Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 12-12-2011, 08:12 AM
tvenu tvenu is offline
Mein Auto: BMW X5 - 2006
Changing microfilter in 645ci
How do I change the microfilter?
Is this easily done, want to avoid the dealer and do it myself
Sent from my Xoom using Bimmer
2004 645 cic with SMG
2006 - X5, sport, premium, winter pkgs, 19 inch upgrade, panoramic sunroof
2002 - 540i
2000 - 323ci
1994 - 540i
Old 12-12-2011, 06:07 PM
Yorgi's Avatar
Yorgi Yorgi is offline
There are two filters. Check out my Brake Pad DIY which shows you how to remove one of the two filters in the section related to brake fluid (right at the end of the DIY). If you search the main forum there are also a few good DIY pics for the microfilters.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-13-2011, 08:15 AM
stevelee203 stevelee203 is offline
Mein Auto: 2006 BMW 650I CONV.
i change mine both of them took me less then 5min
[/SIGPIC][/SIGPIC]2006 BMW 650I Convertible Black Saphire Metallic / Black
SMG
Premium Sound
Sport / Cold / Comfort Access
19" OEM
Logic 7 Premium
Sound HD Radio
Heads Up Display
Park Distance Control
K&N air filter
Aluminum Racing Pedals
6000k headlight upgrade
fog light upgarde
2010 MV AGUSTA F4 titanium/RED frame
2010 Audi Q5 S Line
Old 12-14-2011, 12:22 PM
Kansas Corey Kansas Corey is offline
Mein Auto: 2007 BMW 650i black conv
http://www.bimmerfest.com/forums/sho....php?t=499472&
Old 09-04-2012, 12:19 AM
Medicus Medicus is offline
Marine
Mein Auto: 2005 BMW 645Ci
Easiest filter change that I have ever done on a vehicle. Right under the hood by the window on both sides of the vehicle
Old 10-16-2012, 07:26 PM
euhysh euhysh is offline
Mein Auto: 2008 650i Coupe 6MT BSM
Sorry to bump an old thread, but this thread helped out a lot changing out the microfilters. Got a quick question, I'm looking down the intake hole on the side and I see tons of crap and dead vegetation in there. It's completely jam packed in there...anyone know a way to clear this out? I tried using vacuum, needle nose pliers and even chopsticks but no luck, the space is too small. Is it ok to have all that crap in there? AC still works fine and stuff.
Old 10-16-2012, 08:57 PM
Yorgi's Avatar
Can you take a pic of what you are trying to clean? If you are trying to get down into a tight area I like to use a 1/2" clear rubber hose attached to a shopVac. I have the clear hose attached to a step up adapter that fits into the shopVac hose. The adapter cost about $0.50 at home depot. I added a bit of duct tape to the threaded end to make sure it fits snugly into the end of the shopVac hose:
Is it the try you are trying to clean? The tray under the filter lifts out which would make for easy cleaning. Here is a pic from my Brake Pad DIY:
'04 M3 - track
Old 10-21-2012, 12:29 PM
fritchard fritchard is offline
Mein Auto: 645 Ci
I used a section of plastic coated wire I had in my garage to shift the bulk, then dropped my high pressure airline in there for the rest...think it's more of a drain hole than an inlet, and all clear now. Wasn't causing me any issues either, it just needed doing!
Old 10-22-2012, 04:11 PM
Hey Yorgi, thanks for the tip, I guess I'll have to hit home depot...in the picture you posted, the hole I'm talking about is beneath that hood strut...it leads down to the side.
I'll try that wire trick to loosen up the packed debris too. Thanks for the help guys
Old 01-27-2013, 12:33 PM
Blaknificent Blaknificent is offline
Mein Auto: '05 Black Sapphire 645ci
I simply took out the filters and used a vacuum cleaner crevice tool to vacuum out the filters. Worked like a champ. Code cleared itself.
