Old 12-24-2011, 04:55 PM
Mike_Junior's Avatar
Mike_Junior Mike_Junior is offline
540i Guy
Mein Auto: 98 540i/6
Coolant Leak and smoking!! (*Needs Help*)
So this morning getting ready to go to work I was expecting to have a wonderful christmas eve enjoying the cruise in my e39, once I crank her up everything seemed fine so before heading to work I take a trip to the gas station to get me a drink, so after that I venture on to my job enjoying the cruise in my e39...once I arrived I enter the parking and all of a sudden I see alot of smoke coming out the hood of my car I looked at the temp gauge and it wasnt overheating, so I quickly park my car.. I pop the hood and I see smoke coming out of the front passenger side of my car where the air filter is I also seen coolant splashed everywhere, I looked under car and it was pouring antifreeze right underneath the front passenger side of my car..what could be the problem?? HELP
PS: Once I got off work I experienced the same thing it began smoking under the hood of my car (right passenger side) and it would leak antifreeze real bad
Old 12-24-2011, 06:40 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Radiator or hose must be leaking.
Old 12-24-2011, 06:45 PM
540i Guy
is it expensive to repair??
Old 12-24-2011, 09:05 PM
1BadE39 1BadE39 is offline
Mein Auto: 1997 540i
passenger side no visible breakage from the top could be lower rad hose or bottom of expansion tank. Figures my 540 blessed me as well with a busted upper rad outlet coupling this week. Lower hose is 17 on autohausaz good luck.
Old 12-24-2011, 10:24 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
Check your two heater hoses in the back manifold to heater core:
Hose F Engine Inlet & Water Valve 64218391005
Hose F Radiator & Engine Return 64218391013
Those are usually the first to develop leaks and are located between the two cabin filters.
For peace of mind, while you are at it, replace all cooling system hoses since that are nearly 14 years old by now. Or just replace what hasn't by now.
Here is a list of all hoses, all 8 hoses together should be less than $100 and last another 10 years:
http://www.eaceuroparts.com/content/...em-parts-list/
Old 12-24-2011, 10:49 PM
redbull713's Avatar
redbull713 redbull713 is offline
Mein Auto: 96 M3 2/5spd
Check the hose that runs across the top of the radiator to the expansion tank. The nipple might have broken off, it happened to my 97 540i. Check all of the hoses of the cooling system.
Old 12-24-2011, 11:49 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
I would bet on the expansion tank. Time or a cooling system overhaul.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 12-25-2011, 03:56 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
You have your basic cooling system overhaul in front of you.
It cost me about 500 or so in parts from Oembimmerparts.
It will cost you double if you farm it out.
Since it's likely the most common problem on this forum, you can't help but find every single thing you need already posted when you do a search for "cooling system overhaul".
Good luck and MERRY CHRISTMAS!
Old 12-25-2011, 11:12 AM
mifesto mifesto is offline
Mein Auto: m3
take off the expansion tank. remove the bleed screw and the plastic around the screw and the expansion tank will semi fall out and only be held by the hose at the bottom. it will give you a chance to check for damages.
if not maybe lightly squeeze the hose connected to bottom of expansion tank, see if theres any damage.
it could also be the radiator plastic endtanks itself....
goodluck!
Old 12-27-2011, 06:37 PM
540i Guy
Thanks guys I got it fixed at a local bmw dealer shop, come to find out it was a cracked upper hose that goes to the manifold guy charged me 160.32 for parts and labor
Old 12-27-2011, 06:40 PM
So, one of the two mentioned previously above?
Hose number should be on the work order they gave you.
Old 12-27-2011, 07:30 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
This means you have a good opportunity to plan a total cooling system overhaul, as Bluebee discussed above. Water pump, coolant reservoir, thermostat, hoses, radiator and more tend to fail within a short period of each other. It's best to take care of this pre-emptively because overheating can severely damage the cylinder head.
BMW--giving new meaning to the phrase "disposable income."
