Removed Visor Decals - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - 2017)
The 5 Series Gran Turismo - 535i, 550i and 550i xDrive model.
Old 12-18-2011, 11:18 AM
wchewbaka wchewbaka is offline
Mein Auto: 2012 535i GT; 1976 2002
I removed the Airbag decal from the cloth visors - even easier than I thought it would be after reading other posts. It only took a few minutes.
The visor is removed by prying off the fascia from the mount, removing the torx screw, and disconnecting the power plug.
I used 100% alcohol and soaked the decal with a paper towel - about one third of the decal area at a time. The trick is to only soak it long enough to cause it to release from the cloth. If you soak it too long it disintegrates - making it harder to remove the little pieces. I only soaked it about a minute under a weight to ensure contact and the decal can be gently pulled off without tearing.
There is currently a faint outline of where the decal used to be, but I expect it won't be as visible as the nap recovers and the foam underneath pushes up the cloth.
Not sure how regular rubbing alcohol would work - I just happened to have a 100% bottle in the garage. You also could probably remove the decal from the visor mounted in the car since the alcohol was not dripping from the towel....
HTML code is Off
