Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 01-03-2012, 12:31 PM
328is Driver 328is Driver is offline
Matt
Mein Auto: '98 328is
Clutch Point Adjustment
Hello all, i just got a '98 328is and joined the forum, but ill save that for the introductions thread. Anyways, I'm also learning how to drive. I've been driving for over a year (I'm 17) but in an automatic '02 Camry. My new Bimmer is a manual. As any new manual driver does, I'm struggling a little bit. One thing i have noticed is that the clutch point is fairly high in the throw of the clutch. It's a '98 so it makes sense that the cable has stretched a bit and I would need to adjust it soon either way so I was wondering if anyone had done this before and could give me some tips? Thanks.
Old 01-08-2012, 03:37 PM
mywidebody02 mywidebody02 is offline
Mein Auto: 04 X5 4.8is
there is no cable. it is hydrolic and no adjustment. That's the European way
Old 02-27-2012, 10:11 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
the late take up on the clutch is due to clutch wear. you may be looking at replacing it soon. does it slip?
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 02-28-2012, 11:26 AM
tim330i's Avatar
tim330i tim330i is offline
Administrator
Mein Auto: Ti Silver 03 M3
You could put some washers between the slave cylinder and the bell housing. Worked well for me.
Tim
The 2014 F32 4 Series Coupe Concept
BMW F32 4 Series Coupe on sale summer 2013
