Old 12-25-2011, 07:06 PM
dgdoc dgdoc is offline
Mein Auto: 2001 540i/6spd
540i Rough Idle
My 2001 540i with 130K miles has a very uneven/rough idle when cold.
Seems to be getting worse and now even when it is warm, the idle is rough and not what it was 6 months ago.
The idle speed on the car is now down to about 590 RPM when warm. (What is the spec?).
I've changed plugs recently - O2 and MAF replaced 3 years ago.
I'm thinking it needs new intake manifold gaskets, but wanted to see if it could be something else before tackling this job.
Could the CCV cause this problem? (Car is not burning oil, no smoke, no codes stored).
Old 12-25-2011, 08:18 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Is the SES (CEL) light on?
Your warm idle should be 500 RPM with AC off, 700 with it on.
Old 12-25-2011, 08:29 PM
Thanks JimLev - No CEL or codes stored.
It is a 540 6spd so not sure the specification for idle speed is any different compared to an Auto.
As mentioned, it is very rough and almost sounds like it is misfiring when first warming up in cold weather. It did this last year too and at the time, thought it was intake manifold gaskets.
But, now seems to also not idle perfectly when warm, so was looking for suggestions of what this might be.
Old 12-25-2011, 08:50 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
Have you checked for pending codes using a code reader?
Old 12-25-2011, 08:55 PM
That was the first thing I checked.
No Check Engine Light and no Codes stored.
Old 12-25-2011, 09:24 PM
When I had a rough idle that appeared after working on the car, it turned out to be hose#27 not sitting properly on the intake resonator, ever so slightly.
http://www.realoem.com/bmw/showparts...13&fg=20&hl=70
Checked all over for vacuum leaks and got codes for ICV, cleaned the ICV several times and still rough idle when cold. Was about to replace the ICV. That is, until I noticed the hose not sitting exactly on the resonator. Twisted the hose firmly in place and the idle went back to normal.
I realize you have a m62TU engine, but suggest you double check vacuum hoses and intake hoses again.
Old 12-26-2011, 07:40 AM
Thanks - This has been degrading over the last year or so and also is much worse when cold - so based on the continued downward spiral, doesn't seem like it would be a hose.
Will check..
Any thoughts on either CCV or air leak around fuel injectors?
Old 12-26-2011, 03:48 PM
Dents Dents is offline
Mein Auto: 2000 540i 6 speed
Are there any other symptoms such as low RPM hesitation or studdering under 2000 rpm?
Old 12-26-2011, 03:50 PM
No other symptoms.
Runs perfect off idle.
Lots of power, accelerates smoothly.
Old 12-26-2011, 06:47 PM
N62b44 N62b44 is offline
Account Under Review
Mein Auto: M3e46
100% air leak somewhere or some coils are bad
Old 12-28-2011, 07:05 AM
Agree on probable air leak - dont think it's coil packs because it runs fine off idle or during hard acceleration.
Old 12-28-2011, 10:16 AM
Calicoastin Calicoastin is offline
Mein Auto: 2003 E39 540i auto
That #27 hose dvsgene mentioned is not on the M62TU 540i. The intake muffler is actually plastic welded onto the intake hose.
Make sure your intake hose clamps are tight.
