Old 12-19-2011, 08:21 AM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
Trunk won't open
All of a sudden my trunk won't open unless I "help" it with my hand as I push any of the three buttons. And before anyone asks, no the lockout switch in the console is not on.
It's almost as though the extra "oomph" of the switch/solenoid/? isn't there to set the trunk in motion. When I just give a gentle nudge after pressing a button, the trunk opens all the way up on it's own and stays there. Otherwise, it just starts to open (1/8") and then closes again. Nothing jamming the mechanisms either.
Old 12-19-2011, 08:25 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Might be low on hydraulic fluid. There is a thread somewhere on here about this issue.
Old 12-19-2011, 09:01 AM
roadfrog's Avatar
Hmmm....worthy of a look. I know the reservoir is in the trunk pass side well. I'll check it out. I just figured since the trunk is opening, and holding that the fluid would be ok.
Old 12-19-2011, 11:13 AM
DFEL750I's Avatar
Mein Auto: 750I
The physics of this would suggest that the most hydraulic pressure is needed to lift the trunk when the trunk lid is parallel to the ground. I would expect that if the fluid was low that what you are experiencing should be the first sign of a problem. Definitely worth a check.
Old 12-19-2011, 12:08 PM
benn81 benn81 is offline
BEAMERBOI
Mein Auto: 2002 BMW LI
What is the lockout swtich because I am now having the same problem for trunk my remote dont work and neither does the button on front console I thought it was a fuse.
Old 12-19-2011, 12:14 PM
N62b44 N62b44 is offline
Account Under Review
Mein Auto: M3e46
Had the same issue:
Your hydraulic is ok level.
Replace two spring struts asap, bc it will eventually kill you hydraulic shock
Old 12-19-2011, 02:09 PM
DFEL750I's Avatar
Mein Auto: 750I
Open your center console and you will see a switch in there next to the cd holder.
Old 12-19-2011, 03:04 PM
BEAMERBOI
