Old 01-04-2012, 09:56 AM
N62b44 N62b44 is offline
Account Under Review
Mein Auto: M3e46
Looks like i Finally discovered BMW V8 secret!!!
Guys,
I was working on my 745i for 2 months to fix the issue with slight hesitation on low rpms.
Recently replaced:
Vcg
Coils
Spark plugs
Compression test is perfect
Fan clutch
And still no effect, just may be a little better.
Inpa, Gt1 are not showing anything, like everything is perfect.
Later some guys came over and I tested their cars with less miles, and guess what??? Same exact issue:
It's slow from pickup, also if you rev the engine you can feel vibration like a small misfire smth.but idling is perfect.
Recently my friend from Europe finally proved my theory about vanos:
He replaced all 4 units with new ones, and now it's day and night!!! It drives like new!!! Awesome torque from low rpms!!!
He disassembled old ones though they are not fixable he says it's same exact sh**Ty issue, as was going on and is going on with M62, m54, m52tu etc!!! Every vanos engine comes with those shty seals, which shrink and cannot move the piston to adjust the timing!!!
I used to have 530i 2003 a year ago, after replacing everything, I was recommended to replace vanos seals with beisan ones!! The result was awesome, and it still drives great.
In other words the ignition is off on low rpms, the piston is pushed for high rpms setting and that's why it drives crappy from low rpms.
I also found here lots of ppl with newer engines complain about exact same issue. Dealer says: your car has no issues, so get last.
Try To rev your car to 3-4rpms and you'll fell slight vibration.
I'm upset with BMW vanos design, so aftermarket seals last 100k miles. And they have had this issue from 90xx and they still install it???
My friend from BMW dealer told me that they replace those units for newer leased cars so they can sell those. Unfortunately they don't last at all!!!! Is it a BMW joke??? Some companies designed sprint booster so you don't have to floor it that much lol
Some ppl think it's okay, but come on 333hp and shty low end torque?? It's still good on the highway, but city mpg is horrible. And if compression test is great on every cylinder, everything is new and no errors, there should be an explanation, right? Saying that my car is old is not explanation at all. So now it's explained.
Simply go to the dealer, ask for a test-drive any new BMW v8, and you'll feel the difference. The throttle response should be instant, it will remind you driving any Toyota, they are nice from low rpms bc their vvti never fails, even after 200k miles.
Old 01-04-2012, 03:05 PM
dommm dommm is offline
Mein Auto: 2011 550ix
Originally Posted by N62b44 View Post
Guys,
Recently replaced:
Vcg
Coils
Spark plugs
Fan clutch
I have also noticed a slight hesitation on low rpms on my 750i/2008. Above you said "He replaced all 4 units with new ones". Please excuse this stupid question but what units did he replace? tia
Old 01-04-2012, 03:28 PM
Mein Auto: M3e46
Yep, believe me you're not the only one here, just bc engine is big and car is heavy, ppl think it's okay, but damn it shty Toyota tundra with 4.0 v6 picks up better than 5,0? I'm just too picky about engines, and if smth does not work right I cannot sleep)
It's called vanos adjustment units.
When you replace it low end torque will be awesome, and no hesitation.
8 cars I've tested none of them worked without that vibration.
In other words wrong timing leads to poor combustion and therefore Higher temp inside the camera, it explains valve steam caps and other problems with V8....
Old 01-04-2012, 03:42 PM
Mein Auto: M3e46
Honestly it sounds like a huge recall to me. But if course they don't gv a sht. Beisan has seals for m62, I'm wondering if they are the same? After I rebuilt vanos on m54b30 I was amazed how car with 160 miles can run, tranny also started shifting better on lower rpms, needless to say city mpg changed a lot: 15-17 to 20-22. If tranny is not getting enough power from the engine the turbine won't spin as it should, so the tranny program will change as well, so for ex it won't shift to higher gear bc there is not much torque, it will even downshift when you go uphill.
So here we get ****ty shifting, shty mpg, slow pickups. Valve cover gaskets die too often, it's all bc of wrong early timing.
One guy told me:"new bimmer runs nice 3-4 yrs or before it reaches 40-60 miles on the clock. This is actually a reason why ppl get rid of their bimmers after 3-4 yrs, bc they don't run the same eventhough dealer says everything is fine.
Kinda sucks bc piston rings and bearings are still perfect after 200k
Miles when all toyotas start smoking.
Old 01-04-2012, 03:53 PM
Wow. I just goggled "vanos adjustment units" & it looks like a big & expensive job!!
http://www.bmwz8.us/pdf/Z8_replacing_Vanos.pdf
Old 01-04-2012, 03:57 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Good info man , so any idea on how much it would cost to replace the vanos adjustment units ???
Old 01-04-2012, 04:12 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
The vanos seals issue with these engines is well documented but this is the first I heard of the problem with the vanos adjustment unit. Have you tried replacing just the seals to see how much each component contributes to the problem?
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 01-04-2012, 05:35 PM
Mein Auto: M3e46
??? Vanos seals are located in those adjustment units) And BMW wants us to buy the whole unit, bc it's not repairable. In m54 engines you can disassemble those.
