E46 (1999 - 2006)
Old 12-26-2011, 02:14 PM
beamer4life beamer4life is offline
Mein Auto: 325i
Indicator lamp
Myy 2003 325i displayed a yellow exclamation point inside a yellow circle. It indicated a error within the transmission system. There is a reset to start the engine in park, engage the emergency brake, then turn the engine off. This worked, but what should I anticipate if it returns? Is this mechanical or on the electrical control side?
Old 12-26-2011, 02:29 PM
jvr826's Avatar
jvr826 jvr826 is online now
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
You might want to refer to the WIKI about various transmission issues that could occur on automatic equipped E46s. Depending on which unit you have, it could mean a number of things.
Jeff R.
Old 12-31-2011, 06:41 AM
Mein Auto: 325i
Question Indicator Lamp
OK, exclamation point inside of a gear was the actual display. Dealership found zero codes in the software. The car has some weird RPM action while driving. Mechanic mention a "shift sensor"? mounted on the side of the transmission.?.?.?.
Old 04-23-2012, 05:08 PM
missinglink missinglink is offline
Great DIY guys!
Mein Auto: 325i
Well, same here, I got the transmission warning light, put in the shift sensor, and still the same, the computer didn't recognize park, it did neutral, no reverse, no drive. How did you fix?
