E46 (1999 - 2006)
Old 01-02-2012, 09:34 PM
Bottombury Bottombury is offline
Mein Auto: 2001 330i
Throttle Delay
When I press down on the gas pedal while in neutral there is a delay of about a second before the engine starts to rev, yet while in gear the response is immediate. What is going on? Is this normal for BMWs?
This is my first BMW and it is a 2001 330i 5 speed manual transmission. Please help. Thanks.
Old 01-02-2012, 10:17 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Electronic throttle. There's a device that adjusts throttle response but it's received mixed reviews and the gist of it (to me) was that it made the last 1/4 of throttle travel useless
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 01-02-2012, 10:34 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Try resetting throttle adaptation. Turn key to "on" (but dont start it) for 10 seconds, then off for 10 seconds and then start the car. Some people swear by it.
Old 01-02-2012, 11:39 PM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
A full second? That doesn't seem quite right. Not really sure what make such an excessive delay in neutral while everything is fine in gear either.
When you say you're in neutral, is that with the clutch depressed?
Old 01-07-2012, 09:37 AM
Maybe not a full second but close to it. Anywhere between a half second to full. I can press the pedal all the way to the floor and take my foot off before the engine revs. This happens in all neutral states, idle and with the clutch.
It's anoying, but I have learned to accomidate. The only thing is though, if I drive another persons car I tend to over rev and makes me look like a noob at standard. :s
I'll try the ten seconds thing and see if that work.
Old 01-07-2012, 11:26 AM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
And by the way
It's def not normal.
You will be able to find a fix for this.
Old 01-07-2012, 03:22 PM
e46_platform e46_platform is offline
Mein Auto: 2002 330Ci 5M sport
i heard the reset was only for automatic trannies?
mine (5 speed manual) also has about a sec. delay
Old 01-07-2012, 03:37 PM
JJ3699's Avatar
JJ3699 JJ3699 is offline
Send a message via AIM to JJ3699
Mein Auto: 2003 325i
+1 and it is irritating
.................BMW 4 LIFE.....................
Old 01-07-2012, 10:29 PM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Welcome to fly by wire technology
Just curious, off a dead stop or transitional lag when applying the throttle?
delay, manual, throttle