Look at this pic: seals are flat, so think about the pressure it would create??? The vanos piston will stay in one position.... This pic explains everything
Old 01-05-2012, 12:45 AM
DarkLord DarkLord is offline
Mein Auto: 2005 E65 750i Sport
yep i have this issue , what cost is involved if a indy does it ?
Old 01-05-2012, 03:04 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Doesn't look like that bad of a job, I definitely need to look into this. Where did you get the seal kit?
Old 01-05-2012, 05:24 AM
Mein Auto: M3e46
I'm wondering who doesn't??
Ppl think it's okay to drive like this.
But as I explained before it's not only slows the car... This is what I'm thinking:
Wheep hole
Valve stem caps
Vcg
Premature spark plugs and coils failure
Etc.
Higher coolant pressure
It's all related to higher temp inside the combustion camera.
There are no seals yet for these engines. So far it's 320$*4 plus tons of labor and tools. Sounds like a good job for keif to try and get a new engine performance?? Only problem that even new units won't last more than 40-60 kmiles. It's a shame that BMW engines fail just bc of these seals inside vanos units.
ID:	307214   Click image for larger version
Old 01-05-2012, 07:46 AM
Swif Swif is offline
Mein Auto: 04 745Li
Could it be that the seals are bad design and the fact that oil changes are so far inbetween that this porblem happens?
Old 01-05-2012, 08:13 AM
Mein Auto: M3e46
It's not bc of oil, but I've seen one bimmer with 138miles running 5w30 mobil 1. Surprisingly vanos was alive there... Don't know why, but lots of ppl complain about castrol oil. Could be the issue with oil quality, but now it does not matter.
Old 01-05-2012, 09:14 AM
Mein Auto: 04 745Li
Just read some infor from beisansystems and it seems it is what the o-ring is mad out of. Then throw in the fact that the o-ring is not the best for use with oil.
I emailed them to see were they are with this system and if they have figured a way to repalce the seals yet.
I have the same concern at 60k and can feel the trans shifting a little harsh at low RPM. Plus I have a the rattle and slight ruff idle at times.
Old 01-05-2012, 09:27 AM
Mein Auto: M3e46
Yeah, his name is Raj, a good guy, knows the stuff. We really need them to design those seals and return our cars to the new engine state.
My neibour has 530 2002, I helped him to replace it. Now it drives awesome, very nice pickup from low rpms. If smbdy interested you can stop by and test drive it. Before it drove like piece of st 160kmiles, only bc we have big v8s we don't feel it that bad, but do a new BMW test drive and you'll know what I mean. In the city it's very very big difference, even highway is different. In any way the engine with perfect compression and no errors should not be shaking on revving.
Ps. Remember old V8 m60b44???
It does not have vanos, and it runs always nice if everything is good, in 99 they put intake vanos and after 60 miles it's slow as dog;( rattles etc.
Old 01-05-2012, 10:09 AM
MOPAULY's Avatar
Not much to be done here if they are not making the seals...I'm not going to spend that kind of $$ and a day of my labor to replace the existing units with new.
Old 01-05-2012, 10:47 AM
Mein Auto: 04 745Li
Also checking with Mr. Vanos for a kit.
Old 01-05-2012, 10:56 AM
Mein Auto: M3e46
They buy seals from beisan and rebuild it for you X2 price
Old 01-05-2012, 10:58 AM
Mein Auto: M3e46
Yep, I'm thinking the same way;((
But I really want that fixed. Still don't understand BMW: to design state of the art engine and put those seals which are designed not to last
Old 01-05-2012, 11:10 AM
Mein Auto: 04 745Li
Rajai justed emailed me back say seal kit should be out in about a month. they have been testing on these.
Old 01-05-2012, 11:39 AM
Mein Auto: M3e46
Hmm he said they have it for m62, did you mention N62???
If so it's great news! Who's the first?? Keif?? I will need cam tools for that.
Old 01-08-2012, 05:12 PM
pauliehcfr pauliehcfr is offline
Mein Auto: a car
I researched some vanos rebuilders and they claim the V8's vanos are problem free. However, I too am experiencing some issues that I believe are vanos related. I have a 2004 545. When cold, it feels like it is surging, almost as if I can feel the vanos making slight adjustments. I also get really crappy take offs. It feels as though there is no throttle response at times and I have to give it more gas while releasing the clutch. Did anyone find a seal repair kit for these?
Old 01-08-2012, 05:38 PM
alleng39 alleng39 is offline
Mein Auto: B7
Just purchased a new 2012 B7 will I be having the same problem soon?
Old 01-08-2012, 05:51 PM
down19992000 down19992000 is offline
Mein Auto: 1995 525i
Wheep hole
Valve stem caps
Vcg
Etc.
What is a combustion camera? Sure you dont mean combustion chamber?
Sent from my SCH-I500 using Bimmer
Old 01-11-2012, 12:52 PM
Mein Auto: a car
Just spoke to Beisan and they said the only issues with the N62 motors vanos is that the solenoids get clogged and need to be removed and cleaned....
