Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 12-21-2011, 02:23 PM
BMC New York BMC New York is offline
Mein Auto: 1979 320i, Harley!!
New here with 320i issues
Have a 1979 320i that will start after about 20 cranks, but will no rev up past 1800/2000 RPM, have had the car since may and when it runs its a great little car, has always been a pain starting, but now since i replaced the fuel line from the filter to the tank has lack of power and wont rev up, have changed both fuel pumps and the filter. Would be greatful for any advise or help, also looking for a proportioning valve for this car, it is leaking from the canister, thanks agaiin BMC New York
Old 04-24-2012, 12:39 PM
Jetset83 Jetset83 is offline
Mein Auto: BMW 320i (e21), Infiniti
Plugs fouled?
Old 06-13-2012, 07:16 PM
Flotsam's Avatar
Flotsam Flotsam is offline
New to this board
Mein Auto: 1995 BMW 325i
Its been a long time since i had my E21, but I am thinking you need to check your dwell angle on your points (do you still have points on yours?) and then your timing on your distributor.
Old 08-15-2012, 06:42 PM
Xerxes Xerxes is offline
Mein Auto: 81 323i and 93 525i
I'd check your fuel pressure at the top, it's possible debris entered the fuel system and is restricting flow. It is also possible to have gotten a bad fuel pump, I've purchased a new fuel pump that did not work, it took me days to figure it out, but sometimes they don't work. If the pump is good but you have low fuel pressure replace the filter again and run compressed air backwards through the lines. Do this in as many small sections as possible, anywhere that you can open the fuel system to the next point, pay close attention to rubber to steel connections as the rubber hose is larger and the steel line makes a bottleneck.
Old 08-22-2012, 10:28 PM
colinb123 colinb123 is offline
Mein Auto: 1978 320i
we had the same issue with a boat i just bought. something was plugging the fuel system so it had a hard time starting. try checking every inch of your fuel system for any bockage
Old 09-15-2012, 02:18 PM
BMWFatherFigure's Avatar
Old School
Also sounds like the starting jet is blocked/defective/disconected
Current:
Previous:
