Old 11-13-2012, 02:24 PM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
Had my 4 wheel alignment done today and here are the specs.... Hope this helps out on the rear tire wear...
All in all I had my 4 wheel alignment, brake system flush, oil change, battery cable recall, scope check and vehicle condition inspection (found out my vacuum pump is starting to leak oil externally. $942 parts and labor if they do it) all for $450.28. My SA takes care of me pretty good.
If your close enough, go to Peter Pan BMW and talk to Pete Scallon and tell him Shanon sent you and he'll take care of you...
2006 BMW 650i Sport/Premium Package
+ Various Mods & Upgrades
Old 03-29-2015, 12:42 PM
BryantandDonna BryantandDonna is offline
Mein Auto: 2009 650i
Question
Originally Posted by Yorgi View Post
My advice is to talk to mechanics, not service advisors since most seem to be smoking cheap drugs.
You can adjust the rear camber on a stock suspension using eccentric bolts, which all BMW rear suspensions have since at least the E30. Any SA should know this. You can only adjust by a few degrees but to say you cannot adjust rear camber is just plain wrong.
Bolts #11 and #15 in this diagram:
Yogi, I've found bolts 11 and 15, is there a specific way I'm supposed to adjust them?
