Old 12-28-2011, 09:00 PM
Skyhigh512 Skyhigh512 is offline
Mein Auto: 01 BMW 540i
Dsc light on
I have a 2001 BMW 540. The dsc light is always on. If I push the button it won't turn off.
How do you fix this? Is it bad to drive with the dsc light always on?
Old 12-28-2011, 10:37 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
When the DSC light is on, it means your DSC system is not operating. Are the ABS and Brake warning lights also on?
Here's a post with lots of information that may help.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 12-29-2011, 05:46 AM
No just the dsc light is on. Thanks for your reply
Old 12-29-2011, 06:10 AM
garywald119 garywald119 is offline
Mein Auto: 2004 545i sport
You have 4 sensors, 1 per wheel. could be corroded connection or bad sensor. If I remember correctly there about $75 each... Plus easy to replace
Old 12-29-2011, 07:55 AM
As garywald119 wrote, it's probably a wheel sensor. There are instructions for checking the wheel sensors in that thread I linked. Also, the dealer has software that can diagnose the fault and determine which sensor or other component is a problem.
Steve
OSRAM CBI
Old 12-29-2011, 09:41 AM
Is there a way that I could get that software and check it myself?
Also what is the name of the sensors? Is it wheel speed sensors?
Old 12-29-2011, 10:40 AM
kgorczyn kgorczyn is offline
Mein Auto: 2000 528i SP/PP
I disagree with the above suggestions - an ABS/Speed Sensor would set off the BRAKE and ABS lights as well.
Every time I have seen ONLY the DSC light on, the issue has been the steering angle sensor. Most of the time it just needs to be recalibrated, other times the sensor has to be replaced. It is about $200 and it's at the bottom of the steering column.
Good Luck!
Old 12-29-2011, 11:11 AM
Thanks for that good info. I'll look into that.
Does anyone know where to download the BMW diagnosis tool??
Old 12-29-2011, 11:39 AM
Download the software won't help unless you have the BMW Scanner. Check on ebay for the software and scanner kits. I bought one for $100 and have a fullly functional GT1/SSS/Progman - now if i could only learn how to use it to it's full potential!
Get it scanned at an Indy - Should take 10 minutes. Maybe he can try to recalibrate the sensor too and your problem will be gone.
Old 12-29-2011, 09:35 PM
Trebbia's Avatar
Trebbia Trebbia is offline
Mein Auto: BMW E39 I6
There are entire forums dedicated to the bmw diagnostic tools which you can download for free.
All you need is a laptop PC and the right cable for your pc & bimmer.
Start with the threads on this forum which explain where to get the software & cable and how to set it all up.
Old 01-06-2012, 12:14 AM
cclcal cclcal is offline
Mein Auto: 525iT
I have the exact same issue, DSC light always on.
I had an indy shop tell me it's the ABS control module, cost about 1000$ but you don't have to replace right away.
I think I will do a search on this forum for wheel speed sensors and steering angle sensor and then plan my next step.
Old 01-06-2012, 12:53 AM
ilian007 ilian007 is offline
Mein Auto: BMW 530i 2002
Ive had same problem replaced the dsc contol module and the problem got fixed. You can have yours rebuild. Just have it in mind you will need the new module programmed at the dealer.
Old 01-06-2012, 01:31 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This from the bestlinks will give you a head start on how to test the four wheel speed sensors and the software to test the three steering angle sensors.
- How to diagnose the BMW amber ABS BRAKE DSC/ASC trifecta or bifecta (1) & what are all known options when your ABS control module is bad (1) & Quick99Si's explanation of why the 10-minute wheel speed sensor diode-action quick test doesn't always work, especially on brand new non-OEM wheel speed sensors (1) (2) & explanations by 540iman as to why the fancy diagnostic tools very often (extremely often, like almost all the time) fail to properly diagnose the trifecta or bifecta (1) (2) (3) (4) (5) (6) & where to get the fancy schmancy diagnostic tools for free once you're aware of these limitations (1)
Old 01-06-2012, 03:27 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
How to fix your DSC light
Old 01-06-2012, 05:53 PM
Mein Auto: 525iT
read that already. Looks like I will have to buy a cable and software.
Still cheaper than dealer
Old 01-08-2012, 09:34 AM
jht3 jht3 is offline
Mein Auto: e30 M3; e39 540i/6
when my '01 540 exibited the DSC light, with an amber BRAKE warning, it was the brake light switch under the steering column. replaced it and the problem went away. i have DIS and INPA on my laptop and used them to find the issue. no way i would have found it other than drive to my local shop and scan it w/ their Autologic. good luck
Old 01-09-2012, 02:30 PM
Jht3 where did you get DIS and Inpa? Tell me how you got it and what I should look for. Thanks
Old 01-09-2012, 03:20 PM
google is your friend. DIS runs on a SCO Unix operating system base, and INPA is a Windows tool. for both you need a working OBDII interface. i have an el cheapo serial based EDIABAS cable i bought off ebay, connecting to my laptop with a serial->usb adapter. if you aren't familiar with vmware/virtual machines it can be challenging to get it all working. INPA is all you REALLY need to read all the BMW specific codes and run most of the diagnostics, it just isn't as user friendly as DIS.
Old 08-10-2012, 03:37 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Good Luck!
How to recalibrate?
Old 08-10-2012, 04:57 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Originally Posted by ztom View Post
How to recalibrate?
Not sure how much you know about BMW DIS and aftermarket diagnostic software/hardware...but there's tons of info on the internet and in these forums about diagnostic stuff.
For example...I typed "BMW DIS software" into my browser's google search box and got info like found at this link:
Q {BMW CCA Member #191509}
(SOLD)
Old 08-10-2012, 11:48 PM
bluebee's Avatar
Making sense of the most often recommended BMW diagnostic tools & cable interfaces (1) & BMW factory & dealer programming, coding, and diagnostic software such as INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman (1) (2) (3) (4) (5) (6) (7) (8) (9) & related BMW diagnostic-tool forums (1) (2) (3) (4) (5)
