DISA Valve repair kit
For those of you that have viewed my M52-M54 engine build and swap forum you know I posted there that I was working on internal replacement parts for a cost effective and long term fix for the DISA self destruct syndrome. Here is what I posted there plus the CAD models of the new internal replacement parts.
![]() ![]() ![]() The 1st pic is of the flapper valve and lever arm that rotates the flapper valve. As you can see the end of the flapper valve has a hex shaped hole in it. The section of the lever arm just past the pointed and slotted end has what's left of a hex shape O.D.. In my opinion, the reason these fail is due to the following: > Because the 2 parts are injection molded they need draft (taper) in order to release from the mold. > Because of the draft on the ID of the hex hole and the OD of the hex section of the lever; and the allowance for manufacturing dimensional tolerances, the 2 pieces have to be made with a clearance in their fit together. > The code PA66 GF30 on the flapper valve means it's made of 30% glass filled nylon. > The code PA66 on the lever arm means it's made of just nylon, without glass fill. > Because there is clearance between the 2 parts in their assembled state, and because there are strong pressure pulses inside the intake manifold, these 2 pieces vibrate against each other during normal operation. > Once the nylon starts to wear a little, the tiny glass fibers in the flapper valve start to become exposed. Since the lever arm is plain nylon, the exposed fibers in the flapper valve start to wear it away, then it's all down hill from there. The lever arm was most likely not made with glass fill because it would eat up the sleeve bearing and seal that it rides in. I have seen this same erosion in other parts where a glass filled plastic moves or vibrates against a non-glass filled plastic. My solution will be to machine both pieces out of aluminum, then anodize them for wear resistance. They will be made in such a way that they lock solidly together once assembled, and indexed so that the flapper valve is slightly preloaded against the rubber sealing lip inside the housing when in its closed position to prevent vibration. ![]() New aluminum parts view 1. ![]() New aluminum parts view 2. ![]() New aluminum parts cutaway view showing fitment of the pieces. A few things to note about the new design: 1) The new aluminum parts will be stronger than the OEM plastic parts. 2) Since all the internal parts lock solidly together they cannot vibrate against each other and erode like the stock pieces. 3) Since a worn and freely flapping about flapper valve is the most likely cause of the internal supporting framework breaking; if a current DISA valve still has a solid internal support structure, there should be no reason for it to break in the future. 4) Since the flapper valve is screwed to the lever arm, and since the lever arm can't get pulled through it's support bushing, even if the internal support framework were to break the flapper valve would remain captive. No possibility of parts running amuck inside the engine. 5) Same concept applies to the pivot pin on top of the flapper valve; it will be screwed and thread locked to the valve. With the OEM design the stock steel pivot pin is just pushed into the plastic flapper valve and falls free in the event of failure. I hope to machine the first set within the next week. If everything goes to schedule I hope to be able to offer a repair kit in about 2 weeks. The kit will include all parts shown plus detailed instructions, a new O-ring seal and a mini tube of red thread lock. This should be a very easy DIY repair. All feedback welcome.
"I'm a little rascal on my Little Rascal" - unknown |
i think there is one guy on ebay and he was doing some similar repairs for M52-M54 DISA engine
great work, pm me when done, ill take one
Really nice work. Must be a bit slow in your shop to tie up a CNC on a project like this. Do you have an estimated cost?
Jerry
![]() 2002 530i 5 speed - 151,000 miles |
Subscribed
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
I just bought a new DISA through the group by
This looks like a better solution. Sign me up for a kit when you have them put together.Chisum |
Sorry to hijack the thread, what is the first year do the e39 start having the DISA? Or all e39 got one.
96 528i AT w/steptronic. => 97 540i w/ steptronic. |
Looks Awesome! Give me a shout when you are ready to sell them!
Very nicely done. That mod/repair would appear to make the DISA valve last the life of the car, as long as the vacuum component doesn't fail.
BMW does seem to be a little too addicted to plastic these days.
He sales o-ring's for M54 DISA and also did M54 DISA repairs for something like 40$ ( not sure about details and why he stopped to do it now ) Last edited by champaign777; 12-21-2011 at 09:09 AM. |
DISA rebuild
BikesStillRule,
I'm very interested in your rebuild kit. My daughter's has apparently gone bad on her X3 2.5. I'm not sure yet if the vacuum diaphram is bad or not, as I haven't yet pulled it. Is there a part for that as well? Please PM me when you have the kit available. I'll give it try and report back. Eric |
The DISA valve from my vehicle is the original with 120,000 miles on it, and even though the plastic bell crank lever and plastic flapper valve were completely worn out and starting to fracture, the main frame ass'y, vacuum pot, inner support bushing, outer support bushing and bell crank seal are all in perfect condition. This gives me a certain level of confidence that most used DISA's will be repairable. I'll keep everyone posted on expected shipment availability. ![]() Exploded view of rev2 design. The revision 2 design incorporates a very light weight custom titainium cap screw that both secures the assembly together and acts as the internal pivot pin. With this design everthing is secured together from outside the DISA/manifold assembly, meaning there is nothing to fall into the intake manifold that's small enough to make it to the engine, even if the main screw were to loosen and fall out. ![]() Transparent view of rev2 design.
I am interested...
DISA valve
Will your kit work with an '04 X3 2.5? I checked and the part # for the E39 is one number off, 805 vs 806.
Eric |
The version I'm currently working on is the 3.0 liter version. As soon as I can I will try to get my hands on the other version and see what the internal differences are.
Do you have those DISA flaps for sale yet ? I need one for my 02 530i got fault codes telling me its faulty
Props to you BikesStillRule!!!!
I will post your efforts on the other board too, I am certain there are people interested in this. If you will start "mass"-producing the kit, at least let's increase the audience.... P.S.: I posted it on the other board here.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby Last edited by doru; 01-04-2012 at 08:07 AM. |
Saw doru's post over on bimmerforums, I'm definitely interested. I've got 142K miles on mine, I haven't checked it, but I am planning on doing all the gaskets in that area in the next week or two, so I'd love to refresh my DISA if I already have it taken out. I'd be willing to be a beta reviewer if you still need one.
Just finished the final revision tool path programming last night. I have the o-rings, Locktite and grease packets in stock and I plan on running about 10 sets of parts over the weekend. The only delay at this point is I'm still trying to source the titanium cap screws. For the people who are in a hurry I might have to ship the first kits with a stainless steel screw.
On another positive note; I just purchased a brand new unit from BMW with the new superceded part number and everything is a perfect fit on that unit too. In fact I can't see any differences between the original production units and the new superceded part number units. Quote:
Im interested. I will be watching this thread.
Awesome, very awesome :-)
You'll be doing good deals on international postage I hope!
-- Carl |
#25
Count me in too!
BMW '00 740il w/196,xxx miles (his), DIY timing guides complete! M60 Manifold, BDC Throttle Body, Muffler delete BMW '02 530iA w/140,xxx miles (hers) BMW '09 R1200GS Adventure w/13,6XX Smiles
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
