Old 12-16-2011, 02:39 PM
RonMoor RonMoor is offline
Mein Auto: 2003 745i
Help to find refrigerant low pressure line in 745i
I need to add some refrigerant to my AC in 2003 745i. Where is low pressure line? Is the one on the 1st picture or the one on the second picture? (They are circled in red). Thank you
Name:	BMW ac port 1.jpg
ID:	305060   Click image for larger version
Name:	BMW ac port 2.jpg
Old 12-16-2011, 06:11 PM
HerbP HerbP is offline
The charging connector will only fit the correct valve. If you are using a bottle kit from an auto store, it will only fit the LP side.
Good Luck!
Old 12-16-2011, 07:08 PM
Mr_Burger's Avatar
Mr_Burger Mr_Burger is offline
2007 760Li User
Mein Auto: 2007 760Li
When I did mine, it was down the left side of the engine (as you look at it)
My 760Li - Fully Loaded
Old 12-16-2011, 10:36 PM
So it's the one on the 1st picture.. On the left from engine... But it seems too small... I cannot secure the connector it's kind of loose...
Old 12-17-2011, 12:04 AM
Mr_Burger's Avatar
2007 760Li User
As long as it snaps on to the schrader valve, it should be fine.. (It's deffinately not the hi port near the front of the car...)
