Old 10-13-2012, 06:45 PM
KingSilverback KingSilverback is online now
The Silverback
Mein Auto: 2006 750Li
Yes, I did this using NCS Expert, read the MMI ecu, then search for IPOD, when you find that line change "nicht_aktiv" to "aktiv" and you will have the ipod menu instead of CD1-6
Old 10-13-2012, 07:05 PM
LuvThis7 LuvThis7 is online now
Mein Auto: 06 Bmw 750Li
Ipod Menu
I did this with dashsoft, but it would never show the songs in my playlist, the lil cursor kept spinning and spinning, But yes i did fig it out.
Does anyone know how to code windows up from the keyfob with dashsoft 2.1.
If not can someone send me a link to download ncs dummy.
Old 10-13-2012, 07:50 PM
Tanny Tanny is offline
Mein Auto: BMW 735i
im also looking to code doors lock when driving and follow me home lights on the fob from dashsoft. Acefx said he doesnt know how to do it...I bought a cable for NCS, does anyone with NCS know how to do this?
Old 10-13-2012, 07:57 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
Gentlemen,
Check this thread, I used NCSExpert to code the features you mentioned
http://www.bimmerfest.com/forums/sho...d.php?t=648573
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
The Silverback
www.bmwcoding.com all the info you need on inpa and ncsexpert is there
Old 10-13-2012, 08:06 PM
Mein Auto: BMW 735i
Originally Posted by First_745Li View Post
Gentlemen,
Thanks,
Ive actually seen that thread. Ill read up on how to use NCS expert to code that when I get the cable as I have been using dashsoft. If I run into problems ill be in contact
Old 10-13-2012, 10:36 PM
ayman ayman is offline
Mein Auto: bmw 740il & BMW M5 e39
my car already with Windows up from the keyfob, i can read for you the block file by Dashsoft but what will be the the controller? General Module?
Old 10-13-2012, 10:48 PM
Yes. Please me the line info. Thanks. I been needing to get this via dashsoft.
Old 10-13-2012, 10:54 PM
Dear Luvthis7,
i will share with you the codes after 8 Hours
Old 10-13-2012, 10:55 PM
Mein Auto: BMW 735i
Ayman do you have auto lock and follow me lights enabled? I'm wondering if I can do this on dash soft
Old 10-13-2012, 10:58 PM
Dear Friend,
i know friend had Auto lock i will try to read his car codes then i will share it in this forum.
but i did not understand follow me lights enabled? what is that option
i also don't have the Accept massage in the MMI
My car is middle east options its so different then US cars.
Old 10-13-2012, 10:59 PM
Mein Auto: BMW 735i
When you unlock the car or lock. The Parker lights will come on. So at night in car park you can find your car
Old 10-13-2012, 11:00 PM
Mein Auto: BMW 735i
Also called welcome lights
Old 10-13-2012, 11:02 PM
i have friend his car imported from US he had this options with a sound also.
i will copy his code and share it very soon. please let me know is it in Light Module?
also his car had Front Signal as park light
Old 10-13-2012, 11:06 PM
check out Elight Module
thats very COOOOOOOOL
i think i will order one you can customized the Welcome light as you like.
Old 10-13-2012, 11:20 PM
Mein Auto: BMW 735i
I'm not sure what module it's in. But I do know it's a function of the key fob
Old 10-13-2012, 11:54 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
If your talking about auto lock ???
Its in key memory on NCS
Sent from my GT-N7000 using Bimmer App
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
Old 10-13-2012, 11:58 PM
Mein Auto: BMW 735i
Yes paper. I don't know how to code that in dashsoft. I bought the cable to do in NCS but I never played with it
Old 10-14-2012, 01:17 AM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW E65 745i
Originally Posted by RTGrove View Post
I am keenly intersted in this as well....but i have the facelift mmi. Possible?
RTGrove, this function is ONLY possible on the facelift MMI. That is using the genuine BMW iPod kit.
I manged to get the MMI and iPod kit off eBay for £250. Great upgrade, well worth doing!
Old 10-14-2012, 01:24 AM
Hi Tanny,
Welcome lights are only a function of the newer light module, I have replaced mine with an LM2 from an LCI E60, also, since swapping the light module the button on the key fob (below the boot button) now switches on the headlights.
Old 10-14-2012, 01:26 AM
Mein Auto: BMW 735i
Ok thanks for clearing that up Stuart.
Old 10-14-2012, 08:56 AM
Hey ayman Can u send me the line info for close doors via keyfob. And the tv line info. None of my channels work. I just get static.
Old 10-14-2012, 09:34 AM
RTGrove RTGrove is offline
Mein Auto: 2006 750 Li
Hmmm...i have a 2006, so it is with the facelift mmi (as i understand it). I also have the oem ipod kit, but i just get cd01-cd06, not the text readouts of the options on the screen....the manual even states that is the way it works. Im confused...
Old 10-14-2012, 10:44 AM
Hi,
Yeah that's right, strange eh! If your MMI has a coding index of C04 then in your trace file from the MMI you should see LISTH_0306, activating this will enable the iPod menus. This is assuming you are using NCS Expert?
For dashsoft you need to go to line 3002 of the MMI coding memory and change one 'bit' in one of the 'bytes'.
My only guess is that BMW developed the iPod kit in conjunction with alpine, and at a later date updated the MMI software to include the iPod menus, that's why if your MMI has a fairly recent software version you an simply enable it. If you want to update the MMI firmware/operating software then you can flash it using winKFP, that's another story though!
Stuart
Old 03-09-2013, 07:10 AM
2FASTFURIOUS 2FASTFURIOUS is offline
Send a message via MSN to 2FASTFURIOUS
Mein Auto: '03 745LI
hi guys, since i am using dashsoft for coding the car, after coding the digital speedo, it seems that the digital speedo comes 1second later than the analog speedo, and also when setting the cruise, the pointer shows the speed lower than actual speed. on the other hand after enabling the video on the move, there number 3 appeared on the bottom of the mmi, is there a way to clean it? also when changing channels there seems to have a light yellow tranparent rectange on the screen with a picture behind for a moment then when channel appears it dissappears, this happen changing channels. is there a way to clean that also? thx for your replies.
