#26
Registered to subscribe to this thread, we did a temporary repair on a broken DISA valve on his 330Ci yesterday (involving a self tapping screw and some glue) which fixed the P0171 and P0174 system too lean codes immediately.
As @BikesStillRule noted, our unit was in perfect condition apart from the nylon part which fits in the bottom of the flap which had sheared completely of which a worrying amount was missing.. This looks like a much better option than stumping up for a whole replacement unit that could just fail again. I'm in the UK too so would definitely be interested in a kit if/when you can produce them. |
#27
I'm keen to get on this too!!
Is there a downside to the steel pin/bolt versus the titanium, if the titanium is going to be a hold up? My DISA is clean and working but there is a small amount of play evident in the mechanism/flap, from what I remember.
-- Carl |
#28
Feedback.... Not so sure your solution is a good one. (note I stated not sure) first off, clearly the system works of resonance which will result in vibration on the flapper valve. The materials (and weight) your using are different than the materials used by BMW. Could be a good thing, or could be a very bad thing resulting in destructive vibration that tears the unit apart. Second, I believe the bearing point of the pin holding the valve is the valve itself. Yours is using the DISA body assembly as the bearing point. This may result in excessive wear of this area as it may have never been designed to function as a bearing point. Note I have stated "could", "may". I do not have any evidence that any of these issues could be a problem. This aside, kudos to your engineering and prototyping of this. Quite cool!!
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
#29
we can always have some pioneers which can buy and use this staff
then we will have a real Feedback subscribed Last edited by champaign777; 01-08-2012 at 09:46 AM. |
#30
I will be a test pilot.
As far as I am concerned, BMW are totally inept with material choices (rubbers, composites and plastics that fail), so I would gladly follow this man's ideas with more faith.
-- Carl Last edited by carl0s; 01-08-2012 at 11:24 AM. |
#31
Hmmm.
-- Carl |
#32
1) With regard to bearing pivot point, the stock unit has a steel pin pressed into the flapper valve and the body has a pressed in PTFE or moly coated bearing supporting the pin. The pin rotates within the body, not the flapper valve, and my design does not change that. 2) I agree that the new ass'y will be heavier. That is the reason for going with a much more expensive custom 'titanium' pivot screw (The CAD pictures you referenced here are the Rev 1 not Rev 2 pictures that were posted later). Another point to note is that the stock steel pin is 4mm (.157") in diameter, and the bearing I.D. is 4.37mm (.172"), leaving a pin to bearing clearance of .015". My design reduces that clearance to .002"-.003", which drastically reduces room for vibration between the pivot and bearing. I have checked 2 used (8 years old) and 1 brand new unit and the bearing I.D. is consistent, so I feel comfortable closing up this clearance. 3) The valve spends 90% of it's life in the closed state (low to mid RPM part throttle driving) where the flapper is fully seated against the silicone seal molded into the DISA frame work. In it's closed position all vibrations of the flapper will be damped. 4) The DISA ass'y has a molded in silicone seal around the perimeter of the frame work which dampens vibrations transmitted into it by the valve to the larger mass of the intake manifold. 5) I have a bunch of electronic test equipment here and we plan on testing the ass'y to see if it has any strong resonances that fall within frequencies generated by the motor (2000-6000rpm = 100-300 Hz). I've spent a considerable amount of time trying to anticipate all failure modes and have had the design reviewed by another engineer. That being said, if anyone sees any other potential problems, please post them for consideration before this goes into production. Thanks again to everyone who is supporting this project.
"I'm a little rascal on my Little Rascal" - unknown |
#33
subscribed
And they say Americans have become fat, stupid, and lazy. |
#34
Anyway, I am totally supporting your project. I don't think the DISA with the improved flapper will destroy itself. The vibration might be an issue, but your design (i think) is fixing it, because of the material and the gap mitigation. I know only a bit about vibration, but enough to state that it's a major pain in my work environment (oil & gas wells drilling). Downhole vibrations kill very robust tools made out of some very exotic steels. The original flapper does not fail due to vibration (in my opinion) but merely due to the material incompatibility which in turn will fail after so many cycles. The DISA fails due to cheap parts made to last as long as the car is under manufacturer warranty. Just like too many parts - CCV comes to mind, or cooling to mention the heavy hitters. Cup holders are just an annoyance.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
#35
![]() Unfortunately ... ![]() The CCV soooo needs to be re-designed, or deleted...!
#36
Basically Have a hose from the Valve cover just how the OEM design is, that hose attaches to a PCV valve. From the PCV valve, another hose into a catch can (there are some nice and expensive models on the web). The catch can then releases the oil into the dipstick and the gases back into the intake manifold - the OEM has 2 lines. Not sure if you would need 2 lines with the "home-made" design? With this method, all your CCV maintenance would be the normal PCV change every 30 k miles or for 5 bux. I would also place the PCV valve at the top somewhere, where you could change it in 2-3 minutes. If this "home-method" could work. Deleting the CCV/PCV is not a good idea.
#37
Then, cap the drain pipe that connects to the dipstick, or find another dipstick tube that does not have that drain pipe incorporated in the dipstick tube base (540i/M5 dipstick tube?)... Hence, replacing the PCV would be old-school maintenance, as it should, not over-engineered, and designed to fail (what emissions...?)...
#38
#39
Maybe there are some forum members close to you that wouldn't mind spending a few Hrs/week for a good cause?
#40
I'll keep my eyes open for this one, too.
"The wise speak of only what they know." |
#41
I'm very interested in this proposal. However, what will be done to incorporate a seal between the two components or did I miss that part?
#42
I've had several people PM me on when this kit will be available, so here is an update for everyone.
Six sets of the machined parts (now rev-3) should be ready by the end of the week. I'm working on the last of the fixturing tonight. The ETA on the custom titanium screws is mid February. I still need to make detailed instructions with good step by step pictures. Vibration testing (checking for any destructive resonances) will happen as soon as the Ti screws arrive. A realistic date for a fully vibration tested kit with detailed instructions ready to ship is the end of February. I would be willing to send out some kits with stainless steel versions of the screw and written instructions under the understanding that no vibration testing will have been performed on that combo. ETA for a stainless screw and written instruction kit is around the first of next week if everything goes to plan. I'm working on this mostly nights and weekends so it slows the process a bit. Thanks everyone.
#43
The tapered mating surfaces on both pieces are precision machined and should form an air tight seal on their own. As an added precaution the instructions will state to apply a very light film of the supplied threadlocking agent with a cotton swab to the I.D. of the flapper valve hex mating surface. The threadlock is not required to hold anything together but is used because it will wick into any possible voids between the mating of the two surfaces during assembly. The screw threads are also threadlocked during assembly which seals that area as well. I hope I understood and answered your question correctly.
#44
BikesStillRules, you're a good man.
#45
#46
-Cost -the DISA will last 100k miles. Until the car is out of warranty
#47
I will be VERY interesting in this! I am on my 3rd CCV....! I almost bought a 4th...! Tired of this sh!t! Sorry for these common problems/ questions keeping you from your M54 re-build. Thank you MUCH! Jason
#49
Well ima need me one a soon as there available
#50
That's pretty darn awesome and impressive...
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
