E90/E92/E93 M3 (2008+)
The latest and greatest V8 powered M3! |
Has anyone used this chip from this CA co. that guarantees 60 more ponies with 4-7 mpg. better for only &69., now?
http://www.gfchips.com/bmwm3.aspx |
saw someone who bought one of these for his acura and took it apart to see what was in it, here's what he found:
![]() i doubt a 4.7Kohm resistor is good for 60hp and increased fuel efficiency |
You forgot to mention elimination of the warranty on a $20k engine as a "feature" ...
Just wanted to see if anyone knew anything about these ![]() I WOULD NEVER ADD ANY MOD THAT IS NOT PROVEN & USED BY MANY |
However, if it is, I'm VERY confident your warranty is OVER the minute you do it (assuming you can't commit fraud and hide it later). To increase hp is to increase stress and heat. Similarly, to increase mileage in the same engine, is to increase heat, since you'll have to run leaner under part throttle uses, to achieve that savings. I'd expect you could install a cold air intake, and maybe new mufflers without risking your warranty. But to alter the software that operates the engine - yea, you're at GREAT risk of losing your warranty on the engine. The claims of the chip supplier are irrelevant, and predictable.
The German Big Three are loaded with engineers with really thick glasses who sit around with calibrated dynos and test tracks and drivers who can put down really reproducible lap times They have worked with all the size. shape and length intakes and exhausts, different throttle curves and compression ratios you can image and more. While they may have goals slightly divergent than yours in the sense that they want reliability and reproducibility as well as have some mandated issues with noise and emissions, the bottom line is no posse of wiseguys with a CNC or a CAD/CAM program in a garage somewhere are going to come up with a solution that will inexpensively increase power output by any appreciable amount. A good rule of thumb from my experience is that you need at least 15% more HP or TQ to truly feel any difference. And if you really want to go faster, bring your money Howitzer. All else is foma. Last edited by allegretto; 12-14-2011 at 05:05 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
