Old 01-01-2012, 08:33 PM
kongfu1 kongfu1 is offline
Mein Auto: BMW Z4
Error code P0340 and P1338 on Z4 - 2003
Any suggestion about how to fix this? It is Z4 2.5i-2003.
There something wrong with camshaft position sensor. But no idea it is left side or right side of CPS. There are two CPS parts are available for Z4, one with sensor, cable and connector and one has sensor only.
Error codes go with Bank1. Any suggestion?
Old 01-02-2012, 07:03 AM
kalali kalali is offline
Mein Auto: 2003 Z4 2.5
Sorry I can't help with your specific question but was wondering what symptoms did you have? I also have an '03 Z4 and am experiencing a cold starting issue that may be vanos related. Sometimes vanos problems also trigger a cam position sensor/adjuster code. Thanks.
Edited to add that I don't get any codes which I find mystifying. Also to add that the only CPS I'm aware is the one that sits right below the exhaust (left side looking from the front of the car) cam shaft below the left vanos. And it looks like a sensor with a connector plugged into it. Hope this helped.
Old 01-02-2012, 07:36 AM
eken eken is offline
Mein Auto: 2001 Z3 3.0i
Intake cam position sensor has cable attached. and is located on right front of engine, just to left of oil filter, and under engine vent hose. Exhaust cam position sensor is located front left of engine just under cylinder head cover, if standing facing the engine in both cases. If you google "replacing intake camshaft position sensor BMW youtube, you should come up with a couple of videos on how to locate and replace. I believe the code you are getting PO340 is for the intake sensor malfunction Good luck!
Old 01-02-2012, 07:40 AM
Mein Auto: BMW Z4
Sometimes the car wouldn't started. From display panel, "engine service required" will
be displayed. If you remove the key, restart the engine it will be fine.
In California, it is rarely to see a cold weather. Not sure if the error codes are caused by vanos.
Old 01-02-2012, 07:44 AM
Mein Auto: BMW Z4
Smile
Thanks. Your post is very helpful.
cps sensors, z4
