Old 11-20-2012, 11:09 AM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
My fluid was pretty dark before I changed it. I thought the color was light green but as long as it's not dark you are OK. That system does more than just power steering and it does take a fair amount of fluid to fill it and uses some occasionally. Not sure why though.
Originally Posted by shan904 View Post
Ok, so I checked it again just to make sure it was purple as I was just going off what the picture showed. I dipped a white paper towel and it came out looking like this. Def not purple. Doesn't look very green either, may have a slight tint, but at least it looks pretty clean : )
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 11-20-2012, 11:13 AM
d geek d geek is offline
diesel evangelist
Mein Auto: Volvo V60+ Volvo S80
I'd be concerned if I was losing PS fluid on a regular basis. Definitely look over the system for any signs of leak and get that corrected if you need to add fluid.
Old 11-21-2012, 07:59 AM
shan904 shan904 is offline
Mein Auto: 2005 645ci
When I checked it and it was dry, my car had been sitting for a few hours. I drove to get the fluid, and when I went to top it off the reservoir was almost full to the max line on the dip stick...Are you supposed to start the car before checking it or something? I only had to add just a tiny bit...
Old 11-21-2012, 08:03 AM
diesel evangelist
Check your owners manual for the procedure. It seems to differ from car to car.
Old 11-21-2012, 07:35 PM
HerbP HerbP is offline
My fluid is a brownish color. It sounds like different manufactures use different color dyes. As long as you have the CHF-11s fluid, you should be ok. If you keep losing fluid, I would try & find the leak fast. Repair cost could be astronomical!
Good Luck!
