Old 12-21-2011, 12:07 AM
E39 touring E39 touring is offline
Mein Auto: BMW e39
What did you do on your e39 recently?
Thought maybe this is a good post to start just to gauge what falls apart on these cars
98 523i touring 207,064kms
In the last week or so;
Replaced sparkplugs - Bosch 4 prong -$105NZD
CVV genuine BMW -$177NZD
Hoses for CVV made my own $10NZD - top hose to order genuine from Autohaus
Oil filter and Shell Helix 15/40W oil - $52NZD
Fronts disks resurfaced to well within spec - $75NZD
Cleaned and polished headlight lenses - elbow grease.
Fixed leak @ power steering hose - elbow grease.
Cleaned K&N - elbow grease
Fixed sticking hood latch - elbow grease
Ran car through 6 month inspection - $43NZD
All is good with the E39.
Old 12-21-2011, 12:42 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
New grommet on windscreen washer pump - leaking.
New wiper blade inserts - dealer only. Aftermarket NFG.
Set of sisal mats from CoCoMats. Perfect fit, good-looking. They have a Velcro-style patch that mates with BMW Velcro buttons to anchor the mats, and prevent sliding.
Old 12-21-2011, 01:13 AM
blz456's Avatar
blz456 blz456 is offline
Mein Auto: 2000 528i
Replaced my leaking VCG with an OEM one because the aftermarket one I put on after doing the vanos in July still leaked (should've listened to you cn90)
Replaced air filter
Changed oil and oil filter
New spark plugs (OEM NGK)
New timing chain tensioner
New brake fluid
New tensioners and idler pulley
New vanos oil supply hose
2000 528i steptronic
Blacked out
Old 12-21-2011, 05:39 AM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
fixed my 'leaky' VCG...or so i thought it was......turned out to be the vlv cover having a hairline crack.fixed with a 2 part epoxy and seem to be holding well to date.
http://www.bimmerfest.com/forums/sho...d.php?t=588321
Old 12-21-2011, 06:10 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
New lemmy tie rods and swaybar endlinks along with an alignment. Steering is tight like little sisters and no more clunking/knocking!
Old 12-21-2011, 07:06 AM
Infamous039's Avatar
Infamous039 Infamous039 is offline
Infamous039
Send a message via AIM to Infamous039
Mein Auto: 2006 750i
Things I have done within the last month
1. Put my Staggared 3-Piece Vellano Wheels on and Rolled rear fenders to take the 275/30/20 rear tires.
2. Changed front and rear brakes/rotors
3. Washed it up nice
I still need to replace one of the rear parking sensors that is not longer working.
2008 BMW 528i
Fully Loaded
2000 Chrysler Voyager (Green Mini-V)
Manual Roll-Up Windows
Manual Seat Adjustments
1-Hub Cap
Old 12-21-2011, 07:42 AM
matt540's Avatar
matt540 matt540 is offline
Mein Auto: 2000 DINAN 540, 1983 745
Dinan free flow exhaust, and soon she will be wearing some 18 inch style 5's.
2000 Dinan 540 Dinan F&R strut tower brace, M5 F&R sway bars, Koni Sports, Eibach springs, Powerflex polyurethane bushings, Dinan stage 2 engine software, Stage 1 trans software, Zionsville cooling kit, resonator delete, Dinan exhaust, Dinan TB, AFE cai, 18" style 5's, 235/40/18 275/35/18, Ultimate cup holders, rear cup holder delete/coin holder, Hella taillights, clear sides, Depo AE, M5 spoiler
1983 745 turbo, style 138 wheels
Old 12-21-2011, 07:57 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Too many things to mention. Just maintain and drive it.
Old 12-21-2011, 08:09 AM
BentValve's Avatar
Hell yes.
Old 12-21-2011, 10:01 AM
matt540's Avatar
Next weekend I will be doing the valve cover gaskets.
Old 12-21-2011, 10:11 AM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
nothing for 2 E39
Old 12-21-2011, 10:17 AM
blackandcoke's Avatar
blackandcoke blackandcoke is offline
New York
Mein Auto: 528IA
Just picked up a set of BBS RS GT 18"S waiting for April to arrive.
Old 12-21-2011, 10:25 AM
Ed Cheung Ed Cheung is offline
Mein Auto: E39
Geeee, you guys are good, all I had done is a "to do list for year 2012" and here are the items on the list....those fixed cost more than my car, LOL.
Vano seal+valve cover gaskets,
replace all shocks and control arms,
tires,
Fix the leaking washer fluid bottle
twisted seat, it is the passenger seat, so this will be on the list for a while
Get the extra key
Fix the remote lock issue,
replace PS fluid, and check why the PS pump is puking PS fluid once in a while
And sort out the issue with the "missing" coolant level thing in the coolant expansion tank
96 528i AT w/steptronic. => 97 540i w/ steptronic. =>steptronic deleted, 6MT installed.
