Old 05-27-2015, 11:47 AM
AlSmith1964 AlSmith1964 is offline
Mein Auto: 2002 745i
Reprogram power module so it supports 90AGM.
I'm looking for some information on an easy way to reprogram my power module so it supports 90AGM. I have a 2002 E65 and have been doing research and found this.
http://www.bmwlogicseven.com/?p=3788
This article seams to apply to my vehicle, I replaced the battery with a 90ah and need to reprogram the control module, has anyone done this and if so got any pointers on how I can possible successfully perform the reprogram? Any help will do, thanks in advance!
OLD 110ah LEAD ACID BATTERY setting:
CBS_SCEN_10H
nicht_aktiv
CC_15_EIN
wert_01
BATTERIE_KAPAZITAET
110ah
ERKENNE_SBE1_HI_RE
NEW 90AGM SETTING
BATTERIE_KAPAZITAET
90ah
ERKENNE_SBE1_HI_RE
Old 05-27-2015, 11:50 AM
hugo_za hugo_za is offline
Mein Auto: E65 740i LCI
You need to use NCSExpert, ISTA/D or ISTA/P to reprogram the car to recognize the 90ahm AGM battery.
battery replacement, dtc, dynamic drive inactive, register battery
