E36 (1991 - 1999)
Old 01-01-2012, 03:17 PM
pilot093 pilot093 is offline
Mein Auto: 1992 325i sedan
a strange problem
so as some of u may know, my radiator blew cause im retarted nd left the car on with no fans nd a fkd up water pump. but anyways all them parts are out of the way but there is a little weird thing with my car now.
My battery is always fkn dead. when i turn the key to the complete off position this harsh beeping noise come on for a lil. not the "door open, or on position". and when i take out the key completely my interior lights stay on and so do my rear license plate lights. so my question is.. what could be causing this? blow fuse? i hope im not starting to have beemer electrical problems.
Thanks alot guys
Old 01-01-2012, 05:09 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Sounds like an electrical gremlin of some sort.
1998 BMW 328is
1966 Pontiac GTO
Old 01-01-2012, 05:10 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
The harsh beeping noise it telling you your lights are still on. Most likely your headlight switch is shot. They break internally and will still make contact with some of the light circuits, even though it's in the "off" postion.
Yes, you are starting to have typical BMW electrical problems.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 01-01-2012, 05:11 PM
luckeedog luckeedog is offline
Mein Auto: E21,E36
Your trunk light is probably staying on. The wires in the harness running from the body to the trunk lid have a tendency to break or chafe the insulation off and contact a constant ground causing the light to stay on. Open the trunk and push the button and see if the light goes out, if it doesn't, wiggle the wiring harness where it runs from the body to the lid.
Old 01-01-2012, 05:23 PM
D'oh, You kids!
He already idenified which lights stay on. The trunk light might be staying on, too, but my money's on the headlight switch (since I had the exact same thing happen to my 318is)
Quotes to live by:
BMW-CCA #441426
Old 01-01-2012, 08:13 PM
i got another light switch bouta put it on maybe thats the problem well see but this **** is really annoying cause my battery just get drained after i shut the car off
Old 01-02-2012, 12:47 AM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Well when you turn on the car do the headlights come on without turning the knob. Or corners or fogs. That would be a giveaway sign that the switch is to blame.
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 01-02-2012, 02:57 AM
Nah headlights dnt come on just interior lights and license plate lights. after my rsdiator blew i turned the car off nd that was the first time when i noticed this bullsht. trunk lights just stay on nd like i said there us a annoyin beeping noice ontop of regular beeping when you open.the door or turn the key
Old 01-02-2012, 11:46 AM
ZeGerman's Avatar
Warm Leatherette
When you say "interior lights" are you referring to the overhead lights, or the instrument cluster lights?
1998 BMW 328is
1966 Pontiac GTO
Old 01-02-2012, 12:39 PM
instrument lights, i think overhead too im not sure tho. car is in the shop right now so i cant check. im thinkin maybe i should just tell em to make a lil switch to cut the battery power off completely.. since my radio stays on too.(aftermarket radio)
Old 04-06-2012, 09:06 AM
nelson d nelson d is offline
Mein Auto: 92 325, ford van, super 7
did you ever figure it out? my car is doing the same thing
Old 04-06-2012, 09:23 AM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
Don't waste your money having the shop make a cut off switch. They are gonna charge you 100$ go to Orilys or auto zone. You can get a 12amp switch for 7 or 8$ and I stall it at the battery until you FI d the problem. If the If your interior lights are staying on I'm thinking the issue is in the ignition. It sounds like you may have a wire loose or touching in the on position. A
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
