brake sensor light FIXED - Bimmerfest - BMW Forums
Old 12-21-2011, 10:12 AM
bmw5683 bmw5683 is offline
Mein Auto: 1998 bmw 5281
HELP!! recently changed rotors, pads, and sensors on the rear only and the (o) light wont go away. work was done by a shop, front brakes not worked on. when should the light go away? thanks
Old 12-21-2011, 10:51 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
You might find this thread helpful. Read Q'Silvers post, #4.
BMW--giving new meaning to the phrase "disposable income."
Old 12-21-2011, 12:18 PM
thanks i will try that tonite!
Old 12-21-2011, 12:57 PM
Do us a favor and post the outcome.
Old 12-21-2011, 08:10 PM
just tried to reset brake sensor light with the help of all the posts with no luck! i will be taking it back where i had the work done, it has to be a bad sensor or installed wrong! will post outcome
Old 12-21-2011, 08:14 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Did you check that there's a sensor back there? (And that it's not the old one....)
Old 12-21-2011, 08:21 PM
i was charged for new sensors on the invoice taking it back to have it checked
Old 12-21-2011, 08:28 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Position 2 for 30+ seconds didn't work?
If that doesn't work maybe they didn't put in a new sensors or they lost the little metal clip in the sensor.
Old 12-21-2011, 09:16 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Just for grins & giggles...try turning the ignition to POSITION 1 for 30 seconds instead of position 2.
Q {BMW CCA Member #191509}
(SOLD)
Old 12-21-2011, 09:22 PM
i tried that also the darn light is still on thanks guys
Old 12-22-2011, 09:18 AM
vclifford vclifford is offline
Mein Auto: 530i
Try this , I think this worked for me
1. Position 1 for 30-35 seconds then
2. Position 2 for 20-30 seconds. for me it went away at the point
So when I started it went away normally
Regards,
Old 12-22-2011, 11:58 AM
Trebbia's Avatar
Trebbia Trebbia is offline
Mein Auto: BMW E39 I6
If all else fails short the sensor wires.
Old 12-22-2011, 12:42 PM
tried all posts no luck gotta be the sensors will see next week
Old 12-22-2011, 12:44 PM
thanks for posts i'll short out to know more
Old 01-10-2012, 11:08 AM
found that the front driver side sensor had cracked plastic connector and was taped. made secure connection, retaped, ignition in pos. wait 30 seconds key out them start no more light.thanks guys
Old 01-10-2012, 11:58 AM
Thanks for the update. That kind of coincidence (front sensor going out after the rear was worked on) makes diagnosis difficult.
brakes, brakes light, sensor
