#26
Just got the ABS sensor repaired.
Also did O2 sensors. Both at 120k. Next up, fuel filter! |
#27
1 new radiator
2 new abs module 3 got hit behind drivers side rear door 4 snow tires on my old rims 5 removed all cup holders 6 installed led lights underneath the outside door handle 7 oil change 8 replaced 99% of all lights with led soonish.... 1 sway bars front and rear 2 m5 style mirrors 3 exhaust 4 suspension 5 possibly get CAI 6 sports ecu |
#28
VCG's + Plugs = Royal PITA (VCGS, not plugs)
Since aquiring my 530 a few months ago @122k km:
Thermostat, waterpump, oil filter housing gasket, VCG, power steer hose clamps, general service - NZ$1300. Fixed right rear door vapour barrier - $0. Replaced right front underskirt thingy (with temp sensor in it) - $330. Replaced cabin filters - $110. Solved "gym sock pong" with mould killer $15. Experimented with LED AE's - looked stupid... $70. Reverted to stock halo's. Adjusted park brake - as good as it will get... $0. Euro shaped plates - a huge rip off... The ABS module had just been replaced by previous owner, as had the tyres and spark plugs. To do: Transmission fluid replace. (no issues though) Repaint of front end, polish headlights. Check out suspension components (no issues though)
Cheers Stuart NZ |
#30
Depo smoked sidemarkers.
#31
I put gas in my bimmer a few days ago.
1997 BMW 528ia l Bilstein sport struts l H&R springs l smoked LED tail lights l smoked headlight lenses l smoked side markers l M5 trunk spoiler l 17" TRM rims l *custom IPod ashtray dock* l black chrome kiney grille |
#32
In the past few months:
1) Replaced CCV and hoses. 2) Replaced plugs. 3) A/C Final Stage Resistor (twice) 4) Replaced blower motor (discovered initial FSR was defective - motor still good). 5) Replaced flex disc. 6) Replaced Front brake pads and rotors. 7) Replaced ignition coil & new plugs. 8) Replaced Cam Shaft Position Sensor. 9) Oil & Filter Change. 10) Transmission Filter & Fluid w/ pan gasket. 11) Replaced broken drivers side outside door handle. 12) Replaced driver door window regulator - broke again. 13) Repaired trunk lid latch. 14) Repaired frayed wires at trunk lid. 15) Repaired leaky power steering hoses & cleaned PS reservoir. 16) Replaced leaky air pump hose. 17) Replaced serpentine belt & broken tensioner. Need to do: 1) Repair sunroof. 2) Get new tires. 3) Air pump replacement (whines in the AM) 4) Fix broken switch to driver's side seat. 5) Fix both driver's side window regulators (need to replace gear in motor this time). 6) Would like to fix dent in hood and rear passenger door. 7) Go through suspension and repair as necessary. 8) Find source of leak near rear gear box and repair.
I just love this logo... |
#33
Oh yeah. I also replaced the fuel filter and the front cup holder.
Add to needs list: 9) decent floor mats. 10) replace rear A/C vent & cup holder. 11) fix windshield wipers (come to rest in middle of windshield). 12) replace front windshield rubber trim (looks like crap). 13) get a replacement center cap that is missing. If you took mine, please return it no questions asked...:-)
#34
Since August 2010 I've had the tranny rebuilt, installed new shocks and replaced the windshield wiper cowl. I still have a plethora of items to tend to.
![]() "The more you know, the more you don't know," Dave Chappelle ![]() "Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content"-Durant WTT: Black Comfort Seats for Black Sport Seats. PM for info. |
#35
'03 525iT 130K miles
Installed 6 NGK 3199 spark plugs. Easy to do thanks to all the info here. Replaced one high beam bulb (H7) Added a quart of Mobil 1. Still need to do: Change ignition coil(s) if misfires continue. Check fuel filter... Change thermostat Diagnosis why DSC light is always on. Constantly check on radiator. So far so good. Change out cracked windshield Repair tailgate struts, 2x4 is working fine though. |
#36
More done
Repaired rh side rear window drive,easy but a bit of time involved.
Adjusted lh side door handle,new cable on order. To do; Fuel tank level sensor (this will be third time) ![]() ![]() Get A/C tested @ friends company |
#37
Just today: valve cover gasket:
Today:
Replaced MAF sensor ($150) Replaced Hood Emblem ($30) Replaced Wipers ($35) Replaced Power Steering Reservoir O-ring ($1.50) Put on snow tires! ($400 used OEM wheels, $200 used snow tires, $42 mounting) Last edited by EconoBox; 01-07-2012 at 04:52 PM. |
#39
I would die without my car for 9 weeks -_-
Stuff I've done -New waterpump -0w30 Oilchange w/oem filter -New NGK Platinum x6 -New Bremi Sparkplug connector boots x6 -New Upper / Lower Intake boots -Cleaned MAF Stuff I need to do... -VANOS via Dr. Vanos -Bilstien shocks / struts -Change Fuel Filter (any suggestions as to good brands??? was thinking Mahle but dont know if it's any good...) -Dremel surface rust away, repaint with code 354 titanium silver -Oil spray (the snow's a comin gents) -Swap to winter tires -New hingless wiper blades.... |
#40
Spent a bit lately ,some work done by myself but most done by a local Hungarian guy (good man) and he has a hoist;
Middle control arms rear suspension, Front disk pads and sensor, New front engine belt (the long one) and idler, Front swaybar links, Front cup holder, interior door handle, 2 x rear tyres 235/45/17 Relacement intank pump and level sensor. To do: Oil filter change Fix lh side front seat surround plastic trim (again) This is the first real expediture on the car @ around 246,000kms so I'am pretty happy with it . |
#41
in the past couple of weeks...
