Old 10-23-2012, 01:17 PM
VanO VanO is offline
Mein Auto: 2006 325 CI
bluetooth
Hey Guys and Gals
As you can see been a member for some time don't post often normally I find the answer by reading and searching. Here`s my problem I had my Bluetooth system working fine with I phone4 .
I installed a new battery (I even connected battery to system to help prevent power loss) last week now its not working when i try to activate the system nothing at all I checked the wiki and owners manual and fuses and all connections, other forms and Google found no help. So if anyone has a solution for this issue it would be appreciated
VanO
Old 10-23-2012, 02:26 PM
ECSTuning's Avatar
ECSTuning ECSTuning is online now
Instructor of the Stig™
VanO this may sound overly simple but have you tired to repair the phone with the car?
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 10-23-2012, 04:39 PM
Yes it will never connect tells me on the phone to make sure it close enough and continues to search never dose find the phone. I get no promp`s from the system in the car.
Thanks any other ideals? I am lost
VanO
Old 10-23-2012, 05:47 PM
dean330i dean330i is offline
Mein Auto: 330I
did you lose radio settings if so, back up didn't work also you may have to register battery, try with the car running
Old 10-23-2012, 06:32 PM
no i did not loose radio settings and I have had the car running nothing tried several times now.
Old 10-23-2012, 08:10 PM
Mein Auto: 330I
although i have an 06 it says only activate ignition once ,car not running, by going through menu on the radio press phone then bt till bt says yes then press phone again to activate it should say bt on then press again. when i got a new battery i had hard time also. try a different phone. if it does'nt say bt on in radio. your doing something wrong.
Old 10-23-2012, 08:57 PM
Dean
I think that may have worked in the past I just used the button on steering wheel to make connection ran through the radio menu as you suggested and it made connections will try more in the am thanks a lot all you guys are great Sometime these cars will drive you nuts with there odd ways but they always put a smile on your face when driving/
Vano
