post it showing how it works.....its just so easy........
Old 01-04-2012, 04:39 AM
Banned
I have added AUX and OIL Level and Bluetooth to my front MMI now with this tool
Old 01-04-2012, 04:44 AM
Banned
Hey hd750Li, the video works right around the entire MOST bus via the fibre optics. There is no missing cable.
The only reason you don't see it on the front MMI is because of a simple ASCII code change that needs to be done.
US spec cars have this code set to not show TV and DVD, so by simply changing the code in the MMI, you will get TV and DVD on the front screen.
As per my previous post, you can do this yourself simply and enjoy video on the front screen......
I am in Australia, and I bought a second hand facelift MMI from the US, and I have successfully recoded it to suit my car here in Oz, and it shows TV and DVD video fine....as per my videos I have posted.
You guys can enjoy video in the front easy........if you get stuck just ask me......and I will help
Old 01-04-2012, 06:12 AM
politby's Avatar
politby politby is offline
Mein Auto: 2005 750i
Ace, does this include displaying video on the front screen when the car is moving?
Edit: nevermind; if I had read the whole thread I would have seen that you need the dongle...
Old 01-04-2012, 01:37 PM
Banned
Yep, dongle required for video on the move. There are two cables that connect to the MMI. One is for the NAV, the other is for the MOST bus. The dongle interfaces the NAV cable on the back of the MMI to trick the MMI into thinking that it is not moving.....even though it is...
Old 01-04-2012, 01:40 PM
Banned
al700t.....yes they are identical
Old 01-09-2012, 05:16 PM
robohopar's Avatar
robohopar robohopar is offline
Mein Auto: 06 750Li
hey did you get around to making a video on how to change the programming on this to show extra options on the front screen? also can you link us to the hardware/software you used to get this done?
2006 BMW M5
SOLD: 2006 750Li Monaco Blue/Black|Sports Package|Convenience Package|Comfort Access|Logic 7|Rear Entertainment|Night Vision|SAT/HD|Cold Weather|Luxury Seats|Rear Power Sunshades|35% Tint|22" Custom Wheels|H&R's|Alpina Trunk Spoiler| ACS Roof Spoiler| MTEC v3|
Old 01-15-2012, 08:08 PM
ABC News
Hello All
took 15 mins
now watch ABC news on the way to work did i say watch i meant listen :-)
my tuner picks up on the analogue channels, it gets all the digital stations as well however its a bit jumpy when on the move or ven parked for that matter , slight lag n hesitation.
i presume its a digital tuner other wise it wouldn't get those channels at all right ?
Old 02-07-2012, 01:51 PM
Banned
Check this link out LSG
Old 07-14-2012, 06:54 AM
Banned
Video on the move..........woo hoo
Old 07-14-2012, 01:32 PM
andyn63 andyn63 is offline
Mein Auto: 2008 - 750Li
Hi, AceFX! Wonder if you can help!!! I just bought a 2008 750Li (USA) and it does not have the rear entertainment package! I bought a used BMW 6-Disc Changer off ebay trying to add it in so I can watch DVD on the iDrive screen but I could not see any connection in the trunk where the Navigaton DVD is! Could that connector hidden behind somewhere that I have to open the left-side panel to see it? Or that I have to buy a connector to the changer because it does not come with it? Thanks in advance!!!
Old 07-14-2012, 03:04 PM
Banned
You will need to get a MOST cable to loop it into the MOST Bus.... they are not expensive. Can you tell me what else is in your trunk in the rear left quarter.
Old 07-14-2012, 03:25 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
Hey Ace. I'm online. I need to talk with you when you have time.
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 07-14-2012, 07:17 PM
Thank for the reply, AceFX! The only thing is in the left trunk is the Navigation DVD! Tried to look for the DVD connector, but could not find it!
Old 07-14-2012, 09:31 PM
Banned
Ok, so no VID? SVS? can you see the TCU?