MID pixels repaired new windshield and weather trim rear hd bilsteins fabric glue on interior pillars that were sagging canceled transmission drain at 170k hopefully i can just rebuild it correctly one day considering removing tints and installing ddm HID fog lights. Wheel bearings, ccv and front meyle hd sway bar links on deck. |
#42
Bosch plat 4 plugs
OS11 sensor Hood Bowden cable Center brake light |
#43
yellow fog light housings installed and took off HID kit. i had yellow lamin-x on my old housings but didn't like the look since you could still see some of the clear on the edges. as for the removal of HID...i could never get 3000k bulbs to look quite right (morimoto 3000k bulbs looked too green even with yellow film), it was interfering with my ambient temperature sensor somehow, and i keep reading about how HID fog lights actually make visibility in heavy fog WORSE. plus i don't like blinding other drivers. the new fogs look AWESOME and i'm just using the regular bulbs that came with them. no need to put in my yellow nokyas
edit: forgot to mention i have a leaking heater hose on the passenger side near the firewall, luckily it only leaks when the heater is on since my control valve is fine. and the day after that happened, my hood release cable broke. excellent timing. today i took the handle off and took apart my lower dash, but the cable was so messed up i couldn't pull it with pliers. then i tried the method through the kidney grill and the junction box is so dried up i couldn't get it to budge. i don't have a new cable yet so i'll wait for that to come in and then replace it. then i'll lube everything up so nothing else brakes. so guys...KEEP YOUR HOOD RELEASE CABLE LUBED PROPERLY
1999 BMW 540i/6 - Eibach ProKit - E60 SSK - ZHP knob - DJ Autos/FX-Rs/Orion V2s - HID Fogs - M5 front bumper - Scuba tank delete ![]() Last edited by salesman; 11-08-2012 at 10:32 PM. |
#44
I did the Mtech front and rear bumper upgrade. With AC SHCNITZER rear roof wing, M5 rear spoiler, AC Schnitzer front spoilers, Sink drain front air scoops, AE's (and had to make my own wiring) . Even managed to paint the roof top gloss black. Next up is to start cutting up my trunk.
#45
Installed CCFL angel eyes on my touring today.
![]() Touring the nation, one state at a time |
#46
2001 540I/6 M-Sport
95K Miles 10/2012: Valley Pan Job Rear Intake Manifold Front Intake Gasket Replaced Air Filter This Weekend: Replace Spark Plugs; It already had NGK 3199 but they were all burnt. Replacing with NGK 3199. Valve Cover Cover Gasket (probably just do Bank 2); Diagnose cause of idle fluctuation (build smoke machine). Last edited by Sumotide17; 11-08-2012 at 10:29 PM. |
#47
I got my touring last month and I've done a lot so far, but still have a lot to do.
Done: radiator water pump expansion tank, cap, and brass bleeder screw from OEMbimmerparts upper & lower rad hoses with temp sensor valve cover gasket oil filter housing gasket fuel filter BMW all-weather mats replaced broken cupholder, will not use it, but I hate broken things differential oil engine oil & filter air filter cabin air filters attempted alignment (one front tie rod seized) replaced cargo are battery hatch (originally one had broken latch) removed 17" Style 5 wheels, replaced with 16" Style 82 replaced passenger seatbelt tensioner (airbag light) secondary air pump valve and vacuum line replaced (CEL) both front door seals reprogrammed car-key memory for DRLs and drive-away locking Still to do: front suspension rebuild (control arms, thrust arms, tie rods, end links - fine for now, but grease boots are split open) rear subframe bushings crankcase vent valve and hoses VANOS rebuild (although I think it's OK for now) DISA rebuild angel eye LED bulbs (just the bulbs, not the whole ring) tires retrofit heated steering wheel (maybe for next winter - more pressing issues right now) lower engine shield and front fender liners (cracked, but functional for now) |
#48
Done:
Oil change - 0W40 Mobil 1 New intake filter - AFE oiled Cleaned MAF - CRC MAF Spray Added rear decklid spoiler Brake fluid change NEW KEY - YAY! Dusted it off today since I won't be taking it out of the garage. DAMN YOU SNOW! ![]() Ordered new AE LED bulbs Future jobs: Cut scuba tanks, replace with downturn. Front thrust arm bushings valve cover gaskets and seal washers camshaft solenoid gasket M62TU VANOS seal rebuild from Beisan Systems Timing chain guide replacement. Valley pan gasket replacement. M-Tech bumper conversions |
#49
I "Glossified" the kidney grills. They were already flat black, but in order to utilize Plast-Dip's Glossifier, you need to have a base consisting of something Plasti-Dip'd. After five or six coats of the Glossfier though, I wasn't getting the glossy look I wanted so I let it dry overnight and this morning added a couple of coats of Duplicolor clear coat on top of the Glossifier layers. The end result is pleasing:
#50
2000 540/6 with 130,000 on the clock.
Past Month 1. New Radiator with fresh fluid 2. Both belts replaced (removed belts in trunk for backup) 3. New gas cap 4. 3M Headlight Restoration Kit 5. Clean Oil Past 4 Month 1. New tire (90 mph blowout!) 2. Sway bars 3. Control arms 4. Really just the entire front end, had my indie do it 5. New shift knob Need to Do ASAP! 1. VCG/VANOS (smell oil burn daily!) 2. 4 new tires all around (235/255) 3. Fix interior trim pieces 4. Rear bumper re-paint 5. Alignment 6. Rear window regulators 7. Spark Plugs 8. Tranny fluid flush 9. I am sure there is more!
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
