Old 12-14-2011, 06:34 PM
mortyx10 mortyx10 is offline
Mein Auto: 745i
FM AUX Tuner help
Hello everyone
I know most of you did this months or years ago but since I've recently bought my 745i I'm trying to do this mod but I'm getting no luck. here is how I connected my AUX cable
when I connected the tuner back on the car, the FM AM worked as usual and as soon as I connected my phone with music playing, the FM sound stopped but there was no sound of my music. the FM started again by disconnecting the AUX.
here I also have a question regarding the ground wire...where should I connect it? I soldered it to the tuner wall...is that the reason it didn't work?
Then I tried to connect to the back of the board using points C, D, and E.
this time connecting the AUX didn't even stop the FM tuner from playing.
I think its because my tuner doesn't have anything behind those points, not like the others I've seen.
Does anyone know what I'm doing wrong?
Thanks in advance
ID:	304872   Click image for larger version
ID:	304875   Click image for larger version
ID:	304876   Click image for larger version
Old 12-15-2011, 03:44 AM
Mein Auto: 745i
anyone? help please...I want to fix it before putting it back on.
Old 12-15-2011, 03:56 AM
AceFX AceFX is offline
Banned
Mein Auto: BMW 760Li BMW X5 4.8iS
I think I have seen a document about this before, and to do this you have to remove some of the SM components as well. Did you remove any SM components?
Old 12-15-2011, 04:00 AM
Mein Auto: 745i
I've read 3 threads about this, there are two different ways to do it: front and back of the circuit board. for the one I've shown in the picture you don't need to remove anything.
here is the thread:
http://www.bimmerfest.com/forums/sho...d.php?t=491285
Old 12-15-2011, 08:46 PM
Mein Auto: 745i
Finally got it working....
Thanks Ace for trying to help. I've sent you pm regarding your pre-facelift parts.
btw this morning I found something interesting while I was driving my car without the radio tuner. the date and the clock on the Idrive display were missing...they must be related to radio module somehow.
Old 12-15-2011, 08:48 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
how did you get it working ???
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
Old 12-15-2011, 08:55 PM
Mein Auto: 745i
first I used this configuration by MakaveliFaison
and it didn't work, then used this one which is the original idea of this mod.
and it worked the first time.
ID:	305008   Click image for larger version
Old 12-16-2011, 01:56 PM
Banned
Ahhhh, see you had to modify some SM's as I said earlier.....is that what I can see in the photo????
Old 12-16-2011, 07:30 PM
Mein Auto: 745i
yes you were right, but in that thread I posted MakaveliFaison claimed he got it working without removing anything and I thought I could also do it but didn't work. thank you again Ace.
Old 12-16-2011, 10:09 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
glad to see you got it up & working , & thanks for answering my question .
I thought it would be good to ask so your fix could help any 1 else in the
same situation .
Old 12-17-2011, 12:16 AM
dannydos's Avatar
dannydos dannydos is offline
Mein Auto: 745i
Do you have your pictures backwards? Because it looks like you added parts to the board. But I know you said you removed parts.
///E65 745I///22" Asanti AF128///H&R springs/// 12" JL W7///
///700whp 00 EK///<-----To many mods///
Old 12-17-2011, 07:04 AM
Mein Auto: 745i
no if you look closely, in the first picture where the wire is connected, the component (which I have no idea what it's called) is lied horizontally and connected on it's both sides, where in the second picture it is removed and connected verticaly to raise the connection. here is the link where I found this method: http://66.163.168.225/babelfish/tran...%2fM_Radio.htm
Old 12-17-2011, 07:08 AM
Mein Auto: 745i
same situation .
thank you for asking, I first thought no one is interested in this mod anymore, most people now looking into ipod retrofit, but this is the cheapest way to have aux, and yea this might help someone some day.
Old 12-28-2011, 12:21 AM
Rostman Rostman is offline
Send a message via ICQ to Rostman Send a message via Skype™ to Rostman
Mein Auto: 760i
Guys, who did this mod. Tell me please one thing: do i need to put inside some bottun to switch between radio and AUX or it switches automatically? I'm not sure if i understand right.
Old 12-28-2011, 08:56 AM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is online now
Little Odessa
Mein Auto: bmw
Old 12-28-2011, 09:06 AM
Mein Auto: 760i
Originally Posted by USALEXUSBMW750 View Post
Awesome! Thanks!
Old 12-28-2011, 12:16 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Not to be a total dumbas, but can someone please re-type the process, where is the tuner located, Under the dash, and what needs to be removed, and how does one add the extensions to the post shown in the diagram.
I would like to do this mod this weekend as my cd collection totally sucks.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 01-20-2012, 03:05 PM
dannydos's Avatar
Mein Auto: 745i
http://www.electronickits.com/remote_control/rf2.htm
So what do you guys think? I'm gonna try to use this setup to switch between fm and aux mode. I did this mod a few weeks ago (aux mod). I miss having the radio tho. My clock on the car works fine. It needs to be reset due to having to disconnect the battery.
Old 08-07-2012, 02:08 AM
BMW735 BMW735 is offline
Mein Auto: E65
I did this mod (xolmatic) also. Where did you guys solder the ground? I took the common ground on the case, but I am having a alternator whine...
Thanks for the answer.
Old 08-07-2012, 03:20 AM
Banned
Try this.....
http://www.bimmerfest.com/forums/sho...d.php?t=635227
Ace
Old 08-07-2012, 03:39 AM
Mein Auto: E65
Thanks, if I had a facelift MMI I would have done that.
But now I am stuck with the tuner mod.
Like to know where to ground best to prevent the alternator whining.