Old 12-21-2011, 12:31 PM
NZ BMW NZ BMW is offline
Mein Auto: 2001 530i
I'll play:
@125,000km's
Front brake job: NZ$450
Swaybar links: NZ $200
Thrust arms: NZ$350
New fuel cap: NZ$47
New Cam sensor: NZ$350
Service: NZ$350
Wheel alignment: NZ$150
Repair rear blind slides: $NZ100
Did about 6 months ago: radiator - forgot costs.
Replace entire aux fan and shroud after it CAUGHT FIRE $NZ 1200
On my list:
Fuel Filter
Transmission service
Front window seal (just starting to see some cracks)
Rear brakes - interestingly my shop is against machining them...
Old 12-21-2011, 12:40 PM
menhir's Avatar
menhir menhir is offline
Float On
Mein Auto: Not a Bimmer
Most recent:
New OEM brake lines and fluid
2nd new expansion tank and temp sensor in 20K miles!
2nd new lower left control arm (ball joint AND bushing crapped out after 20K miles)
"The wise speak of only what they know."
Old 12-24-2011, 02:12 AM
LalaRay's Avatar
LalaRay LalaRay is offline
Boosted
Mein Auto: 03 ///M5
new center link
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower
Supersprint Headers,
Evolve Alpha N Tune,
CNS lightweight dm flywheel/Spec clutch,
ST coilovers,
Eibach Rear Sway bar/Beast Power Brackets,
Drilled slotted Rotors/Akebono Euro pads,
Magnaflow 14816 Mufflers
_____________________________
Old 12-24-2011, 05:09 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Replaced all of the speakers with Boston Acoustic SC50's.
Bought a JL Audio amp, haven't installed it yet.
Forgot, last week I changed the oil and filter to 0w-40 Mobil 1 from BMW 5w-30
Old 12-24-2011, 07:56 AM
bobbydacrab bobbydacrab is offline
Mein Auto: 1999 528i 190k
Changed: oil/filter, trans, diff, PS. New shifter. New fuel filter. F&R Zimmerman coated rotors and Akebono Euro pads. New wiper inserts. Headlight bulbs (2). Put the snows on.
Coming up: CDV delete, bleed the brake and clutch systems.
99 528i, 5 speed, sport/premium, 188k (8/2011)
Old 12-24-2011, 09:23 AM
mda419 mda419 is offline
Mein Auto: 1997 528i
VANOS (Seals/Solenoid/Rattle Kit), Alternator, Timing Chain Tensioner, Fuel Filter, Air Filters (Cabin/Engine), Spark Plugs, Emission Control Gasket, MAF Sensor cleaned, TB cleaned.
Allelujah, she came back to life and resurrected !!!
Old 12-24-2011, 09:45 AM
riro424 riro424 is offline
Mein Auto: 2003 525i
At 85,000 miles...
  1. DISA ('Fest group buy)
  2. CCV (hoses very brittle but no mayo)
  3. OFH gasket, TB gasket, PF housing hose/clamps, misc washers, chain tensioner, and drive belts (and cleaned crap out of alternator)
  4. Drain and refill ATF, oil/filter change, air filter change, clean cabin filter housing drain holes
  5. New Conti DSW tires and Hunter Hawk alignment
  6. Mounted winter wheel/tires (Pirelli 210 Snowsport)
Running and shifting smoothly, with all the annoying leaks and squeals gone.
Old 12-24-2011, 09:47 AM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Last few months... or last 500 miles.
1. Repaired Cluster needles via VDO repair
2. Replaced cluster trim piece
3. Oil + filter change
4. New Battery
5. OEM Aux input...worth every penny.
Soon-
1. Dr colorchip
2. Revamped stereo
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 12-24-2011, 12:40 PM
EddieNYC's Avatar
EddieNYC EddieNYC is offline
-Eddie
Send a message via AIM to EddieNYC
Car wash.
Old 12-24-2011, 11:21 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
Originally Posted by mda419 View Post
VANOS (Seals/Solenoid/Rattle Kit), Alternator, Timing Chain Tensioner, Fuel Filter, Air Filters (Cabin/Engine), Spark Plugs, Emission Control Gasket, MAF Sensor cleaned, TB cleaned. !!!
Why did you change these:
Timing Chain Tensioner?
What is the TB?
Are each an easy DIY?
Did you need to lift the car to do the fuel filter?
Old 12-25-2011, 05:10 AM
MotorMark MotorMark is offline
Mein Auto: '01 530i
Picked mine up from the body shop last week. It lived there for 9 weeks, being brought back to life from the crazy hail storm back in April. I have named him Lazarus. Looks as good or better than the pic below.
[SIGPIC][SIGPIC]
Old 12-26-2011, 02:06 AM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
9 weeks i dont know how you did it
ST coilovers,
