Old 12-17-2011, 06:18 PM
William37 William37 is offline
Mein Auto: 1998 BMW 540 I
Smile 1998 bmw z3 smog air pump
What does the Smog Emission Pump do? My pump on 1998 BMW Z3 1.9 engine, auto transmission, i was told that before long it would have to be replaced. How do you know when it needs to be replaced? Can it be rebuild or can you buy a kit for it? The cost for a new one is out of site. Any advice would be very helpful.
HAPPY HOLIDAYS
Old 12-17-2011, 09:29 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
The secondary air pump will trigger a "check engine light" when it fails. It is required for the car to meet emmissions standards. BTW I have a new one that I won't ever use that I will sell for a lot less than retail. I got it when I was going to install the Downing Supercharger since I was going to have the intake manifold off anyway. Well low and behold my 3/96 1.9 doesn't have one contrary to the ETK. PM me if interested.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 12-18-2011, 05:21 AM
1998 z3
This is a friends car but i will tell him about the air pump that you have. As for what they are worth i guess that would be the condition it is in. I would be guessing but some where between $5700.00 and $7200.00. I know the one he has is in grear condition.
Thanks for your reply
Old 12-18-2011, 07:55 AM
BK85 BK85 is offline
Mein Auto: 97 Z3 2.8
Here is a link to a DIY for the BMW air pump. It's for a 98 528 but the procedure would be similar for most air pumps. I used this procedure to replace/rebuild my 2.8 with a pump off of a newer Audi from the local PullnPay.
http://www.bimmerfest.com/forums/sho...d.php?t=402816
BK85
Old 12-18-2011, 09:15 AM
Air Pump
Thanks for the link very helpful.
Old 05-09-2013, 06:28 AM
Air pump repair.
Here is a link for how I did the repair for about $20.
http://www.bimmerfest.com/forums/sho...6&postcount=41
BK85
OOPS! Stuck this in wrong thread.
Old 05-09-2013, 07:42 AM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by William37 View Post
... Smog Emission Pump... on 1998 BMW Z3 1.9 engine... i was told that before long it would have to be replaced...
Originally Posted by FredR View Post
... I have a new one that I won't ever use... my 3/96 1.9 doesn't have one contrary to the ETK...
So not all 1.9's have an air pump? I wonder if my 10/96 1.9 has one? Will see if I can spot it.
Old 05-09-2013, 10:01 AM
Hornedfrog1969 Hornedfrog1969 is offline
What causes the Secondary Air Pump (SAP) to fail is failure of the check valve attached to the exaust manifild. If you replace the SAP without replacing the faulty check valve, the part will simply fail again over time. Otherwise the pump only runs for about a minute when the engine is cold so it should last indefinately. I pulled an SAP and check valve off of a random BMW (I don't remember what model it was) and put it on my 97 2.8L. I havent had the CEL come on since.
Rob
