Old 01-02-2012, 10:12 AM
Slick44 Slick44 is offline
R.E.44
Mein Auto: 2011 BMW 750i/2007 750i
E65 remotes don't work
The key fobs aren't working period. Sometimes they'll open the truck but they won't lock or unlock the car. I tried the other remote that is basically knew thinking it was a battery problem but still no luck. Any one know what's going on?
Old 01-02-2012, 10:18 AM
UK 750i Sport UK 750i Sport is offline
Mein Auto: BMW 750i Sport
Have you tried re-programming the remotes to the car? Sometimes works, sometimes doesn't, but worth a try;
To sync a remote key to the car;
1) Close the door, and fasten your seatbelt.
2) Insert the key into the slot in the steering column.
3) Hold down the unlock button on the dash-- don't press the brake pedal --
4) Whilst holding the unlock button press the engine start/stop button to turn on the "ignition on" position. This is when all of the dash indicators come on. Continue holding unlock button.
5) After about 10 seconds the "gong" will sound. At this point you can release the lock button and remove the key from the ignition.
6) Lock the car using the buttons on the key fob and let the car go to sleep (up to 20 mins).
2005 (2006 model) BMW 750i Sport, Black Sapphire metallic with Black High Gloss shadow line, Privacy Glass, 20" Y-Spoke Alloys, Sunroof, Rear and Side Electric Blinds, Xenons, Black Nasca Perforated Leather, Dark Ash High Gloss Wood Trim, Comfort Seats - front (20-way) and rear (14-way), Heated Seats - front and rear, Ventilated Seats - front and rear, Sport Steering Wheel, Pro Logic 7 Hi Fi System, Sat Nav, TV, 6xCD Changer, Comfort Access, Soft Close Doors, Powered Boot Lid.
Old 01-02-2012, 11:51 AM
R.E.44
I tried this. It didn't work
Old 01-02-2012, 08:38 PM
R.E.44
Took
The car to BMW. They said I needed a new antenna and 2 new remotes. All covered under warranty.
Old 01-02-2012, 10:40 PM
jdub4051 jdub4051 is offline
Mein Auto: 745Li
Lucky. I wish I was under warranty.
Old 01-03-2012, 09:57 PM
Wilassasin's Avatar
Wilassasin Wilassasin is offline
Wilassasin
Mein Auto: 2013 S550 amg sport pack/
Hey slick when did this issue start? Mines started when i got the iphone 4.
Previous: 335i xdrive coupe(sold),745(sold),750 sport(sold).
Current: 2013' S550 4matic, 2016' C7 (stingray).
Old 10-05-2012, 09:38 PM
markandersonus markandersonus is offline
Mein Auto: 2005 745i
nor me. none of buttons work with new battery
