Old 12-15-2011, 02:55 PM
bhoffner1 bhoffner1 is offline
Mein Auto: 1997 528i
Question Radio and Dash Lights will not go out!
1997 528i, Car is turned off, Key is out. Radio and Dash lights stay on permanently. Any idea why? Previously mentioned a possible General Module issue but dont think this is the case as no one else has seemed to have had the same problem with the radio not being able to turn off. Any Help would be much appreciated!!!!!
Old 12-15-2011, 05:27 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
You do the "failed" ignition switch test? Start car, turn on some electrical items (headlights, radio, rear elec shade, etc)...then reach over and pull down the passenger sun visor, then open the cover on the mirror. If this causes other strange electrical gremlins (steering wheel moves, horn doesn't work, interior lights come on, headlights turn off, etc)...then the issue is more than likely your ignition switch.
Q {BMW CCA Member #191509}
(SOLD)
Old 12-15-2011, 07:01 PM
Hey thanks for the reply. Tried the ignition test, none of the telltale signs. Still just the radio, and the dash and shifter lights not going out. The remote key will still not work as well. Its almost as if the car is not registering that it has been shut of/ key taken out etc. It did stop by itself for about half an hour and then the same problem came back. Any other suggestions tips much appreciated!!
Old 12-15-2011, 08:59 PM
cn90 cn90 is offline
Swap the ignition switch and report back.
Check realoem.com using your VIN.
But for 1997 528i, the PN is 61326902013 (about $70).
At 15 years old, the car will likely need a new ignition switch.
Old 12-16-2011, 10:18 AM
Awesome thanks for the info! Will switch out this weekend. Any thoughts on the potential for a general module issue?
Old 12-16-2011, 10:21 AM
Common problems are common. Ignition Switch goes dead after 12-15y/150K or so.
Gen Module lasts a looong time and is rarely an issue.
Old 10-20-2013, 08:40 PM
blomshar blomshar is offline
Mein Auto: 03 BMW X5
Did the ignition switch cure the problem?
Old 11-23-2014, 03:13 PM
gawpjus gawpjus is offline
Mein Auto: BMW e39 530D
I had a similar problem that drained my battery.
Dash lights were on continuously but found that the USB port stabbed into the cigarette lighter to power my phone was actually the problem.. I now have to pull the USB and the internal metal cigarette lighter out of it's plastic housing to turn the dash lights off.
I hope that helps others - it might just be a unique electrical gremlin just for me.
Old 11-23-2014, 05:13 PM
neun neun is offline
Mein Auto: '11 528i, '01 525i
I had something similar happen randomly over the summer. I disconnected the battery, waited a few minutes, then reconnected. Problem solved. Has never happened again.
Old 02-23-2016, 09:01 AM
cladder cladder is offline
Mein Auto: nissan skyline / x5 bmw
i have the x5 e53 i cant get the dashbord lights togo out all the lights are on inside the car dont know what else to try wished someone could help tryed to get info every where no luck
Old 02-23-2016, 10:34 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Did you just recently replace/disconnect the battery?
Old 02-23-2016, 10:53 AM
Electrcal
I replaced it with a new one
Old 02-23-2016, 11:16 AM
So, did the problem appear immediately after replacing the battery?
Old 02-23-2016, 12:31 PM
no before i was told could be battery playing up the electrics but no luck
Old 02-23-2016, 12:39 PM
been trying to get them off all night diconnect the battery leave for a hour still no luck as soon a i reconnect the complete dashboard light come on
Old 02-23-2016, 02:05 PM
ca2014mp2 ca2014mp2 is offline
Mein Auto: E39 2000 528ITA
I love this test is so esoteric.
Series E39 Vehicle code DP63 Model 528ITA Engine M52TU
Body type OTHER Catalog model USA Production date 1999 / 06
Transmission Automatic Steering Left Catalyzer YES
Production FROM : 1998/09/01 TO : 1999/08/31
Old 02-23-2016, 10:25 PM
done that nothing happens
Old 02-25-2016, 08:37 AM
found the problem hope this helps anyone else who has it
the centre consol where the phone point is the wires break in the hinge when moving it up n down the lights flickered on and off the wires in the hinge apparently break
causing a short circut on the dashboard cut the sheath & seperate the wires hope this helps someone who has the same issues drove me mad
5 series, dash lights, electrical, general module, radio
