E36 (1991 - 1999)
Old 01-02-2012, 04:36 PM
NiiCKSTERR NiiCKSTERR is offline
Mein Auto: 1994 E36 318is
Unhappy I need help! E36
1994 318is E36
So heres exactly whats going on.. i recently cleaned my whole engine. i used a bunch of home ingredients including bleach and degreasers. i used these ingridients for about 3 days of cleaning my engine. on the 4th day i went to pressure wash it. i was on the way home when suddenly my car was stopping and going on its own(with my foot on the pedal of course). i was in 1st gear and it would lag when trying to go, in other words it was idle surging. i got home and the next day my car didnt want to start. so i changed the fuel pump fuse. it takes a 25 but i put a 30 because thats all i have. it was working fair for awhile. then last week i wanted my car back to perfection because it still wasnt working 100%. i found out there was water where the spark plugs were. i flushed out the water, sanded the spark plugs, played with the idle a little bit, and then thats when things really got worse. btw my idle hasnt been 100% either, even before all of this happened. now my car is running like shiiiiit! it sputters very bad! its doing the same thing from the begining, its sputtering very loud. in 2nd gear i can hit about 40mph without red lining. its bad. so my main problem with it right now is the sputtering and the stop and go issue i have. i figured with a clean engine my car would be working better but i was wrong. i really could use some help here. any ideas? i read so much on here about what it can be but i want to know forsure before i spend the money on it. oh and btw my computer in my car is also bad.
Old 01-02-2012, 05:27 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
first,
s p a c i n g . i s . r e a l . i m p o r t a n t ., . t o o ., . a s . i t . m a k e s . i t . e a s i e r . t o . r e a d . w h a t . y o u . w r o t e . o r . e l s e . e v e r y o n e may . j u s t . a s s u m e . t h a t . y o u . a r e . c a n a d i a n. , . o r . s o m e t h i n g .
the last line says it all, though. if the dme is messed up, then you need to get that addressed first.
however, since you decided to get everything wet with your homebrew, make sure it is dry completely before checking anything else out.
and read the stickies, you'll learn quite a bit from them, k??
and welcome to the fest.
df
Old 01-02-2012, 05:50 PM
Burning2nd's Avatar
Under the lift arms
i had no problem reading your post...
Id recommend letting the car idle at a stop for a few hours (assuming it wont overheat)
when you wash your engine... In the future... stay away from the electrical ignition items...
also when you wash it... its on and running.. and warm... dont use bleach
15486372<-----
Old 01-02-2012, 05:53 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
If his DME is bad, as he stated, idling the car for hours on end will not make a difference. Fix what you know is broken first.
1998 BMW 328is
1966 Pontiac GTO
Old 01-02-2012, 05:54 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
Sounds like a misfire from the coilpacks
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 01-02-2012, 06:02 PM
i could read it as well, it was just very choppy, inconcise, and ended with 'my computer is bad...', so i was thinking to my self, well, duh!!??
how is the computer bad?? there are so many other things that it could be that it would be almost impossible to *not* come up with a wild guess and still have it be plausible.
if you 'know the computer is bad', then start from there.
other things that could be causing an issue are dirty icv, throttle plate, fuel filter, coils and/or ignition wires, spark plugs (yeah, i know... you 'sanded them'...), all the way up to and including a blown head gasket.
any way you look at it, the only thing we (as in the forum) can deduce from your post is that you have driveability issues and a bad dme (computer). if that is true, then the first thing that needs to be done is get it fixed.
df
Old 01-02-2012, 06:09 PM
Burning2nd's Avatar
Under the lift arms
i didnt see anything in that about not running... or a dme...(computer we can call that)
15486372<-----
Old 01-02-2012, 06:15 PM
I forgot to mention that it was running while i cleaned it. it was warm and worked fine before that.
Old 01-02-2012, 06:18 PM
i say its been about 2/3 weeks since i last cleaned my engine, so it should be dry by now, right?
Old 01-02-2012, 06:20 PM
one of my guys told me my dme is on default and i need a new one. he said it couldn't read, then he said i need a new dme. im not sure what its called but its a computer thing about 2 feet long and he connected it to my car then after that he said i need a new dme
Old 01-02-2012, 06:34 PM
who said anything about it running/not running in regard to driveability??
the comment, as i understood it, was regarding washing the engine down.
as for the bad computer, it was the last sentence...
df
Old 01-02-2012, 06:50 PM
Mr Gusta's Avatar
Fireballs inc.
check and see if there is water where the spark plugs are
jmansour jmansour is offline
Mein Auto: 04 325i -5spd black/black
YAhhh I learned this lesson the hard way, I washed my moms Odessy like this (but using a hose) and then when my dad tried driving it, it was acting up and eventually just stopped and was all 'ed up. I had to have everything dried off and what not then it ran again. Hopefully you didn't mess too much up and its just temporary
Old 01-02-2012, 06:51 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
You had no problems reading his post, yet made a point of double spacing yours for ease of reading.
DF wasn't harping or saying ill, merely trying to make it easier for all of us to read and assist.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-02-2012, 07:52 PM
there was water where the spark plugs were but there isnt anymore..
Old 01-02-2012, 07:58 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Where is Franklyn?
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 01-12-2012, 06:19 PM
inc_ride2 inc_ride2 is offline
Mein Auto: 318 IS
RE; I need help! E36
After you cleaned the plugs did you ever take care of the wires? thats where your problem is coming from also
Old 01-12-2012, 08:59 PM
Hellawut??
Mein Auto: who knows?
hellooo
-Franklyn
Old 01-12-2012, 09:11 PM
crisscross's Avatar
A little late for mr. 2nd though...
-Alan
-2000 F250 V10
Old 01-13-2012, 10:39 PM
Its fixed! I had a wet spark plug (got it replaced). Next i bought new spark plug cables, they cost $167. and the coils had corosion(from the water) it had some green dust on them, i just cleaned it up and it worked fine. So new spark plug cables and i was good.
Old 01-13-2012, 10:43 PM
hornhospital's Avatar
D'oh, You Kids!
Good job! Where did you buy the wires, and what brand are they? That's about $40 more than an OEM set from Pelican Parts.
Quotes to live by:
Old 01-14-2012, 06:42 PM
Mein Auto: 318 IS
@ Mr Crisscross not sure where the humor was directed?
Thats good Niickster your back on the road
Old 01-14-2012, 06:46 PM
crisscross's Avatar
Don't worry about it, it was for eight Thirty...
-Alan
-2000 F250 V10
Old 01-14-2012, 09:23 PM
Hellawut??
Yeah newbss!!!!
jeessshh!!
Just kidding.
:group:
-Franklyn
Old 01-15-2012, 02:45 PM
quickgt quickgt is offline
Mein Auto: 325i
I had the same exact problem with my 99 Cadillac Eldorado. I washed my engine bay and I fouled all of my coil packs. Replaced them and no problems
07 BMW X3
94 BMW 325i
e36, idle, issues, problems, sputtering
